Python2 vs Python3
RobD
Domoticz version: 4.10717
Python2 vs Python3
Post by RobD »
Something is puzzling me.
I have a RPi 4b with the latest version of Raspberry OS running Domoticz 2020.2.
On the Pi, Python2 and Python3 are installed.
I stumbled into a problem because a Python script which was developed in Python3 did not run as a script_time_xxx.py.
Looking into this I discovered that when Domoticz starts a script it is run on Python2 even though I have included the Shebang
#!/usr/bin/env python3
can anybody help me out?
Plans without action are a daydream.
Action without plans are a nightmare
Thorgal789
Re: Python2 vs Python3
Post by Thorgal789 »
On my side have right problem with python, so I run shell script with domoticz, and the shell script run the python script.
It solve lot of issues.
#!/bin/bash
python3 /home/pi/hp/play_radio.py > /dev/null 2>&1 &
exit 0
RobD
Post by RobD »
sure, I have a comparable workaround.
the thing is that I like to understand the cause of the problem
erem
Domoticz version: 2021.1
Post by erem »
from the command line
which python3
my result : /usr/bin/python3
then try changing the shebang to
#!/usr/bin/python3
Regards,
Rob
RobD wrote: Saturday 27 February 2021 12:26 sure, I have a comparable workaround.
The Shebang! line is ignored when the code is parsed as parm to the controlling interpreter
Consider this Python source with a Shebang!
#!/usr/bin/python3
import sys
print(sys.version)
# Force use of Python3
python3 ./version.py
3.7.3 (default, Jul 25 2020, 13:03:44)
[GCC 8.3.0]
# Force use of Python2
python2 ./version.py
2.7.16 (default, Oct 10 2019, 22:02:15)
[GCC 8.3.0]
# Relying on Shebang! for choosing the right interpreter
./version.py
[GCC 8.3.0]
Users browsing this forum: Droll, Google [Bot] and 1 guest
