write the program to the changing varants of a variable?
abdolhamednik
Domoticz version: 4.9700
Post by abdolhamednik »
Hi, I have a problem writing the program.thank you for your help,
I want to write a program that runs when a variable changes.
It is important to me that the program be run only when it changes.
Can I do this through command 'uservariablechanged' ?
How to use the a command ' uservariablechanged' ??
Thank for your guidance
psubiaco
Re: write the program to the changing varants of a variable?
Post by psubiaco »
Setup -> More options -> Events
click on + button
select LUA -> User variables
and you'll get a clean script template already made that will be called everytime a variable changes.
Regards.
Paolo
Paolo
psubiaco wrote: Saturday 15 May 2021 10:00 and you'll get a clean script template already made that will be called everytime a variable changes.
That is not completely true. This will be called every time a variable is updated, regardless if the value changed or not.
If you need that functionality you will have to compare the new value against the last value (you will have to store that somewhere e.g. dzVenst persistent storage or another variable)
abdolhamednik
Hello, thank you for your guidance..
Is it possible to write a program for me as a small example?
I want a program that turns on the lights when a variable called Smart changes.
Example:
commandArray ={}
   smart=tonumber(uservariables['smart'])
    if smart ==1 then
        commandArray['light']='On'
           if smart==0 then
                 commandArray['light']='Off'
please edit lines 4 and 7 for me.
I do not know how to use the a 'uservariablechanged' command.
thank you for your help.
abdolhamednik wrote: Saturday 15 May 2021 13:05 Is it possible to write a program for me as a small example? I want a program that turns on the lights when a variable called Smart changes.
This example will do something every time the uservariable is updated.
commandArray ={}
   if uservariablechanged['smart'] then
        smart = tonumber(uservariablechanged['smart']) or 99
        if smart == 1 then
            commandArray['light'] = 'On'
        elseif smart == 0 then
            commandArray['light'] = 'Off'
            print ('smart is neither 0 nor 1, but ' .. uservariablechanged['smart'] )
And this exampple will only do something when the value of smart changed but requires an extra variable of the same type called "smart_lastValue"
commandArray ={}
   if uservariablechanged['smart'] and ( uservariables['smart_lastValue'] ~= uservariablechanged['smart']) then
        commandArray['Variable:smart_lastValue'] = uservariablechanged['smart']
        if smart == 1 then
abdolhamednik
Hi thank you very much for your help.
I copied both programs you wrote but is gives the error :
2021-05-16 08:31:34.738 Error: EventSystem: in NEW1: [string "--[[commandArray = {}..."]:37: attempt to index a nil value (global 'uservariablechanged')
smart is also available in uservariables, but I don't know where problem is.
thank you for helping me.
abdolhamednik
Both programs are adjunct when they're on the all option.
But when they are on option ,uservariable, they don,t habe rrror, but in this case it doesn't run, that means the light don't go off or on whit smart changes.
abdolhamednik wrote: Sunday 16 May 2021 6:14 2021-05-16 08:31:34.738 Error: EventSystem: in NEW1: [string "--[[commandArray = {}..."]:37: attempt to index a nil value (global 'uservariablechanged')
You should save it with trigger User variable and you should have added a uservar with name smart_lastValue and same type as uservar smart.
abdolhamednik
I'll put the smart program and the light on here.
I'd appreciate it if you told me exactly the flaw in the program or edited the program for me.
smart program(Device):
commandArray ={}
smart = tonumber(uservariables['smart'])
if devicechanged['auto/man']=='Open' then
commandArray['Variable:smart']='1'
if devicechanged['auto/man']=='Closed' then
commandArray['Variable:smart']='0'
program light(uservariable):
commandArray ={}
if smart == 1 then
variable smart also exists in uservariables.
But the light doesn't go off or on white smart changes.
abdolhamednik wrote: Sunday 16 May 2021 9:03 I'll put the smart program and the light on here.
Have you added the domotizc uservariable smart_lastValue with the same type as smart? If not please do now.
Please show what you see in the log with below version saved as triggered User variable and after updating the uservariable smart with 0 or 1.
-- Added some extra checks and debug printlines.
commandArray ={}
    if uservariablechanged then
        if uservariables['smart_lastValue'] then
                print ('DEBUG - Uservar:  ' .. 'smart value changed'  )
                if smart == 1 then
                    print ('DEBUG - Uservar:  ' .. 'Switching light On'  )
                    print ('DEBUG - Uservar:  ' .. 'Switching light Off'  )
                    print ('DEBUG - Uservar:  ' .. 'smart is neither 0 nor 1, but ' .. uservariablechanged['smart']  )
            elseif uservariablechanged['smart'] then
                print ('DEBUG - Uservar:  ' .. 'smart updated but value did not change'  )
                print ('DEBUG - Uservar:  ' .. 'smart not updated'  )
            print ('DEBUG - Uservar:  ' .. 'smart_lastValue does not exist.'  )
        print ('DEBUG - Uservar:  ' .. 'Not triggered by a uservariable'  )
abdolhamednik
Hi there,your friend
Thank you greatly for your help and guidance.
I edited the program you sent yesterday a little bit and it was kind of right.
I'll out the program here and continue the description.
program:
commandArray ={}
    print('hello....')
                print ('DEBUG!!!!! - Uservar:  ' .. 'smart value changed'  )
                if smart == 1 then
                    print ('DEBUG!!!!! - Uservar:  ' .. 'Switching light On'  )
                    print ('DEBUG!!!!! - Uservar:  ' .. 'Switching light Off'  )
                    print ('DEBUG!!!!! - Uservar:  ' .. 'smart is neither 0 nor 1, but ' .. uservariablechanged['smart']  )
                print ('DEBUG!!!!! - Uservar:  ' .. 'smart updated but value did not change'  )
                print ('DEBUG!!!!! - Uservar:  ' .. 'smart not updated'  )
            print ('DEBUG!!!!!! - Uservar:  ' .. 'smart_lastValue does not exist.'  )
        print ('DEBUG!!!!! - Uservar:  ' .. 'Not triggered by a uservariable'  )
The smart variable in the above program changes between a zero number or one in another program under certain conditions.
I'll put the program that changes 'smart' :
(Devaice)
    commandArray['Variable:smart']='On'
         commandArray['Variable:smart']='Off'
Now the program you wrote is wrong when it changes that second smart program the program you wrote will not be executed.
But when I manually change the smart variable in the 'uservariables' the program works properly and the lights turn on or off.
Now I have a few questions:
1-what is reason for this problem?
2-what's the reason you used variable 'smart_value' ?
I apologize for taking your time..
If you edite the program for me and send it to me,I'll be very grateful.
Thanks Faravan.
abdolhamednik wrote: Monday 17 May 2021 6:59 Now the program you wrote is wrong when it changes that second smart program the program you wrote will not be executed.
Probably a language thing but I tested the script and it behaves as expected, so definitely not wrong.
Reasons;
  • When you set a domoticz uservariable from a classic Lua script or Blockly it will not trigger an event.
    You will have to change the uservar manually, or via a JSON call or use a dzVents script to do that.
  • You set the value of the smart uservarable to 'On' or 'Off' but test if it's 0 or 1
I used the uservariable smart_lastValue to keep track of the previous value of smart to ensure that the script only switches the light when the value of smart changed and not when smart is updated but the value is kept unchanged.
I also have some questions for you.
  • I asked a couple of times for the output of the log to help me understanding what happens but you ignore this question. Why?
  • Your profile states that you use V4.9700 is that stil accurate?
abdolhamednik
Hello, thank you for your help.
I will test the program again and send you the log report
System log for when I manually change Smart:
when smart=1 :
2021-05-17 15:49:50.156 (GSB) Light/Switch (light)
2021-05-17 15:49:50.088 Status: LUA: hello....
2021-05-17 15:49:50.104 Status: LUA: DEBUG!!!!! - Uservar: smart value changed
2021-05-17 15:49:50.105 Status: LUA: DEBUG!!!!! - Uservar: Switching light On
2021-05-17 15:49:50.117 Status: EventSystem: Script event triggered: Script #2
when smart=0 :
2021-05-17 15:51:44.132 (GSB) Light/Switch (light)
2021-05-17 15:51:44.013 Status: LUA: hello....
2021-05-17 15:51:44.027 Status: LUA: DEBUG!!!!! - Uservar: smart value changed
2021-05-17 15:51:44.030 Status: LUA: DEBUG!!!!! - Uservar: Switching light Off
2021-05-17 15:51:44.037 Status: EventSystem: Script event triggered: Script #2
smart and smart_value Available in uservariables.
abdolhamednik
Log for when Smart is changed by Event:
when smart=1 :
2021-05-17 15:57:11.870 (GSB) Light/Switch (R9(1.44)<3-3>[66]**)
2021-05-17 15:57:11.831 Status: User: unity-tech (IP: 192.168.1.80) initiated a switch command (66/R9(1.44)<3-3>[66]**/On)
2021-05-17 15:57:12.565 Status: LUA: smart=1 chon kelid tablo hooshmand shod_sistem hooshmand amade be kar hast
2021-05-17 15:57:12.569 Status: EventSystem: Script event triggered: smart_hadi_new
when smart=0
2021-05-17 15:57:58.342 Status: User: unity-tech (IP: 192.168.1.80) initiated a switch command (66/R9(1.44)<3-3>[66]**/Off)
2021-05-17 15:57:58.784 Status: LUA: smart=0 chon kelid tablo dasti shod
2021-05-17 15:57:58.797 Status: EventSystem: Script event triggered: smart_hadi_new
Thank you very much for your kindness.
abdolhamednik wrote: Monday 17 May 2021 13:24 smart and smart_value Available in uservariables.
Do you mean smart_lastValue?
but despite that; script works as expected
abdolhamednik wrote: Monday 17 May 2021 13:33 Log for when Smart is changed by Event:
Again: uservariables updated by a Lua script or Blockly do not trigger an event.
Do not enter your personal details here. They can be misused and I do not give other support then via the public part of this forum with an exception if any personal data need to be shared.
