Smartthings integration to domoticz Topic is solved
tontze
- Domoticz version: Beta Ch
Hi !
Ive seen many posts where domoticz items are integrated to smartthings, but since smartthings does not have pc frontend, im asking has anyone gotten smartthings items to show up on domoticz ?
I believe this is doable on node-red, but how, is there a tutorial somewhere ?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- FireWizard
Re: Smartthings integration to domoticz
@tontze,
This will help you.
You can install the node for "Smartthings "via the Palette in Node Red.
See: https://flows.nodered.org/node/node-red ... martthings
I suggest you read the tutorials on https://nodered.org/docs/tutorials/I believe this is doable on node-red, but how, is there a tutorial somewhere ?
This will help you.
tontze
Thanks, i can now see my smartthings items in nodered, but i just cannot figure where to go from there .. I have tried simply read state of the item in nodered, but .. i dont get it how to do it :/ Can someone show an example ?FireWizard wrote: Saturday 06 February 2021 21:36 @tontze,
This will help you.
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- FireWizard
Hi, @tontze
Can you show a screenshot of what you see in Node Red? Have you connected "Debug" nodes to your Smartthings Nodes?
tontze
I did now, and yes, i see 'value' nowFireWizard wrote: Saturday 20 February 2021 16:31 Hi, @tontze
I also tried to add inject node to control light from nodered. but couldnt figure that out :/ Heres how i tried it :
I tried to simulate this example (couldnt find where to put it in this form):
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- FireWizard
Hello, @tontze
I see, that you have connected an "Inject" node, called "Switch", with msg.topic as "Kitchen Lights" and a numerical payload "1".
Is this what is expected to send to that payload?
What do I see. if you "fire" the Inject node.
The next screenshot, does not show the expected result. It looks like a part of a manual.
Where can I find that?
Last edited by FireWizard on Saturday 20 February 2021 18:54, edited 1 time in total.
tontze
Absolutely nothing happends if i press inject node :/FireWizard wrote: Saturday 20 February 2021 18:01 Hello, @tontze
The next screenshot, does not show the expected result. I look like a part of a manual.
Yes that is part of flow install manual, but theres not anything more there.
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- FireWizard
hello @tontze
I do not own any of these dvoces and I do not have a Smartthings account.
But I think, that you can probably follow the procedure as described at:
https://adam-phillips.dev/blog/2020-04- ... artthings/
Otherwise the Smartthings forum may help. https://community.smartthings.com/t/nod ... ings/27063
If we have the data properly formatted in Node Red, we can make the connection to Domoticz
Up to now, this isn't a Domoticz issue.
tontze
Thank you for your help, it is true, this is not yet domoticz issue, but it will become one after i learn some more
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
tontze
Ok, managed to get it working !
Below is an example, im sure it can be done better, but this is how i got it working
Now to the domoticz part, how do i get domoticz in/out to node-red ?
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- FireWizard
Hello @tontze,
But some hints.
1. You declare a variable msg. This variable is a standard in Node Red and not necessary to declare.
2. A topic (in your case "switch" is sometimes necessary, but I do not see, where it is used here.
I do not know what the Smartthings node, called "Kitchen Lights" expects.
3. Probably you send a timestamp with the two "Inject" nodes.
You can insert directly the payload in the "Inject" nodes and also the topic.
Then you don't need those two "Function" nodes.
Step 1: Configure a virtual Switch in Domoticz. Note down the IDX number
Step 2: Install in Domoticz hardware: MQTT Client Gateway with LAN interface, if not done already.
I assume you have Mosquitto running?
Insert the following flow and replace in the Switch node, called Filter Switch the current IDX (13) with yours.
Replace the Debug node with the Smartthings node.
Now it should be possible to operate your "Kitchen Lights" FROM Domoticz with the virtual switch.
To send data TO Domoticz, I need to know the contents of your Debug node.
Can you publish that?
Yes probably it could have been done in a different way. Better? Who decides, what is better?Ok, managed to get it working !
But some hints.
Domoticz Out is not a problem.Now to the domoticz part, how do i get domoticz in/out to node-red ?
[{"id":"f1bbcae6.fbeeb","type":"mqtt in","z":"68896a5a.1b56e4","name":"","topic":"domoticz/out","qos":"0","datatype":"json","broker":"f9f13036.e28b58","x":110,"y":820,"wires":[["6805674d.4e1d48"]]},{"id":"d40eb5a7.72987","type":"debug","z":"68896a5a.1b56e4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":690,"y":820,"wires":[]},{"id":"6805674d.4e1d48","type":"switch","z":"68896a5a.1b56e4","name":"Filter Switch","property":"payload.idx","propertyType":"msg","rules":[{"t":"eq","v":"13","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":310,"y":820,"wires":[["be2d15e0.7d88a"]]},{"id":"be2d15e0.7d88a","type":"function","z":"68896a5a.1b56e4","name":"","func":"msg.topic = \"Switch\";\nmsg.payload = msg.payload.nvalue;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":500,"y":820,"wires":[["d40eb5a7.72987"]]},{"id":"f9f13036.e28b58","type":"mqtt-broker","name":"localhost","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]Now it should be possible to operate your "Kitchen Lights" FROM Domoticz with the virtual switch.
- pgielen
- Domoticz version: 2026.4
I just posted a blog post about my own experiences with the Aeotec Smart Home Hub (Works with SmartThings) and step by step instructions to get it working (in Dutch): https://bit.ly/smartthings-domoticz.tontze wrote: Saturday 06 February 2021 13:44 I believe this is doable on node-red, but how, is there a tutorial somewhere ?
https://robothuis.nl, RPi4B, RFXCOM XL, Aeotec Z-Stick, ESP Easy, Weatherstation, several switches and sensors, Ikea Trädfri, Philips Hue, Foscam, Reolink, Lyric T6, Ring
- waaren
pgielen wrote: Thursday 04 March 2021 9:09 I just posted a blog post about my own experiences with the Aeotec Smart Home Hub (Works with SmartThings) and step by step instructions to get it working (in Dutch): https://bit.ly/smartthings-domoticz.
Would you be OK if someone translates your blog and add the translated article to the domoticz wiki?
tontze
Thnx for the golden answers ! These helps me a LOT !
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
tontze
Thnx, i can see in debug node that virtual switch is changing in node-red between 0 and 1, this is what i came up with (does not switch smartthings light tho): Ofcourse i would like this to be working other way around too, switching in smartthings, switches state in domoticzFireWizard wrote: Sunday 21 February 2021 23:13 Hello @tontze,
But some hints.
Replace the Debug node with the Smartthings node.Code: Select all
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- FireWizard
Hello @ tontze
You wrote:
Can you publish your flow?
You wrote:
I suggest that we make this first.Thnx, i can see in debug node that virtual switch is changing in node-red between 0 and 1, this is what i came up with (does not switch smartthings light tho):
This is very well possible but I suggest we do this afterwards, when the other way is working.Ofcourse i would like this to be working other way around too, switching in smartthings, switches state in domoticz
tontze
I really appreciate you helping me FireWizard, i really doFireWizard wrote: Sunday 14 March 2021 22:46 Hello @ tontze
By publishing, do you mean this :
[{"id":"f1bbcae6.fbeeb","type":"mqtt in","z":"e1366dff.7c47f8","name":"","topic":"domoticz/out","qos":"0","datatype":"json","broker":"f9f13036.e28b58","x":110,"y":560,"wires":[["6805674d.4e1d48"]]},{"id":"6805674d.4e1d48","type":"switch","z":"e1366dff.7c47f8","name":"Filter Switch","property":"payload.idx","propertyType":"msg","rules":[{"t":"eq","v":"11","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":310,"y":560,"wires":[["be2d15e0.7d88a"]]},{"id":"be2d15e0.7d88a","type":"function","z":"e1366dff.7c47f8","name":"","func":"msg.topic = \"switch\";\nmsg.payload = msg.payload.nvalue;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":500,"y":540,"wires":[["c2df7e0f.2b59e8","7ee580f7.e4755"]]},{"id":"c2df7e0f.2b59e8","type":"smartthings-node-onoff","z":"e1366dff.7c47f8","conf":"666c7bf2.c25414","name":"Kitchen Lights","device":"e162c5c6-80d2-46e1-aaef-741a39f934fe","x":700,"y":500,"wires":[["5ad15b3c.79e194"]]},{"id":"5ad15b3c.79e194","type":"debug","z":"e1366dff.7c47f8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":910,"y":500,"wires":[]},{"id":"7ee580f7.e4755","type":"debug","z":"e1366dff.7c47f8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":690,"y":580,"wires":[]},{"id":"f9f13036.e28b58","type":"mqtt-broker","name":"localhost","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"666c7bf2.c25414","type":"smartthings-config","name":"ST","token":"xxx"}]End of that page it says :
"For example, to turn on a switch you can send a message to its device node:
topic: "switch",
payload: {
value: 1
So i believe we just need to get output formatted and forwarded correctly to make it work ?)
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- FireWizard
Hello @tontze
I have loaded the Smartthings nodes.
I found the msg.topic quite confusing.
So, as I'm not sure either msg.topic should be set to "switch" or msg.paylaod.topic should be set to "switch" or or both.
I configured them both, just to be sure.
Can you do the following:
1, Create in Hardware a Dummy (Does nothing, use for virtual switches only) device.
2. Press "Create Virtual Sensors" and create a virtual Switch. Give it a name you like and note down its IDX number.
Try the following flow:
3. Configure the MQTT input node to your MQTT settings.
4. Replace in the "Filter Switch" the IDX number to the one you noted previously.
5 Test if you switch the virtual Switch in Domoticz if your light do go On and/or OFF.
Let me know.
See the complete flow below:
Let me know.
[{"id":"f1bbcae6.fbeeb","type":"mqtt in","z":"4e92e308.9bb32c","name":"","topic":"domoticz/out","qos":"0","datatype":"json","broker":"f9f13036.e28b58","x":210,"y":280,"wires":[["6805674d.4e1d48"]]},{"id":"6805674d.4e1d48","type":"switch","z":"4e92e308.9bb32c","name":"Filter Switch","property":"payload.idx","propertyType":"msg","rules":[{"t":"eq","v":"12","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":410,"y":280,"wires":[["a161ac66.49283"]]},{"id":"c2df7e0f.2b59e8","type":"smartthings-node-onoff","z":"4e92e308.9bb32c","conf":"666c7bf2.c25414","name":"Kitchen Lights","device":"e162c5c6-80d2-46e1-aaef-741a39f934fe","x":880,"y":280,"wires":[["5ad15b3c.79e194"]]},{"id":"5ad15b3c.79e194","type":"debug","z":"4e92e308.9bb32c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1090,"y":280,"wires":[]},{"id":"7ee580f7.e4755","type":"debug","z":"4e92e308.9bb32c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":870,"y":340,"wires":[]},{"id":"a161ac66.49283","type":"function","z":"4e92e308.9bb32c","name":"Function Kitchen Light","func":"msg.topic = \"switch\";\nmsg.payload =\n{\n topic: \"switch\",\n payload: {\n value: msg.payload.nvalue\n }\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":640,"y":280,"wires":[["c2df7e0f.2b59e8","7ee580f7.e4755"]]},{"id":"f9f13036.e28b58","type":"mqtt-broker","name":"localhost","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"666c7bf2.c25414","type":"smartthings-config","name":"ST","token":"xxx"}]-
tontze
Nope. your example didnt work, but i figured it out from your example and from my earlier inject node. This is working:
It is working now
I can switch smartthings switch from domoticz
Now just need to make it other way around
[{"id":"6b48d27b.84f02c","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"25239b40.b1f3bc","type":"mqtt in","z":"6b48d27b.84f02c","name":"","topic":"domoticz/out","qos":"0","datatype":"json","broker":"f9f13036.e28b58","x":150,"y":180,"wires":[["cc094159.4c585"]]},{"id":"cc094159.4c585","type":"switch","z":"6b48d27b.84f02c","name":"Filter Switch","property":"payload.idx","propertyType":"msg","rules":[{"t":"eq","v":"11","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":350,"y":180,"wires":[["a161ac66.49283"]]},{"id":"c6497977.29095","type":"smartthings-node-onoff","z":"6b48d27b.84f02c","conf":"666c7bf2.c25414","name":"Kitchen Lights","device":"e162c5c6-80d2-46e1-aaef-741a39f934fe","x":820,"y":180,"wires":[["20cab71c.d8dc48"]]},{"id":"20cab71c.d8dc48","type":"debug","z":"6b48d27b.84f02c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1030,"y":180,"wires":[]},{"id":"df6244d0.37a72","type":"debug","z":"6b48d27b.84f02c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":810,"y":240,"wires":[]},{"id":"a161ac66.49283","type":"function","z":"6b48d27b.84f02c","name":"Function Kitchen Light","func":"var msg = {\n topic: \"switch\",\n payload: {\n value: msg.payload.nvalue\n }\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":580,"y":180,"wires":[["c6497977.29095","df6244d0.37a72"]]},{"id":"f9f13036.e28b58","type":"mqtt-broker","name":"localhost","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"666c7bf2.c25414","type":"smartthings-config","name":"ST","token":"xxxxxxxxxxxxxxxxxxx"}]-----------------------------------------
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- FireWizard
Hello @tontze
You said:
I already said:
I have one small remark to your code.
The first line of your code shows:
It is not necessary to declare the variable msg, as this is already done (by default).
So the contents of the function node should become:
Or if this is not possible can you test the following flow:
I expect you will see, something like:
If this is the case, can you test the following flow:
Connect the output of the Smartthings node to the input of the "Function" node.
And configure the MQTT output node, according to your configuration.
Awaiting your response,
You said:
I was not sure about the example in the Smartthings documentation.Nope. your example didn't work, but i figured it out from your example and from my earlier inject node. This is working:
I already said:
But perfect, that it is working now.I found the msg.topic quite confusing.
So, as I'm not sure either msg.topic should be set to "switch" or msg.payload.topic should be set to "switch" or or both.
and if you click in the function node you will see a small yellow triangle with the text: 'msg' is already defined.var msg = {
msg = {
topic: "switch",
payload: {
return msg;Can you operate the lamp, connected to the Smartthings node, and see if something is shown in the last "Debug"node.It is working nowI can switch smartthings switch from domoticz
[{"id":"7c7791de.29521","type":"inject","z":"4e92e308.9bb32c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":280,"wires":[["b994970e.927188"]]},{"id":"b6f73d8f.ef4cc8","type":"smartthings-node-onoff","z":"4e92e308.9bb32c","conf":"666c7bf2.c25414","name":"Kitchen Lights","device":"e162c5c6-80d2-46e1-aaef-741a39f934fe","x":640,"y":280,"wires":[["635ae9af.854d9"]]},{"id":"b994970e.927188","type":"function","z":"4e92e308.9bb32c","name":"Function Kitchen Light","func":"msg = {\n topic: \"update\",\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":400,"y":280,"wires":[["b6f73d8f.ef4cc8"]]},{"id":"635ae9af.854d9","type":"debug","z":"4e92e308.9bb32c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":850,"y":280,"wires":[]},{"id":"666c7bf2.c25414","type":"smartthings-config","name":"ST","token":"xxx"}]If this is the case, can you test the following flow:
[{"id":"191ec999.485656","type":"function","z":"4e92e308.9bb32c","name":"","func":"if (msg.payload.value === 1 )\n{\nmsg.payload = { \"command\": \"switchlight\", \"idx\": 11, \"switchcmd\": \"On\" };\n}\nelse if ( msg.payload.value === 0 )\n{\nmsg.payload = { \"command\": \"switchlight\", \"idx\": 11, \"switchcmd\": \"Off\" };\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1040,"y":100,"wires":[["d805ccf1.c0753"]]},{"id":"d805ccf1.c0753","type":"mqtt out","z":"4e92e308.9bb32c","name":"","topic":"domoticz/in","qos":"1","retain":"false","broker":"f9f13036.e28b58","x":1230,"y":100,"wires":[]},{"id":"f9f13036.e28b58","type":"mqtt-broker","name":"localhost","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]Regards
