Add option to set loglevels on Scheduled item
keros
Post by keros »
In running DomoticZ on latest stable 2021.1. Since this version, we have the opportunity to set the loglevel par hardware device. This is awesome.
I use dummy devices with a planning and each time the device change, I have a line in the log :
2021-05-15 11:31:01.596 Status: Schedule item started! Name: Horloge A, Type: On Time, DevID: 1, Time: 2021-05-15 11:31:01
I disabled all the log (info, status et error) for the corresponding Dummy hardware, but I still have the status line.
I tried on a new DomoticZ installation (with beta last update Domoticz V2021.1 build 13256).
This is my configuration :
  • 2 dummy hardwares : Dummy A with all loglevel set ON and Dummy B with all loglevel set OFF.
  • 2 virtual devices Horloge A crated from Dummy A and Horloge B crated from Dummy B with exactly the same planing
I expected not to have any log for Horloge B. This is what I got :
Sans titre.png (127.13 KiB) Viewed 930 times
The info log of Horloge B is not showed, that's good, but I still got the status log for Horloge B.
Is it a bug or is there a configuration to turn it off ?
Moderator on Easydomoticz.com, the French DomoticZ forum.
French writer for ZigBeeForDomoticZ Plugin Wiki
Re: Set loglevel on Schedule item doesn't work
keros wrote: Saturday 15 May 2021 11:48 The info log of Horloge B is not showed, that's good, but I still got the status log for Horloge B.
The Status Schedule message you see does not come from the Hardware but from the Scheduler. You cannot prevent individual status messages from this domoticz subsystem but you can prevent all status messages to the log by modifying /etc/init.d/domoticz.sh by editing this file
Change line
DAEMON_ARGS="$DAEMON_ARGS -loglevel  normal,status,error"
to
DAEMON_ARGS="$DAEMON_ARGS -loglevel  error"
This will prevent status or normal messages to show up in the domoticz log.
and do
sudo systemctl daemon-reload
sudo service domoticz restart
keros
Post by keros »
Thank you very much Waaren for the reply and the explanations.
I just wanted to turn off the status log on the scheduled device. For that I moved them to a specific hardware.
I can't turn off the statud log in /etc/init.d/domoticz.sh otherwise I won't have the status log for the other devices and scripts.
The log line indicates Status. I hopped it could be disable with the new function.
Do you think if this could be an issue oppened on GitHub ?
keros wrote: Saturday 15 May 2021 14:49 Do you think if this could be an issue oppened on GitHub ?
No. It is not is a code bug or similar issue.
keros
Post by keros »
Ok, so no improvement possible :(
keros wrote: Saturday 15 May 2021 17:34 Ok, so no improvement possible :(
That is not what I wrote. If you have a suggestion for a modification you should post it in the suggestion subforum If a developer agree that it would be an improvement and is willing to spend time on it, she / he might pick it up and work on it.
The domoticz github issue list is meant for domoticz code bugs only
keros
Post by keros »
Sorry for my misunderstanding. I was right to demand on the forum instead of asking directly in the domoticz github issue :)
Do I create a new post or a moderator can move this topic in the suggestion forum ?
[EDIT (waaren)] moved to suggestions and changed topic subject
keros
Re: Add option to set loglevels on Scheduled item
Post by keros »
Thank you Waaren.
