Python Plugin : iCal Multi Purpose Python Plugin for Domoticz
peter68
- Domoticz version: 2020.2
Re: Python Plugin : iCal Multi Purpose Python Plugin for Domoticz
send by pm
thanks
thanks
infodnv
Since I created 14 devices I get failures that are shown in my logfile, any idea why? It used to work on a few devices.
2020-10-27 22:37:53.423 Error: (Secretariaat ICS) 'onHeartbeat' failed 'IndexError':'string index out of range'.
2020-10-27 22:37:53.423 Error: (Secretariaat ICS) ----> Line 235 in 'C:\Program Files (x86)\Domoticz\plugins\iCal\plugin.py'
2020-10-27 22:37:53.423 Error: (Secretariaat ICS) ----> Line 109 in 'C:\Program Files (x86)\Domoticz\plugins\iCal\plugin.py'
2020-10-27 22:37:53.487 Error: (Scene ICS) 'onHeartbeat' failed 'IndexError':'string index out of range'.
2020-10-27 22:37:53.487 Error: (Scene ICS) ----> Line 235 in 'C:\Program Files (x86)\Domoticz\plugins\iCal\plugin.py'
2020-10-27 22:37:53.487 Error: (Scene ICS) ----> Line 109 in 'C:\Program Files (x86)\Domoticz\plugins\iCal\plugin.py'
2020-10-27 22:37:53.487 Error: (Vestiaire ICS) 'onHeartbeat' failed 'IndexError':'string index out of range'.
2020-10-27 22:37:53.487 Error: (Vestiaire ICS) ----> Line 235 in 'C:\Program Files (x86)\Domoticz\plugins\iCal\plugin.py'
2020-10-27 22:37:53.488 Error: (Vestiaire ICS) ----> Line 109 in 'C:\Program Files (x86)\Domoticz\plugins\iCal\plugin.py'
2020-10-27 22:37:53.864 Error: (Café ICS) 'onHeartbeat' failed 'IndexError':'string index out of range'.
2020-10-27 22:37:53.864 Error: (Café ICS) ----> Line 235 in 'C:\Program Files (x86)\Domoticz\plugins\iCal\plugin.py'
2020-10-27 22:37:53.864 Error: (Café ICS) ----> Line 109 in 'C:\Program Files (x86)\Domoticz\plugins\iCal\plugin.py'
2020-10-27 22:37:53.864 Error: (Vergader ICS) 'onHeartbeat' failed 'IndexError':'string index out of range'.
2020-10-27 22:37:53.864 Error: (Vergader ICS) ----> Line 235 in 'C:\Program Files (x86)\Domoticz\plugins\iCal\plugin.py'
2020-10-27 22:37:53.865 Error: (Vergader ICS) ----> Line 109 in 'C:\Program Files (x86)\Domoticz\plugins\iCal\plugin.py'
2020-10-27 22:37:53.865 Error: (Loge ICS) 'onHeartbeat' failed 'IndexError':'string index out of range'.
2020-10-27 22:37:53.865 Error: (Loge ICS) ----> Line 235 in 'C:\Program Files (x86)\Domoticz\plugins\iCal\plugin.py'
2020-10-27 22:37:53.865 Error: (Loge ICS) ----> Line 109 in 'C:\Program Files (x86)\Domoticz\plugins\iCal\plugin.py'
2020-10-27 22:38:22.403 (Tango ICS) Pushing 'onHeartbeatCallback' on to queue
2020-10-27 22:38:22.433 (Tango ICS) Processing 'onHeartbeatCallback' message
2020-10-27 22:38:22.433 (Tango ICS) Calling message handler 'onHeartbeat'.
2020-10-27 22:38:22.433 Error: (Tango ICS) 'onHeartbeat' failed 'IndexError':'string index out of range'.
2020-10-27 22:38:22.433 Error: (Tango ICS) ----> Line 235 in 'C:\Program Files (x86)\Domoticz\plugins\iCal\plugin.py'
2020-10-27 22:38:22.433 Error: (Tango ICS) ----> Line 109 in 'C:\Program Files (x86)\Domoticz\plugins\iCal\plugin.py'
zak45
- Domoticz version: V2024.4
@infodnv,
need one of your ics file to be able to test.
infodnv
Zak45, in attachment i enclosed a zip with several ics files
- iCal.zip
- (29.78 KiB) Downloaded 119 times
zak45
@infodnv
I do not have been able to reproduce the error
The error occur during the update of the status device for the corresponding calendar.
check if your status device is there , maybe try to reinstall the plugin for the one that made error.
you can also try to put domoticz in 'en' language to see if problem with the lng file.
infodnv
zak45, i took a new raspberry PI and made a new installation. I restored my database and everything is working perfectly.
Thanks for your help, it is really amazing!!
carolief
Hi! Im new here and also still a beginner
I've got a raspberry pi with the iCal plugin running. Using the work switch to turn on the heating in my home office when I'm working from home. So far so good.
Now I'd like another "work switch" that would turn down the heating in the living room when I'm away from home. Is there any way I can create a second switch with a different #wrk# command like #out#?
zak45
There is only one "at work" switch managed by the plugin.carolief wrote: Friday 05 March 2021 7:52 Hi! Im new here and also still a beginnerI've got a raspberry pi with the iCal plugin running. Using the work switch to turn on the heating in my home office when I'm working from home. So far so good.
But you can create a Calendar entry with #cmd# on it and activate any Domoticz device.
sgae1990
I'm trying to install the ical plugin but the dropbox link seems to be offline. Is there anyone who has another link to find the needed files? Google gave me no luck
Thanks in advance!
Thanks in advance!
zak45
Here it is :sgae1990 wrote: Tuesday 16 March 2021 21:00 Hi all,
Thanks in advance!
https://synnas.publicvm.com/s/kDTY8PbGdwLRAsR
sgae1990
Thanks a lot!!zak45 wrote: Wednesday 17 March 2021 19:18
Here it is :
Himmy
- Domoticz version: 2021.1
hi there,
Is Google Translate still a problem when you're installing
Seems after installation a language file for my language (Belgium) is made in the iCal-folder but the file is empty...
I allready tried the "pip install git+https://github.com/BoseCorp/py-googletrans.git --upgrade"
Doesn't help... How do i solve this?
Thxfa
Thxfa
zak45
You can try that :
$ pip3 uninstall googletrans
$ pip3 install googletrans==3.1.0a0
Himmy
Tried that, first line "uninstall" didn't workzak45 wrote: Friday 14 May 2021 17:54 You can try that :
executing your second line made me realise googletrans was uptodate (3.1.0a0)
Deleted the 4 "switches" an made new hardware.
Again an 0-length language file. Could it be the chosen language when i make the hardware: i tried "België" and "Belgium"
The holidays were right an in my language.
Log file said this (many times):
2021-05-15 20:18:02.308 Error: Google Kalender 4 iCal: (Google Kalender 4 iCal) Error to process data
2021-05-15 20:18:02.713 Error: Google Kalender 4 iCal: (Google Kalender 4 iCal) Error on json from Received Data: {"status":{"step":"loadTexttotranslate","msg":"__Error to translate :
2021-05-15 20:18:02.713 __"}}
Number8
- Domoticz version: 2022.1
Hello
I'm running Domoticz latest beta (13314). I installed plugin as instructed. Domoticz is set to English. Allow for new devices is activated. Running python 3.7.3
This error message is reported and no device is created:
Morever, when I return to Harware/Plugin setup all specific options to the plugin are gone
en_en_lng, iCal.sh, plugin.py, iCal.py have been copied to the iCal folder. However, in the repositery I noticed there is iCalv1.py file. Is it needed as well?
Thank you
2021-06-13 17:51:22.829 Error: Calendrier: (Calendrier) Error on json from Received Data: {"status":{"step":"loadTexttotranslate","msg":"__Error to translate :
2021-06-13 17:51:22.829 __"}}
2021-06-13 17:51:22.829 Error: Calendrier: (Calendrier) Error to process dataen_en_lng, iCal.sh, plugin.py, iCal.py have been copied to the iCal folder. However, in the repositery I noticed there is iCalv1.py file. Is it needed as well?
Thank you
Debian buster on NUC and three RPi with buster.
Number8
I made some progress. Devices are now created. Great. However there are still one error message related to Meteo France. I checked that the name of the location is known to Meteo France and postal code uservariable is right
Could I suggest to add an option to use idx instead of name?
This extension to Domoticz is brilliant. Thank you for the great work
2021-06-13 21:01:21.760 Error: Calendrier: (Calendrier) __Error to execute query__
2021-06-13 21:01:21.760 Error: Calendrier: (Calendrier) __Not able to query data from Meteo France__This extension to Domoticz is brilliant. Thank you for the great work
Number8
Plugin has been installed on the production machine (Intel NUC on Debian). Same issue I had when I first tried the plugin on a test machine related to translation. I'm pretty much convinced that this error prevents the plugin to run
Any help would be much appreciated
Domoticz interface is set to English.
Moreover I noticed the following difference between the test and the production machine (it is indeed defined in the plugin parameter)
Hardware tab iCal Port parameter is displayed as expected whereas the port info is missing on the production machine
2021-06-14 08:54:35.443 Error: (Calendrier) Error on json from Received Data: {"status":{"step":"loadTexttotranslate","msg":"__Error to translate :
2021-06-14 08:54:35.443 __"}}
2021-06-14 08:54:35.443 Error: (Calendrier) Error to process dataMoreover I noticed the following difference between the test and the production machine (it is indeed defined in the plugin parameter)
Number8
Well pretty strange, without doing anything, after some time googletrans recovered by itself. Devices are now created. Switched back to French. French file is automatically created but is empty (as in the Dev machine). Seems to me that googletrans API is causing more trouble than solutions.
Number8
Domoticz hardware tab has changed since new stable version which likely explains why there is some regression when it comes to display various parameters. See the attached screenshot of the production machine that has not yet been upgraded to latest stable.
Number8
@zak45: would you consider adding selector switch as a possible command?
Thank you
Thank you
