Does the app need to be changed to work in the background?
The widget on the desktop does not change in real time.
The temperature value changes on the widget only after entering the "Domoticz" application and refreshing.
Widgets are in beta whether it is still underdeveloped?
Can I set alerts after exceeding the set temperature in the form of vibrations?
Domoticz widget - Android
- Target OS: -
Re: Domoticz widget - Android
Hi,Morcinek92 wrote:Hi,
You can add notifications when temperature change...
Envoyé de mon Redmi Note 4 en utilisant Tapatalk
Hello!
I have the same situation. The widget only displays the fresh data after I log in to the domoticz app. Please describe exactly what needs to be set in the domoticz system (web) and what in the domoticz app to update the widget automatically with the values.
Can anyone help me with the above?kispalsz wrote: ↑Tuesday 06 July 2021 11:00 Hello!
- Domoticz version: Latest
Bump. How can we make the widget data auto-refresh? Without this, the widgets are useless. Bedankt!
- user4563
- Domoticz version: 2025.1
Have you tried the Auto Refresh toggle in settings? Not sure if this has any effect on widgets or not.
If it doesn't, I would create a ticket for a bug report: https://github.com/domoticz/domoticz-android
ODroid H4+ / Ubuntu server 24.04 LTS
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
Domoticz Scenes add-on in Kodi
