I had a power failure, and domoticz was offline I started everything up again but dashticz shows no data any more, only the titles like lights , sensors etc.
I did do make stop and make start but that doesnt work.
What to do?
No data
Re: No data
Apparently the Dashticz server is running, otherwise you would not see anything.
So I guess the connection with Domoticz is not working.
Is your Domoticz server still having the same IP address? (after power down your router may have given a new IP address)
Can you click on the Dashticz title (upper left). You might see some messages. (my preliminiary debug window
Further, if you open DevTools (press F12) you probably also will see some errors.
- Domoticz version: 2021.1
Re: No data
Indeed the ip had changed,
Thank u
Thank u
