Hue dimmer switch (RWL021) Conbee 2 / Deconz Topic is solved
- Domoticz version: 2021.1
Version: 2021.1
Platform: Raspberry pi 4
Plugin/Hardware: Conbee 2 / Deconz
Description:
When i use my hue dimmer switch connected thru Conbee 2 / Deconz does it not reconise the buttons correctly. an example: a short pres on button 2 is a recognize as a long press on button one.
Does anyone recognise this issue and resolved it ?
Description:
- Target OS: -
Re: Hue dimmer switch (RWL021) Conbee 2 / Deconz
Hello, it s possible this device need a special widget for it.
Can you give the device Json ? You can see it on log, on domoticz/custom/deconz, or on Phoscon Beta.
Then enable plugin log, on hardware panel "debug info only".
Can you share the value you have with the button you have used ? Something like
2021-06-03 16:54:17.624 (deCONZ) ### WebSocket Data : {'id': '12', 'uniqueid': '00:15:8d:00:22:f0:88:12-01-0012', 'e': 'changed', 'state': {'buttonevent': 1002, 'lastupdated': '2021-06-03T14:54:17.612'}, 't': 'event', 'r': 'sensors'}
2021-06-03 16:54:17.625 (deCONZ) ### Update device (deCONZ - Couloir) : {'nValue': 10, 'sValue': '10'}
If I m right, the first number is the button number, and the second one the event, 1002 > 1 button, short press.'buttonevent': 1002
Hi Thorgal789, thanks you your response!
I pressed the first button on the switch, this was the output:
So, its look like it gives 2 commands. first a 1000 then a 1002.
2021-06-04 22:39:51.355 Deconz: (Deconz) onMessage called
2021-06-04 22:39:51.357 Deconz: (Deconz) ### WebSocket Data : {'e': 'changed', 'id': '7', 'r': 'sensors', 'state': {'buttonevent': 1000, 'eventduration': 0, 'lastupdated': '2021-06-04T20:39:51.350'}, 't': 'event', 'uniqueid': '00:17:88:01:02:0e:96:78-02-fc00'}
2021-06-04 22:39:51.358 Deconz: (Deconz) ### Update device (Deconz Switch) : {'nValue': 0, 'sValue': 'Off'}, IGNORED , no changes !
2021-06-04 22:39:51.458 Deconz: (Deconz) onMessage called
2021-06-04 22:39:51.458 Deconz: (Deconz) ### WebSocket Data : {'e': 'changed', 'id': '7', 'r': 'sensors', 'state': {'buttonevent': 1002, 'eventduration': 1, 'lastupdated': '2021-06-04T20:39:51.450'}, 't': 'event', 'uniqueid': '00:17:88:01:02:0e:96:78-02-fc00'}
2021-06-04 22:39:51.459 Deconz: (Deconz) ### Update device (Deconz Switch) : {'nValue': 10, 'sValue': '10'}
2021-06-04 22:39:52.066 Deconz: (Deconz) onHeartbeat called
2021-06-04 22:39:52.066 Deconz: (Deconz) ### Update device (Deconz Switch) : {'nValue': 0, 'sValue': 'Off'}
- Target OS: -
This is normal 0 mean normal press, and 2 Release press.
1000 > normal press for button 1 (ignored by code)
1002 > button 1 released.
I have take a look in the code. If your model is is exaclty "RWL021" it use generic fonction.
2002 > 10 * 2 = 20
Long press press button 1 give
1001 (press) ignored
1003 (release) > 20 * 1 = 20
So yes, there is a problem for this device. I just need to know the model id exact, are you sure it s eaxactly "RWL02", visible on domotic/custom/deconz.
And as the future widget will be eaxctly for this device, can you tell me the working command ? I don't think for exemple the button on/off support long press.
Short press button 2 givea short pres on button 2 is a recognize as a long press on button one
2002 > 10 * 2 = 20
Hi Thorgal789,
Yes, its exaxt the RWL021
https://gist.github.com/sbyx/67f72210c5 ... fb021d259e
Maby you can get what you need from there?
I just came across this script, it contains the exact expected commands:"ep": 2,
"etag": "ce61293b8b3fd351c5c92f345a9fa216",
"lastseen": "2021-06-05T09:33Z",
"manufacturername": "Philips",
"mode": 1,
"modelid": "RWL021",
"name": "Dimmer Switch",
"state": {
"buttonevent": 1002,
"eventduration": 1,
"lastupdated": "2021-06-04T20:39:51.450"
- Target OS: -
Yep, thx, You can try the beta branch.
IDK how you have installed the plugin, but if you have used git command
Go in plugin folder
Update git
Change branch
Update (to be sure)
Then you can delete the created widget for your device, and restart deconz (hardware/deconz/update), at restart deconz will create a new widget just for this device.
Go in plugin folder
cd Domoticz\plugins\Domoticz-deCONZ
git pull
git checkout beta
git pull
Hi thorgal789
Thanks for your help, but unfortunately it still doesn't work. (same behavior) maybe I did something wrong, Can I check if I have the right config now?
pi@WdB-Pi4001:/opt/smarthome/domoticz/plugins/Domoticz-deCONZ $ git checkout beta
Already on 'beta'
Your branch is up to date with 'origin/beta'.
pi@WdB-Pi4001:/opt/smarthome/domoticz/plugins/Domoticz-deCONZ $ git pull
Already up to date.
- Target OS: -
You have deleted the previous remote, in devices panel ? If yes, when you have restart deconz, you will have in log a notification about a new device added.
You can compare files, changes are here https://github.com/Smanar/Domoticz-deCO ... d8b83dab34
I m just seing this device was previously used with tradfri remote, but the code was disabled, and I don't remember why ...
I checked, and the new lines are in the plugin.py. removed the device and added it agian. The single presses are fine now but the long presses are still not recognized.
I exported the full log of the single press.
I hope you can see the issues in the debug
2021-06-07 18:00:29.084 Deconz: (Deconz) onHeartbeat called
2021-06-07 18:00:29.088 Deconz: (Deconz) ### Initialisation > config
2021-06-07 18:00:29.088 Deconz: (Deconz) ### Request config
2021-06-07 18:00:29.088 Deconz: (Deconz) Send Command /api/C2A23BA324/config/ with None (0 in buffer)
2021-06-07 18:00:29.088 Deconz: (Deconz) Making Request: http://127.0.0.1:80/api/C2A23BA324/config/ with params None
2021-06-07 18:00:29.116 Deconz: (Deconz) Request Return: {"UTC":"2021-06-07T16:00:29","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF071E0F","datastoreversion":"93","devicename":"ConBee II","dhcp":true,"disablePermitJoinAutoOff":false,"factorynew":false,"fwversion":"0x26660700","gateway":"10.10.10.1","internetservices":{"internet":"connected","remoteaccess":"disconnected","swupdate":"connected","time":"connected"},"ipaddress":"10.10.10.55","lightlastseeninterval":60,"linkbutton":false,"localtime":"2021-06-07T15:00:29","mac":"e4:5f:01:08:91:e8","modelid":"deCONZ","name":"Phoscon-GW","netmask":"255.255.255.0","networkopenduration":180,"panid":6859,"portalconnection":"disconnected","portalservices":false,"portalstate":{"communication":"disconnected","incoming":false,"outgoing":false,"signedon":false},"proxyaddress":"none","proxyport":0,"replacesbridgeid":null,"rfconnected":true,"starterkitid":"","swupdate":{"checkforupdate":false,"devicetypes":{"bridge":false,"lights":[],"sensors":[]},"notify":false,"text":"","updatestate":0,"url":""},"swupdate2":{"autoinstall":{"on":false,"updatetime":""},"bridge":{"lastinstall":"2021-05-17T16:24:11","state":"noupdates"},"checkforupdate":false,"lastchange":"","state":"noupdates"},"swversion":"2.11.5","timeformat":"24h","timezone":"Etc/GMT+1","uuid":"95e77e4f-5803-4210-8577-ae44af9d4935","websocketnotifyall":true,"websocketport":8088,"whitelist":{"1B1520A50F":{"create date":"2021-05-15T15:09:53","last use date":"2021-05-16T10:37:40","name":"Phoscon#B1920x937"},"1D14A87469":{"create date":"2021-05-15T14:43:08","last use date":"2021-05-15T14:44:21","name":"Domoticz"},"5A736A1A92":{"create date":"2021-05-18T13:40:11","last use date":"2021-05-18T15:45:01","name":"Phoscon#B1291x927"},"6FAB4DA903":{"create date":"2021-06-02T04:21:44","last use date":"2021-06-02T04:29:06","name":"Phoscon#B1366x938"},"778FEFC322":{"create date":"2021-05-28T20:10:48","last use date":"2021-05-30T20:18:50","name":"Phoscon#B375x635"},"7DADF843CA":{"create date":"2021-05-15T19:22:13","last use date":"2021-05-15T23:01:01","name":"Phoscon#B1920x969"},"A54F2AF41A":{"create date":"2021-06-05T14:31:53","last use date":"2021-06-05T14:36:43","name":"Phoscon#B2400x1171"},"B9147004CF":{"create date":"2021-05-15T15:20:26","last use date":"2021-05-15T15:20:26","name":"Domoticz"},"C2A23BA324":{"create date":"2021-05-15T15:35:26","last use date":"2021-06-07T16:00:29","name":"Domoticz"},"DED06E8B42":{"create date":"2021-06-01T16:09:16","last use date":"2021-06-01T19:14:59","name":"Phoscon#B375x635"},"EA2F109D09":{"create date":"2021-05-18T11:01:01","last use date":"2021-05-18T13:03:00","name":"Phoscon#B1700x936"},"F21FA342ED":{"create date":"2021-05-15T15:11:29","last use date":"2021-05-15T15:11:29","name":"Domoticz"},"FA0EB7FB9F":{"create date":"2021-05-15T15:23:16","last use date":"2021-05-15T15:23:16","name":"Domoticz"}},"zigbeechannel":20}
2021-06-07 18:00:29.117 Deconz: (Deconz) Classic Data : {'UTC': '2021-06-07T16:00:29', 'apiversion': '1.16.0', 'backup': {'errorcode': 0, 'status': 'idle'}, 'bridgeid': '00212EFFFF071E0F', 'datastoreversion': '93', 'devicename': 'ConBee II', 'dhcp': True, 'disablePermitJoinAutoOff': False, 'factorynew': False, 'fwversion': '0x26660700', 'gateway': '10.10.10.1', 'internetservices': {'internet': 'connected', 'remoteaccess': 'disconnected', 'swupdate': 'connected', 'time': 'connected'}, 'ipaddress': '10.10.10.55', 'lightlastseeninterval': 60, 'linkbutton': False, 'localtime': '2021-06-07T15:00:29', 'mac': 'e4:5f:01:08:91:e8', 'modelid': 'deCONZ', 'name': 'Phoscon-GW', 'netmask': '255.255.255.0', 'networkopenduration': 180, 'panid': 6859, 'portalconnection': 'disconnected', 'portalservices': False, 'portalstate': {'communication': 'disconnected', 'incoming': False, 'outgoing': False, 'signedon': False}, 'proxyaddress': 'none', 'proxyport': 0, 'replacesbridgeid': None, 'rfconnected': True, 'starterkitid': '', 'swupdate': {'checkforupdate': False, 'devicetypes': {'bridge': False, 'lights': [], 'sensors': []}, 'notify': False, 'text': '', 'updatestate': 0, 'url': ''}, 'swupdate2': {'autoinstall': {'on': False, 'updatetime': ''}, 'bridge': {'lastinstall': '2021-05-17T16:24:11', 'state': 'noupdates'}, 'checkforupdate': False, 'lastchange': '', 'state': 'noupdates'}, 'swversion': '2.11.5', 'timeformat': '24h', 'timezone': 'Etc/GMT+1', 'uuid': '95e77e4f-5803-4210-8577-ae44af9d4935', 'websocketnotifyall': True, 'websocketport': 8088, 'whitelist': {'1B1520A50F': {'create date': '2021-05-15T15:09:53', 'last use date': '2021-05-16T10:37:40', 'name': 'Phoscon#B1920x937'}, '1D14A87469': {'create date': '2021-05-15T14:43:08', 'last use date': '2021-05-15T14:44:21', 'name': 'Domoticz'}, '5A736A1A92': {'create date': '2021-05-18T13:40:11', 'last use date': '2021-05-18T15:45:01', 'name': 'Phoscon#B1291x927'}, '6FAB4DA903': {'create date': '2021-06-02T04:21:44', 'last use date': '2021-06-02T04:29:06', 'name': 'Phoscon#B1366x938'}, '778FEFC322': {'create date': '2021-05-28T20:10:48', 'last use date': '2021-05-30T20:18:50', 'name': 'Phoscon#B375x635'}, '7DADF843CA': {'create date': '2021-05-15T19:22:13', 'last use date': '2021-05-15T23:01:01', 'name': 'Phoscon#B1920x969'}, 'A54F2AF41A': {'create date': '2021-06-05T14:31:53', 'last use date': '2021-06-05T14:36:43', 'name': 'Phoscon#B2400x1171'}, 'B9147004CF': {'create date': '2021-05-15T15:20:26', 'last use date': '2021-05-15T15:20:26', 'name': 'Domoticz'}, 'C2A23BA324': {'create date': '2021-05-15T15:35:26', 'last use date': '2021-06-07T16:00:29', 'name': 'Domoticz'}, 'DED06E8B42': {'create date': '2021-06-01T16:09:16', 'last use date': '2021-06-01T19:14:59', 'name': 'Phoscon#B375x635'}, 'EA2F109D09': {'create date': '2021-05-18T11:01:01', 'last use date': '2021-05-18T13:03:00', 'name': 'Phoscon#B1700x936'}, 'F21FA342ED': {'create date': '2021-05-15T15:11:29', 'last use date': '2021-05-15T15:11:29', 'name': 'Domoticz'}, 'FA0EB7FB9F': {'create date': '2021-05-15T15:23:16', 'last use date': '2021-05-15T15:23:16', 'name': 'Domoticz'}}, 'zigbeechannel': 20}
2021-06-07 18:00:29.118 Deconz: (Deconz) ### Request lights
2021-06-07 18:00:29.118 Deconz: (Deconz) Send Command /api/C2A23BA324/lights/ with None (0 in buffer)
2021-06-07 18:00:29.118 Deconz: (Deconz) Making Request: http://127.0.0.1:80/api/C2A23BA324/lights/ with params None
2021-06-07 18:00:29.128 Deconz: (Deconz) Request Return: {"1":{"etag":"dcac65829314377b9018ee58f124e197","hascolor":false,"lastannounced":null,"lastseen":"2021-06-07T15:59Z","manufacturername":"dresden elektronik","modelid":"ConBee II","name":"Configuration tool 1","state":{"reachable":true},"swversion":"0x26660700","type":"Configuration tool","uniqueid":"00:21:2e:ff:ff:07:1e:0f-01"}}
2021-06-07 18:00:29.129 Deconz: (Deconz) Classic Data : {'1': {'etag': 'dcac65829314377b9018ee58f124e197', 'hascolor': False, 'lastannounced': None, 'lastseen': '2021-06-07T15:59Z', 'manufacturername': 'dresden elektronik', 'modelid': 'ConBee II', 'name': 'Configuration tool 1', 'state': {'reachable': True}, 'swversion': '0x26660700', 'type': 'Configuration tool', 'uniqueid': '00:21:2e:ff:ff:07:1e:0f-01'}}
2021-06-07 18:00:29.129 Deconz: (Deconz) ### Device > 1 Name:Configuration tool 1 Type:Configuration tool Details:{'reachable': True} and []
2021-06-07 18:00:29.129 Deconz: (Deconz) Skipping Device (Useless) : 00:21:2e:ff:ff:07:1e:0f-01
2021-06-07 18:00:29.129 Deconz: (Deconz) ### Request sensors
2021-06-07 18:00:29.129 Deconz: (Deconz) Send Command /api/C2A23BA324/sensors/ with None (0 in buffer)
2021-06-07 18:00:29.129 Deconz: (Deconz) Making Request: http://127.0.0.1:80/api/C2A23BA324/sensors/ with params None
2021-06-07 18:00:29.142 Deconz: (Deconz) Request Return: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"4aa9e6cf9ffa22a1d7ff56bf6afc5c2a","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark":false,"daylight":true,"lastupdated":"2021-06-07T11:38:46.898","status":170,"sunrise":"2021-06-07T03:22:26","sunset":"2021-06-07T19:54:57"},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:07:1e:0f-01"},"2":{"config":{"battery":100,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"850795b3a0043a62c5ecf790202ce46d","lastseen":"2021-06-07T15:39Z","manufacturername":"LUMI","modelid":"lumi.weather","name":"Multi Sensor","state":{"lastupdated":"2021-06-07T15:39:15.711","temperature":2358},"swversion":"20191205","type":"ZHATemperature","uniqueid":"00:15:8d:00:06:7b:ff:d0-01-0402"},"3":{"config":{"battery":100,"offset":-3,"on":true,"reachable":true},"ep":1,"etag":"ea52044837d5d4f322a867739e3a3f12","lastseen":"2021-06-07T15:39Z","manufacturername":"LUMI","modelid":"lumi.weather","name":"Humidity 3","state":{"humidity":4547,"lastupdated":"2021-06-07T15:39:15.723"},"swversion":"20191205","type":"ZHAHumidity","uniqueid":"00:15:8d:00:06:7b:ff:d0-01-0405"},"4":{"config":{"battery":100,"on":true,"reachable":true},"ep":1,"etag":"ff1dbb4348f3b3fc7dfcc552345b62a9","lastseen":"2021-06-07T15:39Z","manufacturername":"LUMI","modelid":"lumi.weather","name":"Pressure 4","state":{"lastupdated":"2021-06-07T15:39:15.730","pressure":1022},"swversion":"20191205","type":"ZHAPressure","uniqueid":"00:15:8d:00:06:7b:ff:d0-01-0403"},"8":{"config":{"battery":67,"group":"4","on":true,"reachable":true},"ep":2,"etag":"32051567397a78789aa640bbed8eda13","lastseen":"2021-06-07T16:00Z","manufacturername":"Philips","mode":1,"modelid":"RWL021","name":"Dimmer Switch","state":{"buttonevent":1002,"eventduration":1,"lastupdated":"2021-06-07T16:00:23.868"},"swversion":"6.1.1.28573","type":"ZHASwitch","uniqueid":"00:17:88:01:02:0e:96:78-02-fc00"}}
2021-06-07 18:00:29.143 Deconz: (Deconz) Classic Data : {'1': {'config': {'configured': True, 'on': True, 'sunriseoffset': 30, 'sunsetoffset': -30}, 'etag': '4aa9e6cf9ffa22a1d7ff56bf6afc5c2a', 'manufacturername': 'Philips', 'modelid': 'PHDL00', 'name': 'Daylight', 'state': {'dark': False, 'daylight': True, 'lastupdated': '2021-06-07T11:38:46.898', 'status': 170, 'sunrise': '2021-06-07T03:22:26', 'sunset': '2021-06-07T19:54:57'}, 'swversion': '1.0', 'type': 'Daylight', 'uniqueid': '00:21:2e:ff:ff:07:1e:0f-01'}, '2': {'config': {'battery': 100, 'offset': 0, 'on': True, 'reachable': True}, 'ep': 1, 'etag': '850795b3a0043a62c5ecf790202ce46d', 'lastseen': '2021-06-07T15:39Z', 'manufacturername': 'LUMI', 'modelid': 'lumi.weather', 'name': 'Multi Sensor', 'state': {'lastupdated': '2021-06-07T15:39:15.711', 'temperature': 2358}, 'swversion': '20191205', 'type': 'ZHATemperature', 'uniqueid': '00:15:8d:00:06:7b:ff:d0-01-0402'}, '3': {'config': {'battery': 100, 'offset': -3, 'on': True, 'reachable': True}, 'ep': 1, 'etag': 'ea52044837d5d4f322a867739e3a3f12', 'lastseen': '2021-06-07T15:39Z', 'manufacturername': 'LUMI', 'modelid': 'lumi.weather', 'name': 'Humidity 3', 'state': {'humidity': 4547, 'lastupdated': '2021-06-07T15:39:15.723'}, 'swversion': '20191205', 'type': 'ZHAHumidity', 'uniqueid': '00:15:8d:00:06:7b:ff:d0-01-0405'}, '4': {'config': {'battery': 100, 'on': True, 'reachable': True}, 'ep': 1, 'etag': 'ff1dbb4348f3b3fc7dfcc552345b62a9', 'lastseen': '2021-06-07T15:39Z', 'manufacturername': 'LUMI', 'modelid': 'lumi.weather', 'name': 'Pressure 4', 'state': {'lastupdated': '2021-06-07T15:39:15.730', 'pressure': 1022}, 'swversion': '20191205', 'type': 'ZHAPressure', 'uniqueid': '00:15:8d:00:06:7b:ff:d0-01-0403'}, '8': {'config': {'battery': 67, 'group': '4', 'on': True, 'reachable': True}, 'ep': 2, 'etag': '32051567397a78789aa640bbed8eda13', 'lastseen': '2021-06-07T16:00Z', 'manufacturername': 'Philips', 'mode': 1, 'modelid': 'RWL021', 'name': 'Dimmer Switch', 'state': {'buttonevent': 1002, 'eventduration': 1, 'lastupdated': '2021-06-07T16:00:23.868'}, 'swversion': '6.1.1.28573', 'type': 'ZHASwitch', 'uniqueid': '00:17:88:01:02:0e:96:78-02-fc00'}}
2021-06-07 18:00:29.144 Deconz: (Deconz) ### Device > 1 Name:Daylight Type:Daylight Details:{'dark': False, 'daylight': True, 'lastupdated': '2021-06-07T11:38:46.898', 'status': 170, 'sunrise': '2021-06-07T03:22:26', 'sunset': '2021-06-07T19:54:57'} and {'configured': True, 'on': True, 'sunriseoffset': 30, 'sunsetoffset': -30}
2021-06-07 18:00:29.157 Deconz: (Deconz) ### Update device (Deconz - Daylight) : {'nValue': 1, 'sValue': 'On'}, IGNORED , no changes !
2021-06-07 18:00:29.157 Deconz: (Deconz) ### Device > 2 Name:Multi Sensor Type:ZHATemperature Details:{'lastupdated': '2021-06-07T15:39:15.711', 'temperature': 2358} and {'battery': 100, 'offset': 0, 'on': True, 'reachable': True}
2021-06-07 18:00:29.158 Deconz: (Deconz) ### Update device (Temperature bathroom) : {'nValue': 0, 'sValue': '23.58', 'BatteryLevel': 100}, IGNORED , no changes !
2021-06-07 18:00:29.158 Deconz: (Deconz) ### Device > 3 Name:Humidity 3 Type:ZHAHumidity Details:{'humidity': 4547, 'lastupdated': '2021-06-07T15:39:15.723'} and {'battery': 100, 'offset': -3, 'on': True, 'reachable': True}
2021-06-07 18:00:29.158 Deconz: (Deconz) ### Update device (Humidity bathroom) : {'nValue': 45, 'sValue': '1', 'BatteryLevel': 100}, IGNORED , no changes !
2021-06-07 18:00:29.158 Deconz: (Deconz) ### Device > 4 Name:Pressure 4 Type:ZHAPressure Details:{'lastupdated': '2021-06-07T15:39:15.730', 'pressure': 1022} and {'battery': 100, 'on': True, 'reachable': True}
2021-06-07 18:00:29.159 Deconz: (Deconz) ### Update device (Deconz - Pressure 4) : {'nValue': 0, 'sValue': '1022;2', 'BatteryLevel': 100}, IGNORED , no changes !
2021-06-07 18:00:29.159 Deconz: (Deconz) ### Device > 8 Name:Dimmer Switch Type:ZHASwitch Details:{'buttonevent': 1002, 'eventduration': 1, 'lastupdated': '2021-06-07T16:00:23.868'} and {'battery': 67, 'group': '4', 'on': True, 'reachable': True}
2021-06-07 18:00:29.159 Deconz: (Deconz) ### Update device (Deconz - Dimmer Switch) : {'nValue': 0, 'sValue': 'Off', 'BatteryLevel': 67}, IGNORED , no changes !
2021-06-07 18:00:29.159 Deconz: (Deconz) ### Request groups
2021-06-07 18:00:29.159 Deconz: (Deconz) Send Command /api/C2A23BA324/groups/ with None (0 in buffer)
2021-06-07 18:00:29.159 Deconz: (Deconz) Making Request: http://127.0.0.1:80/api/C2A23BA324/groups/ with params None
2021-06-07 18:00:29.168 Deconz: (Deconz) Request Return: {"3":{"action":{"alert":"none","bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"d0a0b520b9fc3b40d3c774afb5625245","id":"3","lights":[],"name":"RWL021 7","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup","uniqueid":"00:17:88:01:02:0e:96:78"},"4":{"action":{"alert":"none","bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":true,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["8"],"etag":"88ec97327d95fb603de5ba23260286e7","id":"4","lights":[],"name":"RWL021 8","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup","uniqueid":"00:17:88:01:02:0e:96:78"}}
2021-06-07 18:00:29.168 Deconz: (Deconz) Classic Data : {'3': {'action': {'alert': 'none', 'bri': 127, 'colormode': 'hs', 'ct': 0, 'effect': 'none', 'hue': 0, 'on': False, 'sat': 127, 'scene': None, 'xy': [0, 0]}, 'devicemembership': [], 'etag': 'd0a0b520b9fc3b40d3c774afb5625245', 'id': '3', 'lights': [], 'name': 'RWL021 7', 'scenes': [], 'state': {'all_on': False, 'any_on': False}, 'type': 'LightGroup', 'uniqueid': '00:17:88:01:02:0e:96:78'}, '4': {'action': {'alert': 'none', 'bri': 127, 'colormode': 'hs', 'ct': 0, 'effect': 'none', 'hue': 0, 'on': True, 'sat': 127, 'scene': None, 'xy': [0, 0]}, 'devicemembership': ['8'], 'etag': '88ec97327d95fb603de5ba23260286e7', 'id': '4', 'lights': [], 'name': 'RWL021 8', 'scenes': [], 'state': {'all_on': False, 'any_on': False}, 'type': 'LightGroup', 'uniqueid': '00:17:88:01:02:0e:96:78'}}
2021-06-07 18:00:29.168 Deconz: (Deconz) ### Groupe > 3 Name:RWL021 7
2021-06-07 18:00:29.168 Deconz: (Deconz) ### Groupe > 4 Name:RWL021 8
2021-06-07 18:00:29.219 Deconz: (Deconz) onConnect called
2021-06-07 18:00:29.269 Deconz: (Deconz) onMessage called
2021-06-07 18:00:29.269 Deconz: (Deconz) WebSocket Handshake : HTTP/1.1 101 Switching Protocols ***Upgrade: websocket ***Connection: Upgrade ***Sec-WebSocket-Accept: V0htEbn5FhIA1xfQRyG3yU1aG9c= ***Server: deconz ***Access-Control-Allow-Credentials: false ***Access-Control-Allow-Methods: GET ***Access-Control-Allow-Headers: content-type ***Access-Control-Allow-Origin: http://127.0.0.1 ***Date: Mon, 07 Jun 2021 16:00:29 GMT *** ***
- Target OS: -
Can you show the logs when using long press ? I have used same value than on your link, so it s value during long press, not the release.The single presses are fine now but the long presses are still not recognized.
This is the full log of the long button press and release. i see first a 1000, then a 1001 and at last the expected 1003.
Hope you understand this behavior.
2021-06-07 19:30:45.529 Deconz: (Deconz) onMessage called
2021-06-07 19:30:45.530 Deconz: (Deconz) ### WebSocket Data : {'e': 'changed', 'id': '8', 'r': 'sensors', 'state': {'buttonevent': 1000, 'eventduration': 0, 'lastupdated': '2021-06-07T17:30:45.519'}, 't': 'event', 'uniqueid': '00:17:88:01:02:0e:96:78-02-fc00'}
2021-06-07 19:30:45.531 Deconz: (Deconz) ### Update device (Deconz - Dimmer Switch) : {'nValue': 0, 'sValue': 'Off'}, IGNORED , no changes !
2021-06-07 19:30:46.332 Deconz: (Deconz) onMessage called
2021-06-07 19:30:46.332 Deconz: (Deconz) ### WebSocket Data : {'e': 'changed', 'id': '8', 'r': 'sensors', 'state': {'buttonevent': 1001, 'eventduration': 8, 'lastupdated': '2021-06-07T17:30:46.319'}, 't': 'event', 'uniqueid': '00:17:88:01:02:0e:96:78-02-fc00'}
2021-06-07 19:30:46.333 Deconz: (Deconz) ### Update device (Deconz - Dimmer Switch) : {'nValue': 20, 'sValue': '20'}
2021-06-07 19:30:46.549 Deconz: (Deconz) onMessage called
2021-06-07 19:30:46.549 Deconz: (Deconz) ### WebSocket Data : {'e': 'changed', 'id': '8', 'r': 'sensors', 'state': {'buttonevent': 1003, 'eventduration': 10, 'lastupdated': '2021-06-07T17:30:46.520'}, 't': 'event', 'uniqueid': '00:17:88:01:02:0e:96:78-02-fc00'}
2021-06-07 19:30:46.550 Deconz: (Deconz) ### Update device (Deconz - Dimmer Switch) : {'nValue': 0, 'sValue': 'Off'}
2021-06-07 19:30:49.063 Deconz: (Deconz) onHeartbeat called
2021-06-07 19:30:49.064 Deconz: (Deconz) ### Update device (Deconz - Dimmer Switch) : {'nValue': 0, 'sValue': 'Off'}, IGNORED , no changes !
2021-06-07 19:30:59.052 Deconz: (Deconz) onHeartbeat called
- Target OS: -
So it have worked no ?
For short press button 1 you have 1002 > 10
For long press button 1 you have 1001 > 20
For long press button 2 you have 2001 > 40
For short press button 3 you have 3002 > 50
For long press button 3 you have 3001 > 60
first a 1000 > short press initial = ignored
then a 1001 > long press actualy pressed
and at last the expected 1003 > long press released ignored
If you prefer I can use the release event instead of the actualy pressed ? But the actualy pressed is better for script, for exemple a dimmer script.
For short press button 2 you have 2002 > 302021-06-07 19:30:46.332 Deconz: (Deconz) ### WebSocket Data : {'e': 'changed', 'id': '8', 'r': 'sensors', 'state': {'buttonevent': 1001, 'eventduration': 8, 'lastupdated': '2021-06-07T17:30:46.319'}, 't': 'event', 'uniqueid': '00:17:88:01:02:0e:96:78-02-fc00'}
No, its not working jet.
When i check the device data (domoticz/custom/deconz/Switch) i see the following: so only the X002 and X003 have a function
Long press:
"buttonevent": 1003,
"eventduration": 11,
"lastupdated": "2021-06-07T19:19:47.458"
Short press:
"eventduration": 0,
"lastupdated": "2021-06-07T19:20:19.997"
Long press:
2021-06-07 21:19:47.498 Deconz: (Deconz) ### WebSocket Data : {'e': 'changed', 'id': '8', 'r': 'sensors', 'state': {'buttonevent': 1003, 'eventduration': 11, 'lastupdated': '2021-06-07T19:19:47.458'}, 't': 'event', 'uniqueid': '00:17:88:01:02:0e:96:78-02-fc00'}
"eventduration": 0,
2021-06-07 21:20:20.017 Deconz: (Deconz) ### WebSocket Data : {'e': 'changed', 'id': '8', 'r': 'sensors', 'state': {'buttonevent': 1002, 'eventduration': 0, 'lastupdated': '2021-06-07T19:20:19.997'}, 't': 'event', 'uniqueid': '00:17:88:01:02:0e:96:78-02-fc00'}
So the X002 are for short press button and the X003 for the long press button
- Target OS: -
And if you take a look on the widget, on the "log" button ? you haven't value for long press ? Called L1, L2, ...
It's like you prefer, X001 if for long press and X003 for long press release.
Have updated the code to test with release, no need to re-include the device, just restart the plugin.
Hardware/deconz/update.
git pull
Hi Thorgal,
Thankyou very much! its working like a charm now. This is exactly the behavior I expected!
The remote is working in combination with dzvents and reacts almost 3 seconds faster than Hue(switch) > demoticz(script) > Hue(lamps) the last 1/2 seconds of the delay is probably still in domoticz > Hue(lamps). so thats the next job to do!
Enjoy your Coffee
- Target OS: -
Lol, thx for the coffe, so using release is better.
And Thx to you too, to help to correct the code, I think you was not the only one with this issue, and IDK what happen on code for this device ...
I m waiting for a return for a last change for siren device, and I will make the beta official in 1 week I think.
I tested now my SML001 devices (Philips hue Motion sensor first gen) the motion, tempature and Lux are working fine. So no rework on that.
I will contact you when I'm going to encounter unexpected behavior again
