recent Domoticz.Configuration() API problem
pipiche
Post by pipiche »
I have an issue with the recent added Domoticz.Configuration API in the Python Framework
from the doc: https://www.domoticz.com/wiki/Developin ... hon_plugin, the correct value type are dictionary. However it looks like the API doesn't survive to a Dictionary with a key equal to None !
Here is a piece of code to duplicate:
config_item = { '_count': self.count , 'None_Value': None}
Domoticz.Log("config_item: %s" %str(config_item))
Domoticz.Log("Json config_item: %s" %json.dumps(config_item ))
setConfigItem( Value=config_item)
pipiche
Re: recent Domoticz.Configuration() API problem
Post by pipiche »
For those whom might get to that issue ( having a dict with None value ), I have made a workaround by converting the None to Null when saving and from Null to None when retrieving.
I think the best would be to have Domoticz.Configuration() capable to store JSON datatype instead of dict, this will make the code in Domoticz simpler and rely on JSON Encoder/decoder
def prepare_dict_for_storage( dict_items):
    Domoticz.Log("prepare_dict_for_storage")
    dict_str = json.dumps( dict_items )
    return json.loads( dict_str, object_pairs_hook=dict_None_to_Null )
def repair_dict_after_load( dict_items):
    return  json.loads( dict_str, object_pairs_hook=dict_Null_to_None)
def dict_None_to_Null( items ):
    result = {}
    for key, value in items:
        if value is None:
            Domoticz.Log("Updating %s: %s to %s:'Null'" %(key,value, key))
            value = "Null"
        result[key] = value
    return result
def dict_Null_to_None( items ):
    result = {}
        if value == "Null":
            value = None
        result[key] = value
    return result
pipiche
Post by pipiche »
for information, I found an other limitation, which is that the new API doesn't work nicely with the full Dict type. for instance if you have any value inside your dictionary set to None, then it will be rejected !!!
