Hi!
I am trying to control my garage port with an Arduino. I have a Domoticz windows server running controlling all lights and sensors in my house and I want to add my garage port to the system, the gate works like if it gets a puls it opens/closes and if it gets another pulse while opening/closing it stops, then goes the reversed way. I have a Relay to control the pulse but how do I "connect" it to domoticz?
Thanks beforehand!
Best regards Max
Control a garage port with Arduino via Domoticz Topic is solved
- Domoticz version: 2024.7
Re: Control a garage port with Arduino via Domoticz
What kind of wireless gateways to Domoticz do you have? Because that save you some money to buy a new gateway. Wifi is off course 1 of the possibility but there is also zigbee, zwave, RF etc.
You need Arduino with Ethernet shield + Relay or more simple would be to buy ESP8266 and connect relay (on ESP8266 install espeasy firmware with works perfectly with Domoticz.
- Domoticz version: 2021.1
I have a Arduino D1 Mini Pro (based on ESP-8266EX) and a relay
If it is compatible with ESPEASY you have a domoticz interface with that.
Ok, I will give it a try! Wish me good luck
I just got it working! I had to wait for the arduino. It was easy to setup and works flawless. Thanks for the help!
Good to hear! What was your method you used, with Espeasy?
How to do that without espeasy? Because i have on this esp32 another sensors etc. reporting to domoticz and i want to drive relay with the same esp32 through domoticz.
