i cant get the rule working
when i put the code in my browser i get a value to domotics
this is my rule
ive tested to posibilities with , and :
and when i look into my log i see this
and in domoticz i received nothing the value 11 is set by using the url in my browser
191 multipzem2 82191 1 multipzem21 Usage Electric 1 Watt - - 2021-05-10 11:26:25
192 multipzem2 82192 1 multipzem22 Usage Electric 0 Watt - - 2021-05-10 10:54:15
193 multipzem2 82193 1 multipzem23 Usage Electric 0 Watt 5 - 2021-05-10 07:43:28
194 multipzem2 82194 1 pzemmulti21 Usage Electric 0 Watt 5 -
Pzem04t valueus splitting
- Domoticz version: 2026.3
Re: Pzem04t valueus splitting
Please report this on the ESPEasy forum as it is a ESPEasy issue.
If I check the doc https://espeasy.readthedocs.io/en/lates ... Rules.html
I see
I see
SendToHTTP
To send a message to another device, like a command to switch on a light to Domoticz
On System#Boot do //When the ESP boots, do
timerSet,1,10 //Set Timer 1 for the next event in 10 seconds
endon
On Rules#Timer=1 do //When Timer1 expires, do
SendToHTTP 192.168.0.243,8080,/json.htm?type=command¶m=switchlight&idx=174&switchcmd=On
endon
Many users have reported problems with commands being truncated, particularly when trying to send commands to Domoticz. It seems to be a parsing error. There is the following workaround:
SendToHTTP 192.168.0.243,8080,/json.htm?type=param=switchlight&command&idx=174&switchcmd=On
spike318
https://sites.google.com/view/spikeauto ... h-esp-easy
After af few time i found out how to split the value's id did it in Node red
Everyting you need you find on my site
