Konnected.io
doh
Konnected.io
Post by doh »
I've just seen this and it looks great - turns your existing/traditional hard-wired alarm system into something WiFi connected that can be integrated into a home automation setup.
It works with Smartthings and Home Assistant.
Has anyone tried hooking this up to Domoticz?
Sent from my SM-T820 using Tapatalk
doh
Re: Konnected.io
Post by doh »
So, I've been doing further research into this.
Konnected has a python library that can be used to query the alarm system and to trigger the siren.
It is possible to set the Konnected to trigger an HTTP PUT with a JSON payload to a specific URL. It seems that Domoticz ignores the payload but does respond to the HTTP PUT request, so my thinking is:
  • Create a dummy scene and individual sensor virtual switches (as motion sensors) in domoticz
  • Program the Konnected to trigger the scene when movement is detected, by telling it the scene URL to call
  • On activation of that scene have a domoticz script call the python library to query the true state of each sensor
  • If alarm is set, etc. and a sensor is triggered, then use the python library to sound the alarm, send me an alert, etc.
Does this sound reasonable? Is there a better way of doing this?
nigels0
Domoticz version: 3.8153
Re: Konnected.io
Post by nigels0 »
This topic is old now, but I wonder if anyone has interfaced the connection kit with Domoticz yet?
Domoticz version: 2026.3
Re: Konnected.io
There is now also a MQTT interface for Konnected, perhaps that will give some options: https://help.konnected.io/support/solut ... -with-mqtt
nigels0
Re: Konnected.io
Post by nigels0 »
I didn’t see that…
Would this plug-in then be the best route?:
https://github.com/emontnemery/domoticz_mqtt_discovery
Edit: actually not as it doesn’t handle sensors yet.
Re: Konnected.io
It could be a base for a konnected_mqtt plugin.
Perhaps also Nod eRed could help. But on both issues I am no expert
See https://www.domoticz.com/wiki/MQTT for more info, also on NodeRed conversions
Also there is a Node Red subforum
