Try the script and look at your log and devices.
If you see error or something is not working we can take it from there.
Controlling Toon [HACKED] from Domoticz
- madpatrick
- Domoticz version: 2025.1
Re: Controlling Toon [HACKED] from Domoticz
-= HP server GEN11 =- OZW -=- Toon2 (rooted) -=- Domoticz v2025.1 -=- Dashticz v3.14b on Tab8" =-
- EdwinK
- Domoticz version: BETA
working:
ToonScenes
ToonAutoprogram
Those are not:
ToonProgramInformation
ToonTemperature
ToonBurnerinfo (not very important to me)
I would like to add the P1 readings too, but there are others 'tiles' for that.
ToonScenes
ToonAutoprogram
Those are not:
ToonTemperature
- madpatrick
ToonProgramInformation is not used by me, so i've remove it from the script.
You can add it yourself if you like
if domoticz.devices(ToonProgramInformation).text ~= ToonProgramInformationSensorValue then
-- domoticz.log('Updating Toon Program Information to: '..ToonProgramInformationSensorValue)
domoticz.devices(ToonProgramInformation).updateText(ToonProgramInformationSensorValue)
Are the names spelled correctly ?
Difficult to help without any information
ToonBurnerinfo. Do you mean "ToonBurnerName" ?
- madpatrick
For P1 check the dev_x.x of your Toon
- EdwinK
Yesmadpatrick wrote: ↑Wednesday 07 April 2021 19:03ToonProgramInformation is not used by me, so i've remove it from the script.
Do you see any errors in the log.Code: Select all
if domoticz.devices(ToonProgramInformation).text ~= ToonProgramInformationSensorValue then -- domoticz.log('Updating Toon Program Information to: '..ToonProgramInformationSensorValue) domoticz.devices(ToonProgramInformation).updateText(ToonProgramInformationSensorValue) end
I was, but I recreated the UV_ variables again and now the errors seem to be gone. So, that problem seems to be solvedAre the names spelled correctly ?
Yrs, sorry that was a mistake from working too long on this.ToonBurnerinfo. Do you mean "ToonBurnerName" ?
- madpatrick
So, it is working now for you ?
- EdwinK
So far it looks like it's working now with the exception of the temperarture. I can't get the room-temperature to show. Of course it's still on the Toon itself.
