Husqvarna has a REST API for integrations to their lawnmower. It would be really nice to have the lawnmover in Domoticz. Mainly to prevent the sprinkler system from popping up if the lawnmover isn't in the charging station. And also forcefully docking the lawnmover before irrigation.
https://developer.1689.cloud
Found one python implementation on github
https://github.com/chrisz/pyhusmow
Husqvarna Automower API
- mrhedstrom
- Domoticz version: 3.4834
- mrhedstrom
- FireWizard
Re: Husqvarna Automower API
Hi, @mrhedstrom,
As you might have seen, the repo of the Python plugin is no longer maintained.
If you look to this API you will see some examples, using NodeJS.
So I recommend to use Node Red and push it to Domoticz with MQTT,
There are plenty examples on this forum and on the Internet to install these two packages
However if you need support for these, do not hesitate to ask.
So, it is not recommended to use that plugin. Much easier is to use the official API.This repository is no longer maintained. Husqvarna provides an official api now, you can easily use it: https://developer.1689.cloud/apis/Automower+Connect+API
- Domoticz version: 2026.3
If the NodeJS/MQTT is too much work you could check the Python library created for the official API:
https://pypi.org/project/aioautomower/
So also with examples. You should be able to run the python script that is on that page. It should put your Automower in " Resume Schedule" state.
For getting the API code follow the instruction in the HA integration with the official API: https://github.com/Thomas55555/husqvarna_automower
Please let us now if you are able to get your Automower running.
payload = '{"data": {"type": "ResumeSchedule"}}'
## For more commands see: https://developer.husqvarnagroup.cloud/apis/Automower+Connect+API#/swagger
SendingCommand(api_key, access_token, provider, token_type, mower_id, payload)Please let us now if you are able to get your Automower running.
