Energy Graph
Brutus
Energy Graph
Post by Brutus »
I'm struggeling with my energy graph. IDX 1 is a P1 Smart Meter With LAN. It monitors a 3 fase meter and we also have solar panels.
I would like to see the actual incomming or outgoing power (-3262). Just as the P1 meter is showing in Domoticz.
When adding this code:
// Grafiek: "Energie"
blocks['graph_1'] = {
    devices: [1],
    legend: false,
	datasetColors: ['white'],
	buttonsBorder: 'transparent',
        buttonsColor: '#ccc',
	buttonsFill: 'transparent',
	lineFill:true,
The graph outputs the standing of the consumption that day.
Output of P1 meter currently -3966
http://192.168.100.9:8080/json.htm?type=devices&rid=1
	"ActTime" : 1614002195,
	"AstrTwilightEnd" : "19:55",
	"AstrTwilightStart" : "05:44",
	"CivTwilightEnd" : "18:38",
	"CivTwilightStart" : "07:01",
	"DayLength" : "10:31",
	"NautTwilightEnd" : "19:17",
	"NautTwilightStart" : "06:23",
	"ServerTime" : "2021-02-22 14:56:35",
	"SunAtSouth" : "12:50",
	"Sunrise" : "07:34",
	"Sunset" : "18:05",
	"app_version" : "2020.2",
	"result" :
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"BatteryLevel" : 255,
			"Counter" : "94628.239",
			"CounterDeliv" : "548.486",
			"CounterDelivToday" : "12.390 kWh",
			"CounterToday" : "32.643 kWh",
			"CustomImage" : 0,
			"Data" : "52778525;41849714;270702;277784;0;3966",
			"Description" : "",
			"Favorite" : 1,
			"HardwareID" : 2,
			"HardwareName" : "P1",
			"HardwareType" : "P1 Smart Meter with LAN interface",
			"HardwareTypeVal" : 5,
			"HaveTimeout" : false,
			"ID" : "0001",
			"LastUpdate" : "2021-02-22 14:56:34",
			"Name" : "Energie",
			"Notifications" : "false",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"Protected" : false,
			"ShowNotifications" : true,
			"SignalLevel" : "-",
			"SubType" : "Energy",
			"SwitchTypeVal" : 0,
			"Timers" : "false",
			"Type" : "P1 Smart Meter",
			"TypeImg" : "counter",
			"Unit" : 1,
			"Usage" : "0 Watt",
			"UsageDeliv" : "3966 Watt",
			"Used" : 1,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "1"
	"status" : "OK",
	"title" : "Devices"
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
Lokonli
Re: Energy Graph
Post by Lokonli »
You have to create a 'custom graph'.
For an example for single phase P1 see:
https://dashticz.readthedocs.io/en/mast ... tom-graphs
Brutus
Re: Energy Graph
Post by Brutus »
@Lokonli
Thnx for your answer. Did look there but had no luck getting it to work now it does.
Used this code:
    title: 'Energie',
    devices: [1],
	graph: ['line','line','line'],
	lineFill:[false, true, true],
	lineTension: 0.4,
	custom : {
        "last day": {
            range: 'day',
            filter: '4 hours',
            data: {
                Actueel: 'd.v_1+d.v2_1-d.r1_1-d.r2_1',
                Verbruik: 'd.v_1+d.v2_1',
                Oplevering: '-d.r1_1-d.r2_1'
	datasetColors: [colourWhite, colourBlueLight, colourOrange],
    legend: true
Result:
28x Fibaro Modules
SMA Solar System
Lokonli
Re: Energy Graph
Post by Lokonli »
The graph looks quite ok to me.
What would you like to see differently? The data in the header row?
or combine it with the solar data?
(The energy usage seems high. You have a heat pump/electrical heating?)
Brutus
Re: Energy Graph
Post by Brutus »
Hi Lokonli,
I'm sorry maybe I was not clear about that. Before you pointed me to that link I already looked at that link but could not get the graph working. After you pointed it again to me I looked and got it working as you can see 8-)
This graph is from work. We only have heatpomps and 104 Solar panels recently placed. So I installed Domoticz to get a better look at the Energy standings. With dashticz we can make it even look nice ;) With days like this the graph looks nice:
Now I thought lets do this at home with the same graph because I like it. But... I copied the code from this page:
https://dashticz.readthedocs.io/en/mast ... stom-graph
Modified it to my device:
blocks['graph_77'] = {
    title: 'Energie',
    devices: [77],
    graph: ['line','bar','bar'],
    custom : {
        "last day": {
            range: 'day',
            filter: '24 hours',
            data: {
                nett: 'd.v_77+d.v2_77-d.r1_77-d.r2_77',
                usage: 'd.v_77+d.v2_77',
                generation: '-d.r1_77-d.r2_77'
        "last 2 weeks": {
            range: 'month',
            filter: '14 days',
            data: {
        "last 6 months": {
            range: 'year',
            filter: '6 months',
            data: {
    legend: true,
    datasetColors:['blue','red','yellow']
With this result:
The last day graph is not working. The other two are giving data.
What could be wrong?
Greetings.
28x Fibaro Modules
SMA Solar System
Lokonli
Re: Energy Graph
Post by Lokonli »
Can you add the graph debug button (see manual), select 'last day' button, and copy/paste the debug data here?
Then I'll have a look.
Brutus
Re: Energy Graph
Post by Brutus »
I'm trying to add this button but getting this error:
Error loading custom/CONFIG.js
SyntaxError: missing : after property id at line 329:10
    title: 'Energie',
    devices: [77],
    debug Button: true,
	custom : {
        "last day": {
            range: 'day',
            filter: '24 hours',
            data: {...
28x Fibaro Modules
SMA Solar System
Lokonli
Re: Energy Graph
Post by Lokonli »
Brutus wrote: Thursday 25 February 2021 9:53 I'm trying to add this button but getting this error:
    title: 'Energie',
    devices: [77],
    debug Button: true,
	custom : {
        "last day": {
            range: 'day',
            filter: '24 hours',
            data: {...
Replace
debug Button: true,
with
debugButton: true,
Brutus
Re: Energy Graph
Post by Brutus »
When using the search option on the Dashticz documentation it creates a space :roll:
Removing the space helps haha. Heres the debug:
  "mountPoint": "#block_24",
  "block": {
    "width": 12,
    "datasetColors": [
      "blue",
      "red",
      "yellow"
    "barWidth": 0.9,
    "beginAtZero": false,
    "borderDash": [],
    "borderWidth": 2,
    "buttonsBorder": "white",
    "buttonsColor": "black",
    "buttonsFill": "white",
    "buttonsIcon": "#686868",
    "buttonsMarginX": 2,
    "buttonsMarginY": 0,
    "buttonsPadX": 6,
    "buttonsPadY": 2,
    "buttonsRadius": 0,
    "buttonsShadow": false,
    "buttonsSize": 14,
    "buttonsText": false,
    "cartesian": "linear",
    "custom": {
      "last day": {
        "range": "day",
        "filter": "24 hours",
        "data": {
          "nett": "d.v_77+d.v2_77-d.r1_77-d.r2_77",
          "usage": "d.v_77+d.v2_77",
          "generation": "-d.r1_77-d.r2_77"
      "last 2 weeks": {
        "range": "month",
        "filter": "14 days",
        "data": {
      "last 6 months": {
        "range": "year",
        "filter": "6 months",
        "data": {
    "customHeader": false,
    "debugButton": true,
    "displayFormats": false,
    "drawOrderDay": false,
    "drawOrderLast": false,
    "drawOrderMonth": false,
    "flash": false,
    "fontColor": "white",
    "format": true,
    "gradients": false,
    "graph": [
      "line",
      "bar",
      "bar"
    "graphTypes": false,
    "groupBy": false,
    "groupByDevice": false,
    "height": false,
    "iconColour": "grey",
    "interval": 1,
    "legend": true,
    "lineFill": false,
    "lineTension": 0.1,
    "maxTicksLimit": null,
    "method": 1,
    "pointBorderColor": [
      "grey"
    "pointBorderWidth": 0,
    "pointRadius": 0,
    "pointStyle": false,
    "range": "initial",
    "refresh": 300,
    "reverseTime": false,
    "sortDevices": false,
    "spanGaps": false,
    "stacked": false,
    "title": "Energie",
    "tooltiptotal": false,
    "zoom": false,
    "devices": [
      77
    "key": "graph_77"
  "key": "graph_77",
  "name": "graph",
  "graphDevices": [
      "AddjMulti": 1,
      "AddjMulti2": 1,
      "AddjValue": 0,
      "AddjValue2": 0,
      "BatteryLevel": 255,
      "Counter": "16816.958",
      "CounterDeliv": "14037.239",
      "CounterDelivToday": "13.105 kWh",
      "CounterToday": "3.174 kWh",
      "CustomImage": 0,
      "Data": "10905291;5911667;4133502;9903737;398;0",
      "Description": "",
      "Favorite": 1,
      "HardwareID": 10,
      "HardwareName": "Energie Meter",
      "HardwareType": "P1 Smart Meter USB",
      "HardwareTypeVal": 4,
      "HaveTimeout": false,
      "ID": "0001",
      "LastUpdate": "2021-02-25 22:16:45",
      "Name": "Energie",
      "Notifications": "false",
      "PlanID": "4",
      "PlanIDs": [
        4,
        6
      "Protected": false,
      "ShowNotifications": true,
      "SignalLevel": "-",
      "SubType": "Energy",
      "SwitchTypeVal": 0,
      "Timers": "false",
      "Type": "P1 Smart Meter",
      "TypeImg": "counter",
      "Unit": 1,
      "Usage": "398 Watt",
      "UsageDeliv": "0 Watt",
      "Used": 1,
      "XOffset": "347",
      "YOffset": "301",
      "idx": 77,
      "currentValue": "3,17 kWh",
      "name": "Energie",
      "sensor": "counter",
      "subtype": "Energy",
      "title": "Energie",
      "txtUnit": "kWh",
      "txtUnits": [],
      "type": "P1 Smart Meter",
      "decimals": 2
  "decimals": 2,
  "graphIdx": "block_24",
  "lastRefreshTime": 1614287811,
  "range": "day",
  "title": "Energie",
  "params": [
    "type=graph&sensor=counter&idx=77&range=day&method=1"
  "txtUnits": [
    "kWh"
  "data": {
    "result": [
        "d": "2021-02-24 22:20",
        "r1_77": "0",
        "v_77": "332"
        "d": "2021-02-24 22:25",
        "r1_77": "0",
        "v_77": "327"
        "d": "2021-02-24 22:30",
        "r1_77": "0",
        "v_77": "330"
        "d": "2021-02-24 22:35",
        "r1_77": "0",
        "v_77": "328"
        "d": "2021-02-24 22:40",
        "r1_77": "0",
        "v_77": "324"
        "d": "2021-02-24 22:45",
        "r1_77": "0",
        "v_77": "326"
        "d": "2021-02-24 22:50",
        "r1_77": "0",
        "v_77": "295"
        "d": "2021-02-24 22:55",
        "r1_77": "0",
        "v_77": "203"
        "d": "2021-02-24 23:00",
        "r1_77": "0",
        "v_77": "201"
        "d": "2021-02-24 23:05",
        "r1_77": "0",
        "v_77": "203"
        "d": "2021-02-24 23:10",
        "r1_77": "0",
        "v_77": "180"
        "d": "2021-02-24 23:15",
        "r1_77": "0",
        "v_77": "178"
        "d": "2021-02-24 23:20",
        "r1_77": "0",
        "v_77": "177"
        "d": "2021-02-24 23:25",
        "r1_77": "0",
        "v_77": "180"
        "d": "2021-02-24 23:30",
        "r1_77": "0",
        "v_77": "198"
        "d": "2021-02-24 23:35",
        "r1_77": "0",
        "v_77": "223"
        "d": "2021-02-24 23:40",
        "r1_77": "0",
        "v_77": "207"
        "d": "2021-02-24 23:45",
        "r1_77": "0",
        "v_77": "294"
        "d": "2021-02-24 23:50",
        "r1_77": "0",
        "v_77": "289"
        "d": "2021-02-24 23:55",
        "r1_77": "0",
        "v_77": "262"
        "d": "2021-02-25 00:00",
        "r1_77": "0",
        "v_77": "268"
        "d": "2021-02-25 00:05",
        "r1_77": "0",
        "v_77": "359"
        "d": "2021-02-25 00:10",
        "r1_77": "0",
        "v_77": "363"
        "d": "2021-02-25 00:15",
        "r1_77": "0",
        "v_77": "375"
        "d": "2021-02-25 00:20",
        "r1_77": "0",
        "v_77": "359"
        "d": "2021-02-25 00:25",
        "r1_77": "0",
        "v_77": "363"
        "d": "2021-02-25 00:30",
        "r1_77": "0",
        "v_77": "354"
        "d": "2021-02-25 00:35",
        "r1_77": "0",
        "v_77": "376"
        "d": "2021-02-25 00:40",
        "r1_77": "0",
        "v_77": "342"
        "d": "2021-02-25 00:45",
        "r1_77": "0",
        "v_77": "322"
        "d": "2021-02-25 00:50",
        "r1_77": "0",
        "v_77": "365"
        "d": "2021-02-25 00:55",
        "r1_77": "0",
        "v_77": "279"
        "d": "2021-02-25 01:00",
        "r1_77": "0",
        "v_77": "180"
        "d": "2021-02-25 01:05",
        "r1_77": "0",
        "v_77": "181"
        "d": "2021-02-25 01:10",
        "r1_77": "0",
        "v_77": "182"
        "d": "2021-02-25 01:15",
        "r1_77": "0",
        "v_77": "184"
        "d": "2021-02-25 01:20",
        "r1_77": "0",
        "v_77": "203"
        "d": "2021-02-25 01:25",
        "r1_77": "0",
        "v_77": "197"
        "d": "2021-02-25 01:30",
        "r1_77": "0",
        "v_77": "194"
        "d": "2021-02-25 01:35",
        "r1_77": "0",
        "v_77": "188"
        "d": "2021-02-25 01:40",
        "r1_77": "0",
        "v_77": "185"
        "d": "2021-02-25 01:45",
        "r1_77": "0",
        "v_77": "181"
        "d": "2021-02-25 01:50",
        "r1_77": "0",
        "v_77": "182"
        "d": "2021-02-25 01:55",
        "r1_77": "0",
        "v_77": "182"
        "d": "2021-02-25 02:00",
        "r1_77": "0",
        "v_77": "315"
        "d": "2021-02-25 02:05",
        "r1_77": "0",
        "v_77": "275"
        "d": "2021-02-25 02:10",
        "r1_77": "0",
        "v_77": "278"
        "d": "2021-02-25 02:15",
        "r1_77": "0",
        "v_77": "276"
        "d": "2021-02-25 02:20",
        "r1_77": "0",
        "v_77": "273"
        "d": "2021-02-25 02:25",
        "r1_77": "0",
        "v_77": "269"
        "d": "2021-02-25 02:30",
        "r1_77": "0",
        "v_77": "269"
        "d": "2021-02-25 02:35",
        "r1_77": "0",
        "v_77": "266"
        "d": "2021-02-25 02:40",
        "r1_77": "0",
        "v_77": "263"
        "d": "2021-02-25 02:45",
        "r1_77": "0",
        "v_77": "262"
        "d": "2021-02-25 02:50",
        "r1_77": "0",
        "v_77": "170"
        "d": "2021-02-25 02:55",
        "r1_77": "0",
        "v_77": "166"
        "d": "2021-02-25 03:00",
        "r1_77": "0",
        "v_77": "167"
        "d": "2021-02-25 03:05",
        "r1_77": "0",
        "v_77": "165"
        "d": "2021-02-25 03:10",
        "r1_77": "0",
        "v_77": "195"
        "d": "2021-02-25 03:15",
        "r1_77": "0",
        "v_77": "183"
        "d": "2021-02-25 03:20",
        "r1_77": "0",
        "v_77": "176"
        "d": "2021-02-25 03:25",
        "r1_77": "0",
        "v_77": "176"
        "d": "2021-02-25 03:30",
        "r1_77": "0",
        "v_77": "177"
        "d": "2021-02-25 03:35",
        "r1_77": "0",
        "v_77": "159"
        "d": "2021-02-25 03:40",
        "r1_77": "0",
        "v_77": "162"
        "d": "2021-02-25 03:45",
        "r1_77": "0",
        "v_77": "161"
        "d": "2021-02-25 03:50",
        "r1_77": "0",
        "v_77": "165"
        "d": "2021-02-25 03:55",
        "r1_77": "0",
        "v_77": "161"
        "d": "2021-02-25 04:00",
        "r1_77": "0",
        "v_77": "259"
        "d": "2021-02-25 04:05",
        "r1_77": "0",
        "v_77": "282"
        "d": "2021-02-25 04:10",
        "r1_77": "0",
        "v_77": "263"
        "d": "2021-02-25 04:15",
        "r1_77": "0",
        "v_77": "261"
        "d": "2021-02-25 04:20",
        "r1_77": "0",
        "v_77": "260"
        "d": "2021-02-25 04:25",
        "r1_77": "0",
        "v_77": "259"
        "d": "2021-02-25 04:30",
        "r1_77": "0",
        "v_77": "259"
        "d": "2021-02-25 04:35",
        "r1_77": "0",
        "v_77": "257"
        "d": "2021-02-25 04:40",
        "r1_77": "0",
        "v_77": "262"
        "d": "2021-02-25 04:45",
        "r1_77": "0",
        "v_77": "255"
        "d": "2021-02-25 04:50",
        "r1_77": "0",
        "v_77": "165"
        "d": "2021-02-25 04:55",
        "r1_77": "0",
        "v_77": "164"
        "d": "2021-02-25 05:00",
        "r1_77": "0",
        "v_77": "163"
        "d": "2021-02-25 05:05",
        "r1_77": "0",
        "v_77": "185"
        "d": "2021-02-25 05:10",
        "r1_77": "0",
        "v_77": "179"
        "d": "2021-02-25 05:15",
        "r1_77": "0",
        "v_77": "177"
        "d": "2021-02-25 05:20",
        "r1_77": "0",
        "v_77": "173"
        "d": "2021-02-25 05:25",
        "r1_77": "0",
        "v_77": "173"
        "d": "2021-02-25 05:30",
        "r1_77": "0",
        "v_77": "163"
        "d": "2021-02-25 05:35",
        "r1_77": "0",
        "v_77": "167"
        "d": "2021-02-25 05:40",
        "r1_77": "0",
        "v_77": "160"
        "d": "2021-02-25 05:45",
        "r1_77": "0",
        "v_77": "166"
        "d": "2021-02-25 05:50",
        "r1_77": "0",
        "v_77": "164"
        "d": "2021-02-25 05:55",
        "r1_77": "0",
        "v_77": "161"
        "d": "2021-02-25 06:00",
        "r1_77": "0",
        "v_77": "292"
        "d": "2021-02-25 06:05",
        "r1_77": "0",
        "v_77": "273"
        "d": "2021-02-25 06:10",
        "r1_77": "0",
        "v_77": "263"
        "d": "2021-02-25 06:15",
        "r1_77": "0",
        "v_77": "257"
        "d": "2021-02-25 06:20",
        "r1_77": "0",
        "v_77": "256"
        "d": "2021-02-25 06:25",
        "r1_77": "0",
        "v_77": "257"
        "d": "2021-02-25 06:30",
        "r1_77": "0",
        "v_77": "255"
        "d": "2021-02-25 06:35",
        "r1_77": "0",
        "v_77": "293"
        "d": "2021-02-25 06:40",
        "r1_77": "0",
        "v_77": "294"
        "d": "2021-02-25 06:45",
        "r1_77": "0",
        "v_77": "295"
        "d": "2021-02-25 06:50",
        "r1_77": "0",
        "v_77": "204"
        "d": "2021-02-25 06:55",
        "r1_77": "0",
        "v_77": "225"
        "d": "2021-02-25 07:00",
        "r1_77": "0",
        "v_77": "227"
        "d": "2021-02-25 07:05",
        "r1_77": "0",
        "v_77": "214"
        "d": "2021-02-25 07:10",
        "r1_77": "0",
        "v_77": "177"
        "d": "2021-02-25 07:15",
        "r1_77": "0",
        "v_77": "169"
        "d": "2021-02-25 07:20",
        "r1_77": "0",
        "v_77": "159"
        "d": "2021-02-25 07:25",
        "r1_77": "0",
        "v_77": "228"
        "d": "2021-02-25 07:30",
        "r1_77": "0",
        "v_77": "210"
        "d": "2021-02-25 07:35",
        "r1_77": "0",
        "v_77": "220"
        "d": "2021-02-25 07:40",
        "r1_77": "0",
        "v_77": "203"
        "d": "2021-02-25 07:45",
        "r1_77": "0",
        "v_77": "110"
        "d": "2021-02-25 07:50",
        "r1_77": "0",
        "v_77": "110"
        "d": "2021-02-25 07:55",
        "r1_77": "0",
        "v_77": "154"
        "d": "2021-02-25 08:00",
        "r1_77": "0",
        "v_77": "123"
        "d": "2021-02-25 08:05",
        "r1_77": "0",
        "v_77": "124"
        "d": "2021-02-25 08:10",
        "r1_77": "0",
        "v_77": "81"
        "d": "2021-02-25 08:15",
        "r1_77": "0",
        "v_77": "27"
        "d": "2021-02-25 08:20",
        "r1_77": "47",
        "v_77": "0"
        "d": "2021-02-25 08:25",
        "r1_77": "109",
        "v_77": "0"
        "d": "2021-02-25 08:30",
        "r1_77": "172",
        "v_77": "0"
        "d": "2021-02-25 08:35",
        "r1_77": "339",
        "v_77": "0"
        "d": "2021-02-25 08:40",
        "r1_77": "411",
        "v_77": "0"
        "d": "2021-02-25 08:45",
        "r1_77": "489",
        "v_77": "0"
        "d": "2021-02-25 08:50",
        "r1_77": "556",
        "v_77": "0"
        "d": "2021-02-25 08:55",
        "r1_77": "666",
        "v_77": "0"
        "d": "2021-02-25 09:00",
        "r1_77": "737",
        "v_77": "0"
        "d": "2021-02-25 09:05",
        "r1_77": "740",
        "v_77": "0"
        "d": "2021-02-25 09:10",
        "r1_77": "1099",
        "v_77": "0"
        "d": "2021-02-25 09:15",
        "r1_77": "810",
        "v_77": "0"
        "d": "2021-02-25 09:20",
        "r1_77": "1301",
        "v_77": "0"
        "d": "2021-02-25 09:25",
        "r1_77": "1376",
        "v_77": "0"
        "d": "2021-02-25 09:30",
        "r1_77": "1421",
        "v_77": "0"
        "d": "2021-02-25 09:35",
        "r1_77": "1200",
        "v_77": "0"
        "d": "2021-02-25 09:40",
        "r1_77": "1318",
        "v_77": "0"
        "d": "2021-02-25 09:45",
        "r1_77": "1151",
        "v_77": "0"
        "d": "2021-02-25 09:50",
        "r1_77": "1266",
        "v_77": "0"
        "d": "2021-02-25 09:55",
        "r1_77": "1094",
        "v_77": "0"
        "d": "2021-02-25 10:00",
        "r1_77": "1186",
        "v_77": "0"
        "d": "2021-02-25 10:05",
        "r1_77": "1006",
        "v_77": "0"
        "d": "2021-02-25 10:10",
        "r1_77": "1199",
        "v_77": "0"
        "d": "2021-02-25 10:15",
        "r1_77": "1396",
        "v_77": "0"
        "d": "2021-02-25 10:20",
        "r1_77": "1264",
        "v_77": "0"
        "d": "2021-02-25 10:25",
        "r1_77": "1400",
        "v_77": "0"
        "d": "2021-02-25 10:30",
        "r1_77": "1637",
        "v_77": "0"
        "d": "2021-02-25 10:35",
        "r1_77": "1413",
        "v_77": "0"
        "d": "2021-02-25 10:40",
        "r1_77": "1357",
        "v_77": "0"
        "d": "2021-02-25 10:45",
        "r1_77": "1429",
        "v_77": "0"
        "d": "2021-02-25 10:50",
        "r1_77": "1232",
        "v_77": "0"
        "d": "2021-02-25 10:55",
        "r1_77": "1749",
        "v_77": "0"
        "d": "2021-02-25 11:00",
        "r1_77": "2060",
        "v_77": "0"
        "d": "2021-02-25 11:05",
        "r1_77": "1934",
        "v_77": "0"
        "d": "2021-02-25 11:10",
        "r1_77": "2041",
        "v_77": "0"
        "d": "2021-02-25 11:15",
        "r1_77": "2132",
        "v_77": "0"
        "d": "2021-02-25 11:20",
        "r1_77": "1972",
        "v_77": "0"
        "d": "2021-02-25 11:25",
        "r1_77": "1670",
        "v_77": "0"
        "d": "2021-02-25 11:30",
        "r1_77": "1861",
        "v_77": "0"
        "d": "2021-02-25 11:35",
        "r1_77": "2127",
        "v_77": "0"
        "d": "2021-02-25 11:40",
        "r1_77": "2065",
        "v_77": "0"
        "d": "2021-02-25 11:45",
        "r1_77": "1833",
        "v_77": "0"
        "d": "2021-02-25 11:50",
        "r1_77": "2116",
        "v_77": "0"
        "d": "2021-02-25 11:55",
        "r1_77": "2283",
        "v_77": "0"
        "d": "2021-02-25 12:00",
        "r1_77": "2136",
        "v_77": "0"
        "d": "2021-02-25 12:05",
        "r1_77": "2005",
        "v_77": "0"
        "d": "2021-02-25 12:10",
        "r1_77": "2160",
        "v_77": "0"
        "d": "2021-02-25 12:15",
        "r1_77": "1978",
        "v_77": "0"
        "d": "2021-02-25 12:20",
        "r1_77": "2185",
        "v_77": "0"
        "d": "2021-02-25 12:25",
        "r1_77": "2157",
        "v_77": "0"
        "d": "2021-02-25 12:30",
        "r1_77": "1818",
        "v_77": "0"
        "d": "2021-02-25 12:35",
        "r1_77": "2080",
        "v_77": "0"
        "d": "2021-02-25 12:40",
        "r1_77": "2594",
        "v_77": "0"
        "d": "2021-02-25 12:45",
        "r1_77": "2567",
        "v_77": "0"
        "d": "2021-02-25 12:50",
        "r1_77": "2576",
        "v_77": "0"
        "d": "2021-02-25 12:55",
        "r1_77": "2553",
        "v_77": "0"
        "d": "2021-02-25 13:00",
        "r1_77": "2557",
        "v_77": "0"
        "d": "2021-02-25 13:05",
        "r1_77": "2442",
        "v_77": "0"
        "d": "2021-02-25 13:10",
        "r1_77": "2476",
        "v_77": "0"
        "d": "2021-02-25 13:15",
        "r1_77": "2516",
        "v_77": "0"
        "d": "2021-02-25 13:20",
        "r1_77": "2501",
        "v_77": "0"
        "d": "2021-02-25 13:25",
        "r1_77": "2423",
        "v_77": "0"
        "d": "2021-02-25 13:30",
        "r1_77": "2252",
        "v_77": "0"
        "d": "2021-02-25 13:35",
        "r1_77": "2168",
        "v_77": "0"
        "d": "2021-02-25 13:40",
        "r1_77": "2367",
        "v_77": "0"
        "d": "2021-02-25 13:45",
        "r1_77": "1987",
        "v_77": "0"
        "d": "2021-02-25 13:50",
        "r1_77": "1987",
        "v_77": "0"
        "d": "2021-02-25 13:55",
        "r1_77": "1760",
        "v_77": "0"
        "d": "2021-02-25 14:00",
        "r1_77": "2141",
        "v_77": "0"
        "d": "2021-02-25 14:05",
        "r1_77": "1918",
        "v_77": "0"
        "d": "2021-02-25 14:10",
        "r1_77": "1743",
        "v_77": "0"
        "d": "2021-02-25 14:15",
        "r1_77": "1384",
        "v_77": "0"
        "d": "2021-02-25 14:20",
        "r1_77": "1552",
        "v_77": "0"
        "d": "2021-02-25 14:25",
        "r1_77": "1964",
        "v_77": "0"
        "d": "2021-02-25 14:30",
        "r1_77": "1672",
        "v_77": "0"
        "d": "2021-02-25 14:35",
        "r1_77": "1648",
        "v_77": "0"
        "d": "2021-02-25 14:40",
        "r1_77": "1467",
        "v_77": "0"
        "d": "2021-02-25 14:45",
        "r1_77": "2105",
        "v_77": "0"
        "d": "2021-02-25 14:50",
        "r1_77": "1748",
        "v_77": "0"
        "d": "2021-02-25 14:55",
        "r1_77": "1790",
        "v_77": "0"
        "d": "2021-02-25 15:00",
        "r1_77": "1736",
        "v_77": "0"
        "d": "2021-02-25 15:05",
        "r1_77": "1795",
        "v_77": "0"
        "d": "2021-02-25 15:10",
        "r1_77": "1718",
        "v_77": "0"
        "d": "2021-02-25 15:15",
        "r1_77": "1610",
        "v_77": "0"
        "d": "2021-02-25 15:20",
        "r1_77": "1274",
        "v_77": "0"
        "d": "2021-02-25 15:25",
        "r1_77": "1468",
        "v_77": "0"
        "d": "2021-02-25 15:30",
        "r1_77": "1369",
        "v_77": "0"
        "d": "2021-02-25 15:35",
        "r1_77": "1290",
        "v_77": "0"
        "d": "2021-02-25 15:40",
        "r1_77": "1224",
        "v_77": "0"
        "d": "2021-02-25 15:45",
        "r1_77": "1075",
        "v_77": "0"
        "d": "2021-02-25 15:50",
        "r1_77": "1036",
        "v_77": "0"
        "d": "2021-02-25 15:55",
        "r1_77": "1018",
        "v_77": "0"
        "d": "2021-02-25 16:00",
        "r1_77": "760",
        "v_77": "0"
        "d": "2021-02-25 16:05",
        "r1_77": "1008",
        "v_77": "0"
        "d": "2021-02-25 16:10",
        "r1_77": "649",
        "v_77": "0"
        "d": "2021-02-25 16:15",
        "r1_77": "624",
        "v_77": "0"
        "d": "2021-02-25 16:20",
        "r1_77": "498",
        "v_77": "0"
        "d": "2021-02-25 16:25",
        "r1_77": "546",
        "v_77": "0"
        "d": "2021-02-25 16:30",
        "r1_77": "741",
        "v_77": "0"
        "d": "2021-02-25 16:35",
        "r1_77": "685",
        "v_77": "0"
        "d": "2021-02-25 16:40",
        "r1_77": "467",
        "v_77": "0"
        "d": "2021-02-25 16:45",
        "r1_77": "402",
        "v_77": "0"
        "d": "2021-02-25 16:50",
        "r1_77": "298",
        "v_77": "0"
        "d": "2021-02-25 16:55",
        "r1_77": "150",
        "v_77": "0"
        "d": "2021-02-25 17:00",
        "r1_77": "83",
        "v_77": "0"
        "d": "2021-02-25 17:05",
        "r1_77": "27",
        "v_77": "0"
        "d": "2021-02-25 17:10",
        "r1_77": "0",
        "v_77": "85"
        "d": "2021-02-25 17:15",
        "r1_77": "0",
        "v_77": "105"
        "d": "2021-02-25 17:20",
        "r1_77": "0",
        "v_77": "155"
        "d": "2021-02-25 17:25",
        "r1_77": "0",
        "v_77": "244"
        "d": "2021-02-25 17:30",
        "r1_77": "0",
        "v_77": "259"
        "d": "2021-02-25 17:35",
        "r1_77": "0",
        "v_77": "273"
        "d": "2021-02-25 17:40",
        "r1_77": "0",
        "v_77": "335"
        "d": "2021-02-25 17:45",
        "r1_77": "0",
        "v_77": "327"
        "d": "2021-02-25 17:50",
        "r1_77": "0",
        "v_77": "333"
        "d": "2021-02-25 17:55",
        "r1_77": "0",
        "v_77": "245"
        "d": "2021-02-25 18:00",
        "r1_77": "0",
        "v_77": "251"
        "d": "2021-02-25 18:05",
        "r1_77": "0",
        "v_77": "271"
        "d": "2021-02-25 18:10",
        "r1_77": "0",
        "v_77": "197"
        "d": "2021-02-25 18:15",
        "r1_77": "0",
        "v_77": "199"
        "d": "2021-02-25 18:20",
        "r1_77": "0",
        "v_77": "199"
        "d": "2021-02-25 18:25",
        "r1_77": "0",
        "v_77": "177"
        "d": "2021-02-25 18:30",
        "r1_77": "0",
        "v_77": "175"
        "d": "2021-02-25 18:35",
        "r1_77": "0",
        "v_77": "175"
        "d": "2021-02-25 18:40",
        "r1_77": "0",
        "v_77": "177"
        "d": "2021-02-25 18:45",
        "r1_77": "0",
        "v_77": "176"
        "d": "2021-02-25 18:50",
        "r1_77": "0",
        "v_77": "176"
        "d": "2021-02-25 18:55",
        "r1_77": "0",
        "v_77": "176"
        "d": "2021-02-25 19:00",
        "r1_77": "0",
        "v_77": "270"
        "d": "2021-02-25 19:05",
        "r1_77": "0",
        "v_77": "304"
        "d": "2021-02-25 19:10",
        "r1_77": "0",
        "v_77": "289"
        "d": "2021-02-25 19:15",
        "r1_77": "0",
        "v_77": "286"
        "d": "2021-02-25 19:20",
        "r1_77": "0",
        "v_77": "280"
        "d": "2021-02-25 19:25",
        "r1_77": "0",
        "v_77": "277"
        "d": "2021-02-25 19:30",
        "r1_77": "0",
        "v_77": "270"
        "d": "2021-02-25 19:35",
        "r1_77": "0",
        "v_77": "271"
        "d": "2021-02-25 19:40",
        "r1_77": "0",
        "v_77": "175"
        "d": "2021-02-25 19:45",
        "r1_77": "0",
        "v_77": "175"
        "d": "2021-02-25 19:50",
        "r1_77": "0",
        "v_77": "177"
        "d": "2021-02-25 19:55",
        "r1_77": "0",
        "v_77": "175"
        "d": "2021-02-25 20:00",
        "r1_77": "0",
        "v_77": "177"
        "d": "2021-02-25 20:05",
        "r1_77": "0",
        "v_77": "177"
        "d": "2021-02-25 20:10",
        "r1_77": "0",
        "v_77": "178"
        "d": "2021-02-25 20:15",
        "r1_77": "0",
        "v_77": "242"
        "d": "2021-02-25 20:20",
        "r1_77": "0",
        "v_77": "256"
        "d": "2021-02-25 20:25",
        "r1_77": "0",
        "v_77": "230"
        "d": "2021-02-25 20:30",
        "r1_77": "0",
        "v_77": "232"
        "d": "2021-02-25 20:35",
        "r1_77": "0",
        "v_77": "232"
        "d": "2021-02-25 20:40",
        "r1_77": "0",
        "v_77": "235"
        "d": "2021-02-25 20:45",
        "r1_77": "0",
        "v_77": "234"
        "d": "2021-02-25 20:50",
        "r1_77": "0",
        "v_77": "326"
        "d": "2021-02-25 20:55",
        "r1_77": "0",
        "v_77": "362"
        "d": "2021-02-25 21:00",
        "r1_77": "0",
        "v_77": "348"
        "d": "2021-02-25 21:05",
        "r1_77": "0",
        "v_77": "341"
        "d": "2021-02-25 21:10",
        "r1_77": "0",
        "v_77": "336"
        "d": "2021-02-25 21:15",
        "r1_77": "0",
        "v_77": "329"
        "d": "2021-02-25 21:20",
        "r1_77": "0",
        "v_77": "325"
        "d": "2021-02-25 21:25",
        "r1_77": "0",
        "v_77": "321"
        "d": "2021-02-25 21:30",
        "r1_77": "0",
        "v_77": "231"
        "d": "2021-02-25 21:35",
        "r1_77": "0",
        "v_77": "230"
        "d": "2021-02-25 21:40",
        "r1_77": "0",
        "v_77": "231"
        "d": "2021-02-25 21:45",
        "r1_77": "0",
        "v_77": "230"
        "d": "2021-02-25 21:50",
        "r1_77": "0",
        "v_77": "233"
        "d": "2021-02-25 21:55",
        "r1_77": "0",
        "v_77": "227"
        "d": "2021-02-25 22:00",
        "r1_77": "0",
        "v_77": "234"
        "d": "2021-02-25 22:05",
        "r1_77": "0",
        "v_77": "234"
        "d": "2021-02-25 22:10",
        "r1_77": "0",
        "v_77": "389"
        "d": "2021-02-25 22:15",
        "r1_77": "0",
        "v_77": "387"
    "status": "OK",
    "title": "Graph day",
  "realrange": "day",
  "dataFilterCount": 24,
  "dataFilterUnit": "hours",
  "groupBy": false,
  "customRange": true,
  "customRangeName": "last day",
  "graphConfig": {
    "range": "day",
    "data": {
  "keys": [
    "v",
    "v",
    "r1"
  "ykeys": [
    "nett",
    "usage",
    "generation"
  "txtUnit": "kWh",
  "ylabels": [
    "Watt",
    "Watt",
    "Watt"
  "chartctx": "graphoutput_block_24",
  "_width": 666,
  "loadingTooltip": false
28x Fibaro Modules
SMA Solar System
Lokonli
Re: Energy Graph
Post by Lokonli »
Your meter behaves like a single tariff meter.
Can you remove all r2 and v2 data fields from the custom data definition and retry?
Brutus
Re: Energy Graph
Post by Brutus »
That did the trick! But I don't have a single tariff meter. Domoticz reads both usage and generation devices...
28x Fibaro Modules
SMA Solar System
Lokonli
Re: Energy Graph
Post by Lokonli »
And in the Domoticz day graph?
If the Dashticz weeks and months graph is working, then apparently there's something wrong with the day data.
Can you post the browser output of the following:
http://domoticzip:port/json.htm?idx=77&method=1&range=day&sensor=counter&type=graph
Brutus
Re: Energy Graph
Post by Brutus »
hmm never noticed but the day graph indeed has only Usage and generation. Don't know if this is normal behavior of Domoticz.
Output (cut something out because is was a lot of data):
delivered	true
result
0
d	"2021-02-25 08:50"
r1	"556"
v	"0"
1
d	"2021-02-25 08:55"
r1	"666"
v	"0"
2
d	"2021-02-25 09:00"
r1	"737"
v	"0"
3
286
d	"2021-02-26 08:40"
r1	"19"
v	"0"
287
d	"2021-02-26 08:45"
r1	"92"
v	"0"
288
d	"2021-02-26 08:50"
r1	"196"
v	"0"
status	"OK"
title	"Graph counter day"
28x Fibaro Modules
SMA Solar System
