WiFi, MQTT, html controller for ITHO ventilation box (new version)
Everything about esp8266 and more.
bwired
Post by bwired »
Hi Guys
Finally a full control solution for controlling the ITHO :-)
This is a new version date 1-2021
I have installed this ITHO Add-on for my ITHO home ventilator. Now able to fully control the ITHO vent :-)
This fits nicely onto your existing ITHO circuit and you don't need to solder anything.
It has an extra 868mhz transmitter and existing ITHO remotes are learned in by this add-on
This way you are in full control and can even see (or get an MQTT message) when somebody pushes the remote.
So controlling it via your home system and the remotes is fully possible now, also always the exact status.
Check the website where you can order the PCB for more details.
(i have no business with this product, just an end-user ;) )
https://www.tindie.com/products/19680/
https://github.com/arjenhiemstra/ithowifi
hendrikenrenny
Re: WiFi, MQTT, html controller for ITHO ventilation box (new version)
Post by hendrikenrenny »
Thanks! The add-on board works actually very good.
Has anybody already succeeded to write a script (dzvents/LUA/Blockly) to control the fan speed depending on the humidity of the ITHO sensor?
Can you please share this?
Hendrik
galadril
Domoticz version: latest
Post by galadril »
I''ve created a basic python plugin that creates a Ventilation device with Low/Medium/High selector options.
Its currently only to push new commands to the itho wifi module, not read the current state.. but please adjust if needed ;)
https://github.com/galadril/Domoticz-Itho-Wifi-Plugin
