No data
edwin1234
Domoticz version: 2021.1
No data
Post by edwin1234 »
I had a power failure, and domoticz was offline I started everything up again but dashticz shows no data any more, only the titles like lights , sensors etc.
I did do make stop and make start but that doesnt work.
What to do?
Lokonli
Re: No data
Post by Lokonli »
Apparently the Dashticz server is running, otherwise you would not see anything.
So I guess the connection with Domoticz is not working.
Is your Domoticz server still having the same IP address? (after power down your router may have given a new IP address)
Can you click on the Dashticz title (upper left). You might see some messages. (my preliminiary debug window :))
Further, if you open DevTools (press F12) you probably also will see some errors.
edwin1234
Re: No data
Post by edwin1234 »
Indeed the ip had changed,
Thank u 🙏🏻
