Sure, thanks... Here you go. Two dumps in this log; the first ('north') is the one that manifests as RGBWW although it's only WW really and the second ('feature') is the one that domoticz sees as just WW. North was set to 200 'kelvin' before the dump, feature to 123 'kelvin'.
Both lamps are brought into domoticz by the domoticz-zigbee2mqtt plugin; I will have a look at Z2M's device definitions and the plugin for these two types of bulb to see whether I need to submit any changes into those projects, as both are tunable white bulbs, so ought to look the same in domoticz.
Strangely, I can see a color table in the data for the WW one but not the RGBWW one! The 't' value in the WW one is nonsense, though.
North @ kelvin 200:
2021-02-24 16:52:43.682 Status: dzVents: !Info: {["isGroup"]=false, ["rename"]=function, ["setColor"]=function, ["setHue"]=function, ["updateYouless"]=function, ["updateWind"]=function, ["quietOn"]=function, ["bState"]=true, ["updateP1"]=function, ["armAway"]=function, ["_adapters"]={"RGB(W) device adapter", "Switch device adapter"}, ["lastLevel"]=85, ["updateWeight"]=function, ["setDiscoMode"]=function, ["getColor"]=function, ["changed"]=false, ["setLevel"]=function, ["kodiExecuteAddOn"]=function, ["customImage"]=0, ["activate"]=function, ["updateTempHumBaro"]=function, ["deviceSubType"]="RGBWW", ["dump"]=function, ["updateCounter"]=function, ["color"]="", ["isSecurity"]=false, ["_data"]={["lastUpdate"]="2021-02-24 16:52:16", ["name"]="Lounge north lamp", ["subType"]="RGBWW", ["iconNumber"]=95, ["description"]="Innr WW bulb 6c69 // Controlicz: lounge north lamp", ["batteryLevel"]=255, ["rawData"]={"85"}, ["data"]={["maxDimLevel"]=100, ["color"]="", ["hardwareName"]="Zigbee2MQTT", ["hardwareID"]=43, ["unit"]=2, ["hardwareType"]="Zigbee2MQTT", ["usedByCamera"]=false, ["levelVal"]=85, ["hardwareTypeValue"]=94, ["customImage"]=0, ["_state"]="On", ["Image"]="Light", ["protected"]=false, ["_nValue"]=1, ["icon"]="dimmer"}, ["baseType"]="device", ["deviceType"]="Color Switch", ["signalLevel"]=3, ["id"]=2268, ["deviceID"]="0x00158d0005076c69_light", ["switchTypeValue"]=7, ["switchType"]="Dimmer", ["changed"]=false, ["image"]="", ["protected"]=false, ["timedOut"]=false, ["lastLevel"]=85}, ["decreaseBrightness"]=function, ["setIcon"]=function, ["icon"]="dimmer", ["kodiPlayFavorites"]=function, ["level"]=85, ["close"]=function, ["updateSetPoint"]=function, ["deviceId"]="0x00158d0005076c69_light", ["disarm"]=function, ["updateMode"]=function, ["updateElectricity"]=function, ["kodiPlay"]=function, ["quietOff"]=function, ["dimTo"]=function, ["updateSoundLevel"]=function, ["usedByCamera"]=false, ["updateBarometer"]=function, ["state"]="On", ["nValue"]=1, ["sValue"]="On", ["lastUpdate"]={["secondsSinceMidnight"]=60736, ["minutes"]=52, ["ruleIsAtSunset"]=function, ["time"]="16:52", ["ruleMatchesTimeRange"]=function, ["month"]=2, ["wday"]=4, ["yday"]=55, ["secondsAgo"]=27, ["ruleIsInWeek"]=function, ["ruleIsOnDate"]=function, ["addMinutes"]=function, ["daysAgo"]=0, ["makeTime"]=function, ["year"]=2021, ["ruleIsAtCivilTwilightEnd"]=function, ["current"]={["isdst"]=false, ["month"]=2, ["min"]=52, ["hour"]=16, ["yday"]=55, ["sec"]=43, ["wday"]=4, ["day"]=24, ["year"]=2021}, ["ruleIsAtCivilDayTime"]=function, ["addSeconds"]=function, ["isToday"]=true, ["compare"]=function, ["week"]=8, ["dayAbbrOfWeek"]="wed", ["minutesSinceMidnight"]=1012, ["ruleIsAtSolarnoon"]=function, ["rawDate"]="2021-02-24", ["dateToDate"]=function, ["ruleIsAfterCivilTwilightEnd"]=function, ["toUTC"]=function, ["ruleIsAtSunrise"]=function, ["matchesRule"]=function, ["milliseconds"]=0, ["day"]=24, ["dateToTimestamp"]=function, ["isUTC"]=false, ["ruleMatchesBetweenRange"]=function, ["ruleMatchesTime"]=function, ["ruleIsAtCivilTwilightStart"]=function, ["ruleIsAfterCivilTwilightStart"]=function, ["ruleMatchesMinuteSpecification"]=function, ["ruleIsAtDayTime"]=function, ["ruleIsAtNight"]=function, ["ruleMatchesHourSpecification"]=function, ["localeMonths"]=function, ["utils"]={["groupExists"]=function, ["LOG_FORCE"]=0.5, ["inTable"]=function, ["osExecute"]=function, ["urlDecode"]=function, ["deviceExists"]=function, ["dumpTable"]=function, ["LOG_INFO"]=3, ["LOG_WARNING"]=3, ["stringSplit"]=function, ["hasLines"]=function, ["fuzzyLookup"]=function, ["fromJSON"]=function, ["LOG_DEBUG"]=4, ["hsbToRGB"]=function, ["stringToSeconds"]=function, ["leftPad"]=function, ["fileExists"]=function, ["osCommand"]=function, ["round"]=function, ["toJSON"]=function, ["urlEncode"]=function, ["LOG_ERROR"]=1, ["variableExists"]=function, ["fromBase64"]=function, ["toCelsius"]=function, ["centerPad"]=function, ["hardwareExists"]=function, ["leadingZeros"]=function, ["sceneExists"]=function, ["rgbToHSB"]=function, ["isJSON"]=function, ["DZVERSION"]="3.1.3", ["log"]=function, ["cameraExists"]=function, ["toXML"]=function, ["print"]=function, ["fromXML"]=function, ["isXML"]=function, ["toStr"]=function, ["setLogMarker"]=function, ["fromLines"]=function, ["humidityStatus"]=function, ["numDecimals"]=function, ["LOG_MODULE_EXEC_INFO"]=2, ["dumpSelection"]=function, ["rightPad"]=function, ["toBase64"]=function}, ["isdst"]=false, ["ruleIsBeforeSolarnoon"]=function, ["rawTime"]="16:52:16", ["addHours"]=function, ["millisecondsAgo"]=27606, ["rawDateTime"]="2021-02-24 16:52:16", ["sec"]=16, ["ruleIsBeforeCivilTwilightEnd"]=function, ["ruleIsAfterSunrise"]=function, ["ruleIsBeforeSunset"]=function, ["seconds"]=16, ["monthName"]="February", ["ruleIsAtCivilNightTime"]=function, ["ruleIsBeforeCivilTwilightStart"]=function, ["timestampToDate"]=function, ["raw"]="2021-02-24 16:52:16", ["min"]=52, ["msAgo"]=27606, ["getISO"]=function, ["milliSeconds"]=0, ["hour"]=16, ["dayName"]="WednesDay", ["hoursAgo"]=0, ["ruleIsAfterSolarnoon"]=function, ["ruleIsAfterSunset"]=function, ["ruleIsBeforeSunrise"]=function, ["addDays"]=function, ["ruleIsOnDay"]=function, ["monthAbbrName"]="feb", ["dDate"]=1614185536, ["minutesAgo"]=0}, ["signalLevel"]=3, ["update"]=function, ["updateHumidity"]=function, ["setColorBrightness"]=function, ["isHTTPResponse"]=false, ["description"]="Innr WW bulb 6c69 // Controlicz: lounge north lamp", ["setWhiteMode"]=function, ["pause"]=function, ["kodiStop"]=function, ["updateHistory"]=function, ["updateWaterflow"]=function, ["switchType"]="Dimmer", ["setVolume"]=function, ["updateAirQuality"]=function, ["isHardware"]=false, ["setValues"]=function, ["protectionOff"]=function, ["name"]="Lounge north lamp", ["armHome"]=function, ["updateWetness"]=function, ["updateVisibility"]=function, ["updateCustomSensor"]=function, ["increaseBrightness"]=function, ["volumeDown"]=function, ["updateRadiation"]=function, ["_nValue"]=1, ["id"]=2268, ["unit"]=2, ["updatePercentage"]=function, ["setHotWater"]=function, ["updateLux"]=
2021-02-24 16:52:43.682 Status: dzVents: !Info: function, ["toggleSwitch"]=function, ["hardwareID"]=43, ["hardwareName"]="Zigbee2MQTT", ["startPlaylist"]=function, ["deviceType"]="Color Switch", ["cancelQueuedCommands"]=function, ["play"]=function, ["kodiPause"]=function, ["updateVoltage"]=function, ["playFavorites"]=function, ["protectionOn"]=function, ["_state"]="On", ["setMode"]=function, ["switchSelector"]=function, ["rawData"]={"85"}, ["open"]=function, ["isScene"]=false, ["maxDimLevel"]=100, ["inActive"]=false, ["switchOn"]=function, ["hardwareType"]="Zigbee2MQTT", ["idx"]=2268, ["setNightMode"]=function, ["setHex"]=function, ["updateGas"]=function, ["setState"]=function, ["Image"]="Light", ["protected"]=false, ["updatePressure"]=function, ["updateUV"]=function, ["hardwareId"]=43, ["updateDistance"]=function, ["isTimer"]=false, ["hardwareTypeValue"]=94, ["incrementCounter"]=function, ["updateText"]=function, ["updateTempBaro"]=function, ["isDevice"]=true, ["updateRain"]=function, ["updateAlertSensor"]=function, ["updateTemperature"]=function, ["updateTempHum"]=function, ["updateSoilMoisture"]=function, ["switchOff"]=function, ["reset"]=function, ["updateQuiet"]=function, ["active"]=true, ["setRGB"]=function, ["levelVal"]=85, ["setKelvin"]=function, ["baseType"]="device", ["volumeUp"]=function, ["onkyoEISCPCommand"]=function, ["setDescription"]=function, ["stop"]=function, ["switchTypeValue"]=7, ["isVariable"]=false, ["kodiPlayPlaylist"]=function, ["kodiSwitchOff"]=function, ["dumpSelection"]=function, ["kodiSetVolume"]=function, ["timedOut"]=false}
Feature @ kelvin 123:
2021-02-24 16:49:50.698 Status: dzVents: !Info: {["isSecurity"]=false, ["setMode"]=function, ["updateTemperature"]=function, ["switchTypeValue"]=7, ["updateDistance"]=function, ["armHome"]=function, ["_nValue"]=1, ["toggleSwitch"]=function, ["play"]=function, ["updateLux"]=function, ["isGroup"]=false, ["timedOut"]=false, ["updateTempBaro"]=function, ["setHotWater"]=function, ["open"]=function, ["update"]=function, ["increaseBrightness"]=function, ["switchOn"]=function, ["hardwareTypeValue"]=94, ["setLevel"]=function, ["setDescription"]=function, ["updateUV"]=function, ["armAway"]=function, ["switchOff"]=function, ["setHue"]=function, ["updateCounter"]=function, ["updateHumidity"]=function, ["customImage"]=0, ["id"]=3585, ["setState"]=function, ["onkyoEISCPCommand"]=function, ["updateAirQuality"]=function, ["updatePressure"]=function, ["updateGas"]=function, ["setVolume"]=function, ["updateAlertSensor"]=function, ["updateBarometer"]=function, ["kodiPlay"]=function, ["isScene"]=false, ["updateQuiet"]=function, ["signalLevel"]=4, ["kodiPlayFavorites"]=function, ["updateWeight"]=function, ["stop"]=function, ["updateRain"]=function, ["deviceSubType"]="WW", ["state"]="On", ["rawData"]={"60"}, ["nValue"]=1, ["volumeDown"]=function, ["startPlaylist"]=function, ["updateMode"]=function, ["switchType"]="Dimmer", ["quietOn"]=function, ["protected"]=false, ["setRGB"]=function, ["kodiPause"]=function, ["volumeUp"]=function, ["changed"]=false, ["bState"]=true, ["_data"]={["name"]="Lounge feature lamp", ["deviceID"]="0x804b50fffe3f3c40_light", ["image"]="", ["switchTypeValue"]=7, ["signalLevel"]=4, ["subType"]="WW", ["switchType"]="Dimmer", ["data"]={["customImage"]=0, ["_nValue"]=1, ["protected"]=false, ["hardwareType"]="Zigbee2MQTT", ["usedByCamera"]=false, ["levelVal"]=60, ["Image"]="Light", ["unit"]=11, ["hardwareTypeValue"]=94, ["hardwareName"]="Zigbee2MQTT", ["_state"]="On", ["hardwareID"]=43, ["color"]="{"b":0,"cw":0,"g":0,"m":2,"r":0,"t":255,"ww":0}", ["icon"]="dimmer", ["maxDimLevel"]=100}, ["id"]=3585, ["protected"]=false, ["lastUpdate"]="2021-02-24 16:49:38", ["lastLevel"]=60, ["description"]="(Zigbee 3c40) --- Controlicz: Lounge feature lamp", ["deviceType"]="Color Switch", ["changed"]=false, ["batteryLevel"]=255, ["baseType"]="device", ["timedOut"]=false, ["iconNumber"]=95, ["rawData"]={"60"}}, ["rename"]=function, ["activate"]=function, ["active"]=true, ["kodiPlayPlaylist"]=function, ["updateHistory"]=function, ["setIcon"]=function, ["updateWetness"]=function, ["idx"]=3585, ["lastLevel"]=60, ["setWhiteMode"]=function, ["switchSelector"]=function, ["incrementCounter"]=function, ["hardwareID"]=43, ["dimTo"]=function, ["kodiExecuteAddOn"]=function, ["disarm"]=function, ["level"]=60, ["maxDimLevel"]=100, ["_adapters"]={"RGB(W) device adapter", "Switch device adapter"}, ["updateYouless"]=function, ["playFavorites"]=function, ["updateWind"]=function, ["name"]="Lounge feature lamp", ["setDiscoMode"]=function, ["protectionOff"]=function, ["updateSetPoint"]=function, ["updateWaterflow"]=function, ["decreaseBrightness"]=function, ["kodiSwitchOff"]=function, ["isTimer"]=false, ["setNightMode"]=function, ["updateVoltage"]=function, ["updateVisibility"]=function, ["_state"]="On", ["updateText"]=function, ["updateTempHum"]=function, ["isDevice"]=true, ["dumpSelection"]=function, ["kodiStop"]=function, ["description"]="(Zigbee 3c40) --- Controlicz: Lounge feature lamp", ["deviceType"]="Color Switch", ["updateTempHumBaro"]=function, ["levelVal"]=60, ["pause"]=function, ["baseType"]="device", ["color"]="{"b":0,"cw":0,"g":0,"m":2,"r":0,"t":255,"ww":0}", ["dump"]=function, ["protectionOn"]=function, ["updateSoundLevel"]=function, ["updateRadiation"]=function, ["updateSoilMoisture"]=function, ["usedByCamera"]=false, ["hardwareId"]=43, ["quietOff"]=function, ["getColor"]=function, ["Image"]="Light", ["close"]=function, ["setColorBrightness"]=function, ["isHardware"]=false, ["deviceId"]="0x804b50fffe3f3c40_light", ["isHTTPResponse"]=false, ["hardwareType"]="Zigbee2MQTT", ["setHex"]=function, ["lastUpdate"]={["rawDateTime"]="2021-02-24 16:49:38", ["daysAgo"]=0, ["utils"]={["hardwareExists"]=function, ["fromJSON"]=function, ["LOG_FORCE"]=0.5, ["toCelsius"]=function, ["groupExists"]=function, ["osCommand"]=function, ["toStr"]=function, ["urlEncode"]=function, ["LOG_ERROR"]=1, ["centerPad"]=function, ["fromXML"]=function, ["dumpSelection"]=function, ["deviceExists"]=function, ["inTable"]=function, ["LOG_INFO"]=3, ["numDecimals"]=function, ["LOG_MODULE_EXEC_INFO"]=2, ["leftPad"]=function, ["dumpTable"]=function, ["leadingZeros"]=function, ["cameraExists"]=function, ["humidityStatus"]=function, ["DZVERSION"]="3.1.3", ["variableExists"]=function, ["log"]=function, ["stringSplit"]=function, ["rgbToHSB"]=function, ["LOG_DEBUG"]=4, ["stringToSeconds"]=function, ["toJSON"]=function, ["toXML"]=function, ["print"]=function, ["osExecute"]=function, ["hsbToRGB"]=function, ["isXML"]=function, ["setLogMarker"]=function, ["fileExists"]=function, ["rightPad"]=function, ["fromLines"]=function, ["hasLines"]=function, ["fromBase64"]=function, ["toBase64"]=function, ["urlDecode"]=function, ["isJSON"]=function, ["sceneExists"]=function, ["fuzzyLookup"]=function, ["LOG_WARNING"]=3, ["round"]=function}, ["ruleIsAfterSunrise"]=function, ["ruleMatchesMinuteSpecification"]=function, ["rawTime"]="16:49:38", ["addHours"]=function, ["yday"]=55, ["ruleIsBeforeCivilTwilightStart"]=function, ["month"]=2, ["ruleIsAtSolarnoon"]=function, ["wday"]=4, ["makeTime"]=function, ["ruleIsAtDayTime"]=function, ["timestampToDate"]=function, ["minutesSinceMidnight"]=1009, ["monthAbbrName"]="feb", ["addSeconds"]=function, ["addDays"]=function, ["day"]=24, ["minutes"]=49, ["seconds"]=38, ["raw"]="2021-02-24 16:49:38", ["rawDate"]="2021-02-24", ["ruleIsBeforeCivilTwilightEnd"]=function, ["dayAbbrOfWeek"]="wed", ["ruleIsAfterCivilTwilightStart"]=function, ["ruleMatchesHourSpecification"]=function, ["year"]=2021, ["ruleIsAfterSunset"]=function, ["msAgo"]=12622, ["ruleIsAtCivilTwilightEnd"]=function, ["addMin
2021-02-24 16:49:50.698 Status: dzVents: !Info: utes"]=function, ["ruleMatchesBetweenRange"]=function, ["dateToDate"]=function, ["dayName"]="WednesDay", ["ruleMatchesTimeRange"]=function, ["minutesAgo"]=0, ["week"]=8, ["ruleIsOnDate"]=function, ["dateToTimestamp"]=function, ["ruleIsAtNight"]=function, ["isToday"]=true, ["hour"]=16, ["ruleIsBeforeSunset"]=function, ["isdst"]=false, ["secondsAgo"]=12, ["getISO"]=function, ["ruleMatchesTime"]=function, ["ruleIsAtCivilDayTime"]=function, ["ruleIsInWeek"]=function, ["ruleIsAtCivilNightTime"]=function, ["ruleIsAfterSolarnoon"]=function, ["ruleIsBeforeSolarnoon"]=function, ["matchesRule"]=function, ["ruleIsAtSunset"]=function, ["ruleIsBeforeSunrise"]=function, ["ruleIsAtSunrise"]=function, ["ruleIsAfterCivilTwilightEnd"]=function, ["toUTC"]=function, ["milliSeconds"]=0, ["secondsSinceMidnight"]=60578, ["localeMonths"]=function, ["ruleIsAtCivilTwilightStart"]=function, ["sec"]=38, ["compare"]=function, ["milliseconds"]=0, ["current"]={["day"]=24, ["yday"]=55, ["min"]=49, ["sec"]=50, ["year"]=2021, ["wday"]=4, ["isdst"]=false, ["month"]=2, ["hour"]=16}, ["millisecondsAgo"]=12622, ["dDate"]=1614185378, ["time"]="16:49", ["hoursAgo"]=0, ["min"]=49, ["ruleIsOnDay"]=function, ["monthName"]="February", ["isUTC"]=false}, ["kodiSetVolume"]=function, ["setKelvin"]=function, ["setColor"]=function, ["inActive"]=false, ["icon"]="dimmer", ["updatePercentage"]=function, ["setValues"]=function, ["updateElectricity"]=function, ["updateP1"]=function, ["isVariable"]=false, ["hardwareName"]="Zigbee2MQTT", ["cancelQueuedCommands"]=function, ["sValue"]="On", ["unit"]=11, ["updateCustomSensor"]=function, ["reset"]=function}
Domoticz, Z-Stick Gen.5, zzh Zigbee, rxftrx433XL on Ubuntu 22.04, HP 290 G1.
Node Red, MQTT, 80+ Z-wave, ESP8266 & Shelly, handful of Zigbee bulbs. EMS-ESP gateway for Bosch boiler. Controlicz, until it dies :-(
