dashticz and docker
pvklink
Domoticz version: latest b
dashticz and docker
Post by pvklink »
Hi, i have all my components working with one compose file and dockerfiles
The dashticz part is below.After building an new image, i still get "there is a new version 3.8.2" when i execute the dashticz docker.
I thougt that by delete the old container and image and creating it again, this problem is solved.. but still getting it...
After execute the below procedure i have 3.8.0, and not 3.8.2
docker-compose.yml
 dashticz:
    container_name: dashticz
    build: /home/pi/pvkmenu/IOTstack/services/dashticz/.
    #context: .
    restart: always
    ports:
      - "80:80"
    volumes:
      - /etc/localtime:/etc/localtime:ro
      - type: bind
        source: /home/pi/pvkmenu/IOTstack/volumes/dashticz/
        target: /var/www/html/
dockerfile
FROM php:7.4-apache
ARG tz="Europe/Amsterdam"
RUN printf "[PHP]\ndate.timezone = $tz\n" > /usr/local/etc/php/conf.d/tzone.ini && \
mv "$PHP_INI_DIR/php.ini-production" "$PHP_INI_DIR/php.ini"
RUN apt update && apt install git -y
RUN echo "if [ ! -f /var/www/html/version.txt ]; then git clone --depth 1 --branch beta  https://github.com/Dashticz/dashticz /var/www/html; chmod -R a+rw /var/www/html/custom; chmod -R a+rw /var/www/html/img;fi; apache2-foreground" > /usr/bin/init.sh && chmod +x /usr/bin/init.sh
CMD ["/usr/bin/init.sh"]
SHELL ["/bin/bash", "-c"]
Jablotron connection, Ikea
Lokonli
Re: dashticz and docker
Post by Lokonli »
Dashticz is installed in the bind folder in /home/pi/pvkmenu/IOTstack/volumes/dashticz
If the file version.txt already exists, then Dashticz is not overwritten with a new version.
To update Dashticz there are two methods:
1)
Execute 'git pull' in the Dashticz folder (most easy)
2)
remove version.txt from the Dashticz folder, remove Dashticz Docker container and Docker image followed by docker_compose up
Note:
This is only applicable when using the docker-compose-yml and dockerfile from the previous post. The dockerfile used by the automatic install, which can be found on Github as well, works differently. In that case use git pull to update.
pvklink
Post by pvklink »
I tried method 1, the easiest
pi@raspberrypi:~/pvkmenu/IOTstack/volumes/dashticz $ git pull
error: cannot open .git/FETCH_HEAD: Toegang geweigerd
pi@raspberrypi:~/pvkmenu/IOTstack/volumes/dashticz $ sudo git pull
Updating e3c47f5..0c38431
error: Your local changes to the following files would be overwritten by merge:
dist/bundle.js
docs/blocks/specials/dial.rst
docs/blocks/specials/weather.rst
docs/dashticzconfiguration.rst
docs/releasenotes/releasenotes.rst
docs/screens.rst
index.html
index2.html
js/components/simpleblock.js
js/dashticz.js
js/dt_function.js
js/main.js
js/settings.js
lang/bs_BA.json
lang/ca_ES.json
lang/cs_CZ.json
lang/da_DK.json
lang/de_DE.json
lang/en_US.json
lang/es_ES.json
lang/fi_FI.json
lang/fr_FR.json
lang/hu_HU.json
lang/it_IT.json
lang/ja_JP.json
lang/lt_LT.json
lang/nb_NO.json
lang/nl_NL.json
lang/nn_NO.json
lang/pl_PL.json
lang/pt_PT.json
lang/ro_RO.json
lang/ru_RU.json
lang/sk_SK.json
lang/sl_SI.json
lang/sr_RS.json
lang/sv_SE.json
lang/tr_TR.json
lang/uk_UA.json
lang/zh_CN.json
package-lock.json
package.json
src/index.js
themes/white/white.css
version.txt
Please commit your changes or stash them before you merge.
Aborting
pvklink
Post by pvklink »
@update
i did a
- sudo git reset --hard
and then a
- sudo git pull
and now i have the latest version!
Is this the right way ? , or do i loose 'own' addons (custom folders, extra images like png/etc) with this approach ?
Lokonli
Post by Lokonli »
You will loose changed files, not new files I expect.
Verstuurd vanaf mijn AC2003 met Tapatalk
