Service 8080 does not start
peterbos
When I restart my Raspberry Pi it doesn't restart Domoticz. Apparently the web server (:8080) doesn't start as I found out at the internet. When I start the webserver manually by SSH with the command "sudo systemctl restart domoticz.service" it seems to be stable until I restart the Pi again... Why does the web server not run at startup and how can I repair this so it starts automatically?
Peter
Peter
AllesVanZelf
- Domoticz version: 12467
Re: Service 8080 does not start
See this post: link.
This is to be done on commandline:
and add:
ctrl-X om op te slaan en verlaten.
sudo crontab -e Code: Select all
reboot sleep 60 ; sudo /etc/init.d/domoticz.sh restartDomoticz 2020.1 (12230) on Raspberry Pi 3B with Raspian Buster. Besides Domoticz, Rpi is running Pi-Hole.
A beter way is to use the domoticz internal delay.
When domoticz is installed in /home/pi/domoticz just do
You will see all the command line options, one of them is " -startupdelay seconds (default=0) "
if you put in " /etc/init.d/domoticz.sh "at the end of the option lines with nano, or other editor.
30 seconds should be more then enough and do after that
/home/pi/domoticz/domoticz --helpif you put in " /etc/init.d/domoticz.sh "at the end of the option lines with nano, or other editor.
DAEMON_ARGS="$DAEMON_ARGS -startupdelay 30"Code: Select all
sudo systemctl daemon-reload- waltervl
- Domoticz version: 2026.3
Just for the record, these command line parameters are also available on the wiki page https://www.domoticz.com/wiki/Command_line_parameters
For the record, those are just a copy/paste of the cmdline output. A Wiki should explain those parameters a little bit more.
If you want to be flexible, go for the " -f config_file (for example /etc/domoticz.conf)(Unix Only) " parameter.
And change your the rest of the parameters in the "config_file", its handy for those debug parameters.
AllesVanZelf
EddyG, and others,
I like the idea of this config file. I've never found that before.
I start domoticz as a systemd service with all the parameters in the ExecStart commandline.
If I understand this well, I could replace these parameters by: -f config_file /home/pi/domoticz/domoticz.conf ?
And what about the format of this conf file? Is it used like:
That would be nice.
Edit:
I tried:
With different content in the conf file. But then I get this:
DAEMON_ARGS="-daemon"
DAEMON_ARGS= etc. That would be nice.
Edit:
I tried:
/home/pi/domoticz/domoticz -f config_file /home/pi/domoticz/domoticz.confCode: Select all
2021-06-25 11:29:44.856 Error: Please specify the configuration file.Domoticz 2020.1 (12230) on Raspberry Pi 3B with Raspian Buster. Besides Domoticz, Rpi is running Pi-Hole.
If you installed Domoticz the "normal" way there should be a file domoticz.conf, otherwise you can fetch it here: https://raw.githubusercontent.com/domot ... oticz.conf
This should be in the scripts dir. The text "config_file" is a placeholder, should have been written as <config_file>
To start domoticz, it should be
or debian default
/home/pi/domoticz/domoticz -f /home/pi/domoticz/scripts/domoticz.confCode: Select all
/home/pi/domoticz/domoticz -f /etc/domoticz.conf-
AllesVanZelf
Yes Top. Thank you EddyG. This is working. Never seen this conf file before.
Please feel free to modify that wiki page, it is also your page
. I also never heard of that config file and was wondering what it could do.
peterbos
I can write programs in Pascal, in dzVents, in Arduino C/C++ and even Scratch
but Linux commands are like abracadabra to me. Can anyone give me a "How to (re)boot Domotiz 30 seconds after startup" for Dummies explanation please?
Thanks,
Peter
Thanks,
Peter
Toulon7559
- Domoticz version: <2025
Would this 'feature' not be a candidate to include nested in a next update of Domoticz?
Argument: probably most users when restarting the computer have the aim to get Domoticz operational asap.
Proposed place for inclusion: make it part of 'Restart computer' in submenu 'Other options' of 'Setup'
[Unfortunately not myself capable to make such adaptation, because
not knowing enough about the 'internals' of Domoticz]]
How difficult it is to do (as mentioned before by EddyG):
Edit: text editor nano instructions https://www.raspberrypi-spy.co.uk/2013/ ... pberry-pi/
Toulon7559
Sure the change to domoticz.sh is not difficult, but my suggestion was referring to EddyG's 'better' advice in viewtopic.php?p=276688#p276688
In that message he offers 2 versions dependent on configuration:
then I am starting to be cautious .....
Also aspect to be considered that the adaptation should preferably remain resident when a next upgrade of Domoticz is implemented.
[To make it clearer, now the url included for reference in my previous message]
