I’ve searched the forum but could not find my answer. I now run the latest stable version of domoticz on a raspberry pi 3. Can I simply put my sd card in a raspberry pi 4 and turn it on or do I need to reinstall everything?
Moving from raspberry pi 3 to 4
- heggink
- Domoticz version: 12451
Re: Moving from raspberry pi 3 to 4
It depends. When I did that a few months ago, I decided to do a fresh install since I already did 2 major OS release upgrades so better to start clean. If you are running the latest OS with updates, you are probably OK. Best to make a copy of the disk first. Also, AFAIK, you will need a new bootloader as 3 and 4 are not compatible.
Sent from my SM-G980F using Tapatalk
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
jandirkv
- Domoticz version: 3.9117
Thanks for the advise. I will do fresh install then
