I a using a virtual switch (rgb) to be able to 'capture' the commands sent from the gui to that switch and then relay them onto my actual device. This device is not fully supported, hence the workaround.
Now when I perform a set color on the virtual switch, i see it is correctly shown in the log (Status: setcolbrightnessvalue: ID: 20, bri: 100, color: '{m: 3, RGB: ff0eff, CWWW: 0000, CT: 0}')
So my green should be 0e = 14, but the device.color or device.getColor() it returns the value it had before changing the color.: 169
How can I use / retrieve the actual latest sent rgb values for setcolbrightnessvalue in the lua script?
2021-04-30 14:46:16.193 Status: setcolbrightnessvalue: ID: 20, bri: 100, color: '{m: 3, RGB: ff0eff, CWWW: 0000, CT: 0}'
2021-04-30 14:46:16.205 LED strip dummy: Color Switch (LED muurcirkel)
2021-04-30 14:46:16.310 Status: dzVents: Info: Handling events for: "LED muurcirkel", value: "Set Color"
2021-04-30 14:46:16.310 Status: dzVents: Info: sendColor: ------ Start external script: set_ledstrip_color.lua: Device: "LED muurcirkel (LED strip dummy)", Index: 32
2021-04-30 14:46:16.311 Status: dzVents: Debug: sendColor: original color : {"b":255,"cw":0,"g":169,"m":3,"r":255,"t":0,"ww":0}
2021-04-30 14:46:16.311 Status: dzVents: Debug: sendColor: {["g"]=169, ["red"]=255, ["warm white"]=0, ["temperature"]=0, ["r"]=255, ["cold white"]=0, ["m"]=3, ["isWhite"]=false, ["hue"]=300.0, ["mode"]=3, ["value"]=100.0, ["t"]=0, ["brightness"]=100.0, ["b"]=255, ["br"]=100, ["green"]=169, ["ww"]=0, ["blue"]=255, ["cw"]=0, ["saturation"]=33.725490196078}Maureen
