get a counter value of a specific date Topic is solved
steef27
Hi guys,
I need your help.
I would like to retrieve the gas usage over the past 365 days or the position of the gas meter on a specific date.
With the url below I get the counter values of each (!) day.
/json.htm?type=graph&sensor=counter&idx=IDX&range=year
Is it possible to insert a date parameter?
gtz
I need your help.
gtz
- waaren
Re: get a counter value of a specific date
This is not possible in the API call itself but quite easy to get it with dzVents. How do you want to use this ?steef27 wrote: Monday 02 December 2019 15:51 I would like to retrieve the gas usage over the past 365 days or the position of the gas meter on a specific date.
steef27
I want to calculate the annual usage by comparing the current position with the position 365 days ago. Every day.
- waaren
Can you try this one ?steef27 wrote: Monday 09 December 2019 9:26 I want to calculate the annual usage by comparing the current position with the position 365 days ago. Every day.
this dzVents script collects the current energy return / usage and gas usage to enable comparing with Same date last year figure
local scriptVar = 'gasHistory'
return
on =
timer = { 'every 5 minutes' },
httpResponses = { scriptVar },
logging = { level = domoticz.LOG_DEBUG },
execute = function(dz, item)
-- ***** Your settings below this line
local gas = dz.devices('Gas') -- change to name of your gasMeter between quotes or id without quotes
local gasText = dz.devices('gasText') -- text device showing gas Consumption
-- ***** No changes required below this line
_G.logMarker = _G.moduleLabel
local day = 86400 -- (24 * 60 * 60)
local function callYearGraph(id)
url = dz.settings['Domoticz url'] .. '/json.htm?type=graph&sensor=counter&range=year&idx=' .. id
dz.openURL({ url = url, callback = scriptVar })
local function daysInLastYear()
local lastYear = os.time{day = dz.time.day, year = dz.time.year - 1, month = dz.time.month}
return math.floor(os.difftime(os.time(), lastYear) / day )
local function processResult(t)
local gastToday,gasLastYear, gasNow, gasYear = 0, 0, 0 ,0
local dateFmt = "%Y-%m-%d"
local today = os.date(dateFmt,os.time())
local yesterday = os.date(dateFmt,os.time() - day)
local sameDayLastYear = os.date(dateFmt,os.time() - daysInLastYear() * day)
for index, gas in ipairs(t) do
if gas.d == today then gasToday = gas.v gasNow = gas.c
elseif gas.d == yesterday then gasYesterDay = gas.v
elseif gas.d == sameDayLastYear then gasLastYear = gas.v gasYear = gas.c
dz.log('gasToday: ' .. gasToday .. ' M³',LOG_DEBUG)
dz.log('gasYesterDay: ' .. gasYesterDay .. ' M³',LOG_DEBUG)
dz.log('gasLastYear: ' .. gasLastYear .. ' M³',LOG_DEBUG)
dz.log('gasYearConsumption: ' .. (gasNow - gasYear) .. ' M³',LOG_DEBUG)
return gasToday, gasYesterDay, gasLastYear, (gasNow - gasYear)
local function updateTextSensor(gasToday, gasYesterDay, gasLastYear, gasTotal)
gasText.updateText
( 'Gas used today: ' .. gasToday .. ' M³ \n' ..
'Gas used yesterday: ' .. gasYesterDay .. ' M³ \n' ..
'Gas used same day last Year: ' .. gasLastYear .. ' M³ \n' ..
'Gas used in last ' .. daysInLastYear() .. ' days: ' .. gasTotal .. ' M³'
-- main
if item.isHTTPResponse and item.isJSON then
updateTextSensor(processResult(item.json.result))
elseif item.isTimer then
callYearGraph(gas.id)
dz.log('Error while retrieving gas data. Result is ' .. item.statusText ..' ; Response is: ' .. item.data,LOG_ERROR)
}Debian buster, bullseye on RPI-4, Intel NUC.
- MadMedic
- Domoticz version: 2020.2
Hey Waaren, perfect dz vents script...
can I alter this for Energy (Power) consumption too ? Since power has 4 or 6 different values,
instead of gas which has only one, as far as I know
please let me know
"Life is too short for bad coffee"
- waaren
Should be possible to do that but you will have to decide what you want to compare. Below you see the result for one day.MadMedic wrote: Thursday 19 December 2019 16:36 can I alter this for Energy (Power) consumption too ? Since power has 4 or 6 different values,
v + v2 is usage , r1 + r2 is return
"c1" : "6560.563",
"c2" : "2941.709",
"c3" : "4764.800",
"c4" : "6741.620",
"d" : "2018-12-19",
"r1" : "0.000",
"r2" : "0.531",
"v" : "3.964",
"v2" : "12.504"
steef27
thanks, this is perfect!
steef27
Can I also use multiple custom sensors instead of 1 text sensor with all values?
- waaren
Please provide some more detail on what you mean / want.steef27 wrote: Monday 27 January 2020 11:11 Can I also use multiple custom sensors instead of 1 text sensor with all values?
steef27
Instead of using one single textsensor, i would like to store each value in a separate custom sensor.
I would like to split the text values.
- waaren
That should probably be not too hard. If you share what you have now I can help.steef27 wrote: Monday 03 February 2020 11:28 Instead of using one single textsensor, i would like to store each value in a separate custom sensor.
steef27
return
on =
--devices = { 4484, },
--logging = { level = domoticz.LOG_DEBUG },
local gas = dz.devices(4484) -- change to name of your gasMeter between quotes or id without quotes
local gasText2 = dz.devices(4746)
local gasText3 = dz.devices(4747)
local gasText4 = dz.devices(4748)
local gasText5 = dz.devices(4749)
local gasToday,gasLastYear, gasNow, gasYear = 0, 0, 0 ,0
--dz.log('gasToday: ' .. gasToday .. ' M³',LOG_DEBUG)
--dz.log('gasYesterDay: ' .. gasYesterDay .. ' M³',LOG_DEBUG)
--dz.log('gasLastYear: ' .. gasLastYear .. ' M³',LOG_DEBUG)
--dz.log('gasYearConsumption: ' .. (gasNow - gasYear) .. ' M³',LOG_DEBUG)
-- [[Aanpassing zodat verbuik vandaag ook wordt meegerekend ]]
--return gasToday, gasYesterDay, gasLastYear, (gasNow - gasYear)
return gasToday, gasYesterDay, gasLastYear, (gasNow - gasYear + gasToday)
-- local function updateTextSensor(gasToday, gasYesterDay, gasLastYear, gasTotal)
-- gasText.updateText
-- ( 'Gas used today: ' .. gasToday .. ' M³ \n' ..
-- 'Gas used yesterday: ' .. gasYesterDay .. ' M³ \n' ..
-- 'Gas used same day last Year: ' .. gasLastYear .. ' M³ \n' ..
-- 'Gas used in last ' .. daysInLastYear() .. ' days: ' .. gasTotal .. ' M³'
-- end
--gasText2.updateText('Gas used in last ' .. daysInLastYear() .. ' days: ' .. gasTotal .. ' M³')
gasText2.updateCustomSensor(gasToday)
gasText3.updateCustomSensor(gasYesterDay)
gasText4.updateCustomSensor(gasLastYear)
gasText5.updateCustomSensor(gasTotal)
-- main
- waaren
can you try this ?
return
on =
local gasTable = {}
gasTable.Today = gas.v
gasTable.gasNow = gas.c
gasTable.YesterDay = gas.v
gasTable.LastYear = gas.v
gasTable.gasYear = gas.c
gasTable.gasYearConsumption = gasTable.gasNow - gasTable.gasYear + gasTable.gasToday
return gasTable
-- end
local function updateTextSensor(t)
gasText2.updateCustomSensor(t.gasToday or 0)
gasText3.updateCustomSensor(t.gasYesterDay or 0)
gasText4.updateCustomSensor(t.gasLastYear) or 0
gasText5.updateCustomSensor(t.gasTotal or 0)
-- main
steef27
thanks, great!
Piacco
I want to calaculate the energy cost since I got my new energy contract until now.
An example I get a new energy contract on the 26th of june 2019, and i want to calculate how many energy I have used en produced since now.
I tought something like this:
26-06-2019 Get countervalue of the P1-meter C1 and C2 and subtract it with the countervalue of my P1-meter C1 and C2 from today and do exact the same for the delivered energy with counter C3 and C4.
But how do i get the countervalue on a specific day?
Greetz,
Piacco
Greetz,
Piacco
- waaren
With http://<domoticz_ip:domoticz_port>/json.htm?type=graph&sensor=counter&idx=<idx>&range=year
you get all days
So walk the result table and select the specific date.
Or if it is a once of date then do this in your browser, write down the counter values and make these constants in your script.
steef27
I've been running the script for some time now and I noticed that "sameDayLastYear" is not a year ago today, but a year ago tomorrow.
- waaren
can you try again after changingsteef27 wrote: Thursday 29 April 2021 11:28 I've been running the script for some time now and I noticed that "sameDayLastYear" is not a year ago today, but a year ago tomorrow.
return math.ceil(os.difftime(os.time(), lastYear) / day )
