Maximum of lua scripts?
- JohnnySK
Re: Maximum of lua scripts?
still same error
2021-03-31 23:08:04.971 Error: unable to remove file /home/pi/domoticz/scripts/dzVents/data/domscript3650.err
2021-03-31 23:08:28.844 Error: unable to remove file /home/pi/domoticz/scripts/dzVents/data/domscript3659.out
2021-03-31 23:08:28.844 Error: unable to remove file /home/pi/domoticz/scripts/dzVents/data/domscript3659.err
2021-03-31 23:10:43.734 Error: unable to remove file /home/pi/domoticz/scripts/dzVents/data/domscript3714.out
2021-03-31 23:10:43.734 Error: unable to remove file /home/pi/domoticz/scripts/dzVents/data/domscript3714.err
- Domoticz version: 2020.2
Excellent. That does it! Thank you!waaren wrote: ↑Wednesday 31 March 2021 23:01 when using os.execute you should use the background operatorCode: Select all
os.execute('/home/pi/domoticz/scripts/speedtest2.sh &')
It comes to mind that I need to educate on dzvents. I'm quite happy using LUA, dzVents looks different in approach.
What is a good place to start? Step by step documentation?
Hans
- waaren
os.execute is 100% Lua and the background (&) operator is Linux.
The wiki and the video @dannyBloe posted here should get you started
- waaren
can you share the os script and the content of these files in home/pi/domoticz/scripts/dzVents/data/ ?JohnnySK wrote: ↑Wednesday 31 March 2021 23:12 still same error
Also please the output of
sudo ps -ef | grep '[d]omoticz' | cut -d' ' -f1
sudo find /home/pi/domoticz/scripts/dzVents -type d -exec stat -c '%A - %U:%G %n' {} +
sudo find /home/pi/domoticz/domoticz -type f -exec stat -c '%A - %U:%G %n' {} +
sudo find /home/pi/domoticz/scripts/dzVents/data/*err -type f -exec stat -c '%A - %U:%G %n' {} +
- JohnnySK
pi@raspberrypi:~/domoticz/scripts $ sudo ps -ef | grep '[d]omoticz' | cut -d' ' -f1
root
root
root
pi@raspberrypi:~/domoticz/scripts $ sudo find /home/pi/domoticz/scripts/dzVents -type d -exec stat -c '%A - %U:%G %n' {} +
drwxr-xr-x - pi:pi /home/pi/domoticz/scripts/dzVents
drwxr-xr-x - pi:pi /home/pi/domoticz/scripts/dzVents/scripts
drwxr-xr-x - pi:pi /home/pi/domoticz/scripts/dzVents/examples
drwxr-xr-x - pi:pi /home/pi/domoticz/scripts/dzVents/examples/templates
drwxr-xr-x - pi:pi /home/pi/domoticz/scripts/dzVents/generated_scripts
drwxr-xr-x - pi:pi /home/pi/domoticz/scripts/dzVents/dumps
drwxrwxrwx - pi:pi /home/pi/domoticz/scripts/dzVents/data
pi@raspberrypi:~/domoticz/scripts $ sudo find /home/pi/domoticz/domoticz -type f -exec stat -c '%A - %U:%G %n' {} +
-rwxr-xr-x - pi:pi /home/pi/domoticz/domoticz
pi@raspberrypi:~/domoticz/scripts $ sudo find /home/pi/domoticz/scripts/dzVents/data/*err -type f -exec stat -c '%A - %U:%G %n' {} +
-rw------- - root:root /home/pi/domoticz/scripts/dzVents/data/domscript4307.err
-rw------- - root:root /home/pi/domoticz/scripts/dzVents/data/domscript4308.err
empty, 0 bytes, just filenames
script, connect to webserver, get values, calculate and push it to domoticz
#!/bin/bash
content=`curl -s http://admin:[email protected]/rect.cgi?A=4&B=Select`
current=`html2text <<< "$content" | grep "Current_(A)_____" | column -ts'|' | column -ts'Current_(A)_____ '`
voltage=`html2text <<< "$content" | grep "Voltage_(V)_____" | column -ts'|' | column -ts'Voltage_(V)_____ '`
power=`awk '{print $1*$2}' <<<"$current $voltage"`
url="http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=240&nvalue=0&svalue=$power"
report=`curl -s $url`
- waaren
Can you try again after changing the dzVents and bash to the below ones. It might not directly solve the issue but will show more information on what happens.
The power value will be returned to dzVents for further processing.
btw. It should also be possible to directly call the http://admin:[email protected]/rect.cgi?A=4&B=Select with a openURL call and bypass the OS script completely.
Your domoticz user is root but the directories are owned by pi:pi
that might be the reason the temp files (*err / *out) cannot be deleted
local scriptVar = 'getPower'
return
on =
devices =
'Batt Napatie',
shellCommandResponses =
scriptVar,
logging =
level = domoticz.LOG_DEBUG,
marker = scriptVar,
execute = function(dz, item)
local function osScript(script, delay)
dz.executeShellCommand(
command = '/home/pi/domoticz/scripts/' .. script,
callback = scriptVar,
timeout = 30, -- max execution time in seconds
}).afterSec(delay or 0)
if item.isDevice or item.isTimer then
osScript('pv_fpv1.sh')
osScript('pv_fpv2.sh', 10)
elseif item.ok then
dz.log('data from script: ' .. item.data, dz.LOG_DEBUG) -- need more processing
dz.log('There was an error', dz.LOG_ERROR)
dz.log(item, dz.LOG_DEBUG)
#!/bin/bash
echo $power
- Domoticz version: 2024.4
You could try, in lua:
os.execute ('(/home/.../script.sh > /dev/null)&')
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe - open weather map - wol - BBQ detection - rsync backup
- waaren
True but in dzVents > 3.1 the executeShellCommand() is available and that command will not only execute any shell command truly async and in a separate thread but does also offers the option to capture the result and returncode by means of the callback.azonneveld wrote: ↑Thursday 01 April 2021 9:47 This makes the script continue without waiting for the externally script to finish.
So if you are on a recent domoticz build the preferred way of executing any os command from within a dzVents script is to use the executeShellCommand()
- JohnnySK
I have some work now but I will try it. And it's possible get from bash more than one value?
Because I already started work on get voltage from BASH too.. see this
#!/bin/bash
#echo "$current"A
#echo "$voltage"V
#echo "$power"W
#echo "$content"
replace=""
firstStep=`echo "${content//<\/TR>/$replace}"`
secondStep=`echo "${firstStep//<TR>/$replace}"`
lastStep=`echo "${firstStep//BORDER CELLPADDING="3"/$replace}"`
#whole=`html2text <<< "$lastStep"`
#echo "$whole"
values=`html2text <<< "$lastStep" | grep "Input_Voltage_(V)" | column -ts'| °()_-' | column -ts'abcdefghijklmnoprstuvqxyzTIVSNC'`
#echo $values
IFS=' ' read -ra params <<< "$values"
#Print the split string
#for i in "${params[@]}"
#do
# echo $i
#done
sekundy=`date +%S`
#echo $sekundy
remainder=$(( sekundy % 15 ))
if [ "$remainder" -eq 0 ]; then
#echo $sekundy
pvVoltage=${params[1]}
#echo "$pvVoltage"V
url="http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=331&nvalue=0&svalue=$pvVoltage"
#echo $url
fi
- waaren
Yes. The amount of data to return to dzvents is not unlimited but I tested up to 64K without issues.
can you share the result of the first curl command
- JohnnySK
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN">
<HTML>
<HEAD>
<META http-equiv="refresh" content="30;URL=rect.cgi">
</HEAD>
<BODY>
<H2>Rectifier</H2>
<FORM METHOD=GET action=rect.cgi>
<P>Rectifier Address
<SELECT NAME=A><OPTION >1<OPTION SELECTED>4<OPTION >5</SELECT>
<INPUT TYPE=SUBMIT NAME=B VALUE="Select">
</P>
</FORM>
Enabled <INPUT TYPE=CHECKBOX NAME=C CHECKED>
<INPUT TYPE=SUBMIT NAME=D VALUE="Submit" >
</FORM>
<H2>Rectifier Status</H2>
<TABLE BORDER CELLPADDING="3">
<TR>
<TH>Voltage (V)</TH>
<TD>52.1</TD>
</TR>
<TR>
<TH>Current (A)</TH>
<TD>14.9</TD>
</TR>
<TR>
<TH>Mean Current (A)</TH>
<TD>98.5</TD>
</TR>
<TR>
<TH>Temperature (°C)</TH>
<TD>20</TD>
</TR>
<TH>Input Voltage (V)</TH>
<TD>201</TD>
</TR>
<TH>Version</TH>
<TD>50.56</TD>
</TR>
<TH>Serial Number</TH>
<TD>541</TD>
</TR>
</TABLE>
<H2>Alarm Status</H2>
<P><IMG SRC=ok.gif ALT="O"> Input Voltage OK<BR><IMG SRC=ok.gif ALT="O"> Low Voltage<BR><IMG SRC=ok.gif ALT="O"> Module Alarm<BR><IMG SRC=ok.gif ALT="O"> OV Shutdown<BR><IMG SRC=ok.gif ALT="O"> Current Limiting<BR><IMG SRC=ok.gif ALT="O"> Power On<BR><IMG SRC=ok.gif ALT="O"> OVP Enabled<BR><IMG SRC=ok.gif ALT="O"> Current Limit Reduced<BR><IMG SRC=ok.gif ALT="O"> Fan Fail<BR><IMG SRC=ok.gif ALT="O"> Current Share<BR><IMG SRC=ok.gif ALT="O"> Temp. Alarm<BR><IMG SRC=ok.gif ALT="O"> Phase Failure<BR><IMG SRC=ok.gif ALT="O"> Temp. SD<BR><IMG SRC=ok.gif ALT="O"> Internal Failure<BR></P>
</BODY>
</HTML>
- waaren
It's worth a try to see the result of below dzVents script that would get the values without using curl or OS scripts.JohnnySK wrote: ↑Thursday 01 April 2021 12:10Code: Select all
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN"> <HTML>
Please feel free to ask for clarification if and when needed.
local scriptVar = 'getRectData'
return
on =
timer =
'every 5 minutes',
httpResponses =
scriptVar,
logging =
level = domoticz.LOG_INFO,
marker = scriptVar,
local function extractData(myData)
-- get Values
values = {}
for value in string.gmatch(myData, "<TD>([%d%.]*)</TD>") do
table.insert(values, value)
-- get Labels and make table
local counter = 1
local data = {}
for label in string.gmatch(myData, "<TH>([%s%w%(%)%&%;]*)</TH>") do
data[label] = values[counter]
counter = counter + 1
return data
if item.isTimer then
dz.openURL(
url = 'http://admin:[email protected]/rect.cgi?A=4&B=Select',
elseif item.isHTTPResponse and item.ok then
local data = extractData(item.data)
dz.utils.dumpTable (data) -- This will show the content of the datatable. From here it will be relatively easy to populate the various virtual sensors (volt, ampere, etc)
dz.log('There was a problem handling the request', dz.LOG_ERROR)
dz.log(item, dz.LOG_ERROR)
- JohnnySK
but timer offer minutes timer only.. and my script must run maximal each 10seconds..
aaand, I must to turn off dzVents.. I have few devices updated by web api (json svalue update by web get) but each 6-8seconds... and devices get higher and higher delay. After 12hours values in domoticz and reality was so far ... only restart of domoticz service helps. It looks like dzVents create some big load on web server.
- waaren
For that restriction an easy workaround exists that was used before for similar cases.
See below
return
on =
timer =
'every 5 minutes',
httpResponses =
scriptVar,
logging =
marker = scriptVar,
local frequency = 6 -- every 60 / frequency seconds (frequency 6 ==>> every 10 seconds)
-- get Values
values = {}
local counter = 1
local data = {}
return data
local function sendURL(delay)
dz.openURL(
local interval = math.floor(60/frequency)
for delay = interval, (60 - interval), interval do
sendURL(delay)
So to summarize you have similar response problems as you reported before in January 2019 when you use a couple of classic Lua scripts and also after converting scripts to dzVents when updating a number of devices every 5 seconds.I have few devices updated by web api (json svalue update by web get) but each 6-8seconds... and devices get higher and higher delay. After 12hours values in domoticz and reality was so far ... only restart of domoticz service helps.
Then the conclusion might well be that given your current hardware, scripting is not the solution for you if the current update frequency and number of devices are a requirement.
- JohnnySK
Maybe..
But, on latest release was this delay with same scripts under minute. (not realtime, but not so bad)
Today, I have turned off dzVents, I migrated two big measurement scripts to MQTT and LUA but on beta, it looks like web interface gets big delay after few minutes of run. (delay more than 5minutes, really bad)
Yes I had simmilar problem before. I migrated lot off devices to MQTT and upgraded to latest release with new RPi and data was almost in realtime..
- JohnnySK
How LUA scripts update values.. Maybe will be better use red-node for prepare data and push ti domoticz only final values. V 2020.2 support consuption calculation by itself.. (send Watt only) I have this scripts because in earlier version was it on device update.
Users browsing this forum: BurningTyre and 1 guest
