I wanted to express my gratitude to the author of that skill. I have been using domoticz for nearly three years and was struggling with habridge and its limitations.
I was on the verge to develop such a skill myself out of sheer frustration with my previous solution.
By luck I found that topic - seriously: not having native Alexa integration is one of the most serious drawbacks of Domoticz - until now.
Here are my gotchas I encountered along the way to set up that skill:
- you might share a link how to use domoticz ssl port from the outside. In fact I was wondering why the skill does not use MyDomoticz.
- the walk thru to set up the skill is not quite up to date - I had to improvise at some points...
- choosing Ireland for the lambda location is essential _ otherwise the account linking throws weird errors
- the name of the lambda function in the git repository needs to be adapted to the current version
- the final hurdle: make sure to create a floor plan, assign the devices you want to be discovered by Alexa and set the plan ID in the config Jason to your Alexa devices plan I was struggling quite a bit with that last one..
I recommend to link to that topic from the starting page of the forum... It's a huge benefit. I can now set the colors of my MySensors and z-wave rgb strips... Hurray
Cheers,
Lars
