Update after timer change
harrykausl
Domoticz version: 2021.1
Post by harrykausl »
After change of a timer it seems to be necessary, that domoticz is restarted. Could this be changed, that the timers work immediateley?
Domoticz version: 2026.3
Re: Update after timer change
How do you come to that conclusion? I do not think it is necessary.
The only thing there is that if you change a timer it needs a couple of minutes to implement. So if you test timers set a time in the future > 5 minutes from now else it could be skipped the first time.
harrykausl
I had problems with my timers, I changed one (deactivated it) and it dodn't work. Or I changed one, and onother didn't work. After searching in the forum, I read, that there should be a restart of domoticz. After I did this, it worked. I also described this in the thread Domoticz version 2021.1, released, page 12.
I will test too but I am not aware a reboot is necessary...
Are your devices were you had problems connected to a specific hardware/plugin?
Just tested on stable 2021.1.
I can change, enable, disable timers without having to reboot to get the changes being active.
Perhaps clear your browser cache? Because all these changes run with JavaScript from the browser and perhaps something goes wrong here. https://www.domoticz.com/wiki/Browser_Cache
harrykausl
They are connected via Z-wave. Now at the moment everything works. When I will change my timers, I will stop and restart domoticz. Thanks for your help.
