Harmony support, new hardware?
Yihaaa
Re: Harmony support, new hardware?
Post by Yihaaa »
Confirmed. I am also still using the old method. It just works and I see no need to move to the new method.
markk
Post by markk »
I'm running Domoticz on windows so I don't think I can use the old method :(.
Might be time to install Domoticz on a Pi!
gb160
Post by gb160 »
Yihaaa wrote:Confirmed. I am also still using the old method. It just works and I see no need to move to the new method.
The old method is perfectly reliable but lacks the functionality to update domoticz if activity changes are initiated via the harmony remote.its not a big deal but it's a nice function.
In the old harmony thread someone posted a script which gives this functionality however the script has to run on a loop so can increase the load on the pi quite significantly, depending in the frequency of the loop.
It works, but it's not perfect.
gizmocuz
Post by gizmocuz »
make sure you enabled 'accept new hardware devices' before adding the harmony, or enabled it, disable/enable the harmony hardware.
Just added a new activity some days ago, forgot about it in domoticz, checked just now, and its already there
gb160
Post by gb160 »
gizmocuz wrote:make sure you enabled 'accept new hardware devices' before adding the harmony, or enabled it, disable/enable the harmony hardware.
Many thanks for your hard work (and @codeitaway) and this tip in particular....as a beginner of all things Domoticz i had no idea this option even existed!
So far good news, my harmony activities are successfully added, the log no longer gets filled with errors, one slight issue from my end:
I can switch between activities ok, but can't power off....
Is there anything i need to do or should this be automatic ?
Im running 2096 on a Pi.
markk
Post by markk »
@gizmocuz, you are an absolute genius :D
I disabled the "accept new hardware" last week because I kept picking up loads of byron SX devises :oops:
All working perfectly again now ;)
gb160
Post by gb160 »
Hi..im getting errors when using the native support...causing my hub to lock up completely, i can only use the hub again after restarting domoticz, when this occurs i can't even use my harmony remote.
The issue is similar to the original problems on the pi....
My log shows...
2014-12-07 10:07:57 Harmony Hub: Too many commands missed. Resetting connection.
2014-12-07 10:08:00 Hardware Monitor: Fetching data (System sensors)
2014-12-07 10:08:04 Harmony Hub: Authentication succesfull
2014-12-07 10:08:30 Hardware Monitor: Fetching data (System sensors)
2014-12-07 10:08:32 Harmony Hub: Too many commands missed. Resetting connection.
2014-12-07 10:09:00 Error: Harmony Hub hardware (14) thread seems to have ended unexpectedly
2014-12-07 10:09:00 Hardware Monitor: Fetching data (System sensors)
2014-12-07 10:09:27 Harmony Hub: Authentication succesfull
2014-12-07 10:09:30 Hardware Monitor: Fetching data (System sensors)
2014-12-07 10:09:33 Harmony Hub: Too many commands missed. Resetting connection.
2014-12-07 10:10:00 Error: Harmony Hub hardware (14) thread seems to have ended unexpectedly
2014-12-07 10:10:00 Hardware Monitor: Fetching data (System sensors)
2014-12-07 10:10:27 Harmony Hub: Authentication succesfull
2014-12-07 10:10:30 Hardware Monitor: Fetching data (System sensors)
2014-12-07 10:10:33 Harmony Hub: Too many commands missed. Resetting connection.
2014-12-07 10:10:54 Incoming connection from: 192.168.1.42
2014-12-07 10:11:00 Hardware Monitor: Fetching data (System sensors)
2014-12-07 10:11:00 Error: Harmony Hub hardware (14) thread seems to have ended unexpectedly
I haven't changed my harmony hub configuration recently in any way.
It can happen three or four times in a day, or can sometimes go a few days without happening at all.
@CodeItAway any ideas what could be causing this ? its an excellent feature but I've had to disable it because of this problem.
Im running v2.2145 on a Pi.
gb160
Post by gb160 »
Anyone else experiencing this?
id love to have my native harmony control back :(
markk
Post by markk »
I'm getting the following message: "Logitech web service login failed"
I can't be sure but it seems to have been since I flashed my RFX433 to FW v81. Was working perfectly beforehand.
Anyone else experiencing the same or can offer and explanation/advice please?
mbtr
Domoticz version: 2.3817
Post by mbtr »
It's still working for me, even after installing beta build 2.2187. I haven't flashed (new) RFXCom firmware but I don't believe the RFXCom is reponsible for communication (it's through web services). Make sure the password is correct, 'Login failed' suggests that's where the problem is.
Controllers: Raspberry Pi 2B - RFXTrx433E - Aeon ZStick Gen5
Target devices: Fibaro RGBW - Philips Hue - Logitech Harmony - Google Nest
Triggers: Fibaro Motion Sensors - Fibaro Wall Plugs - KaKu Motion Sensors - KaKu Switches - Byron doorbell
markk
Post by markk »
Thanks for your reply. The password is definately correct. I'm stumped.
Yihaaa
Post by Yihaaa »
Pull out all electricity cables etc and make a fresh start up?
markk
Post by markk »
Do you mean on the Harmony Hub? I've rebooted that, still the same. I thought the IP of the hub may have changed but that is still the same too.
markk
Post by markk »
How odd. As a last resort I downgraded my RFXCom firmware back to FW v71, rebooted everything and the Harmony Hub authenticated and logged in perfectly straight away.
Mooky
Post by Mooky »
I have domoticz 2187 + pi + harmony hub + RFX v69.
Login OK, activities show up and turn on OK.
But turning off doesnt't work also for me.
markk
Post by markk »
Mooky wrote:I have domoticz 2187 + pi + harmony hub + RFX v69.
I got round this by adding "all off" as an activity on the Harmony hub. This then appears in your devices and can be added to Domoticz to turn everything off when pressed.
Mooky
Post by Mooky »
Thanks for the advice, I'll try that when I get home.
But isn't that why the "Harmony Off" device (automatically created) is made for ?
Maybe I chose the wrong type, I set it up as a "Push Off button". Is that correct ?
markk
Post by markk »
Use that one and set it up as a push on button. That should work.
Mooky
Post by Mooky »
markk wrote:Use that one and set it up as a push on button. That should work.
Yay it works !
Thank you very much
pipari
Post by pipari »
Hi Guys!
Ordered the Logitech Harmony Ultimate yeasterday and got some questions.. hope someone have the answers!
Is it possible to turn off / on switches in domoticz with the remote (through the harmony hub)?
Anyone that could take som screenshoots or maybe a video? is trying to do as much as possible before the device is at my door!
Best regards
