Dial : customize grey dial bezel color depending on value
FuReT
Post by FuReT »
Hello !
I'm using the dial block and i'm trying to switch the dial bezel color depending on the current value of the Dial.
I got it working with standard block but not able to make it work with the default dial...
My block :
blocks['nrj_conso'] = {
idx: 1027,
title: 'Conso',
type: 'dial',
values: ['Usage','CounterToday'],
min: 0,
max: 7000,
width: 3,
showunit: true,
shownumbers: false,
showring: true,
animation: false,
flash: true,
last_update: false
Ths css i want to apply :
.warning {
background-color: #bb2424;
My function on custom.js :
function getStatus_nrj_conso(block) {
var value = block.device.Usage;
if (parseFloat(value) > 100 ) {
block.addClass='warning';
} else {
block.addClass='';
If someone can help ;)
Thanks in advance.
Lokonli
Re: Dial : customize grey dial bezel color depending on value
Post by Lokonli »
FuReT wrote: Saturday 20 February 2021 0:16 Hello !
My block :
idx: 1027,
title: 'Conso',
type: 'dial',
min: 0,
max: 7000,
width: 3,
showunit: true,
shownumbers: false,
showring: true,
animation: false,
flash: true,
last_update: false
.warning {
} else {
block.addClass='';
Thanks in advance.
The getStatus functions are not supported for dial blocks yet.
The standard blocks and dial blocks currently are almost completely independent implementations. I'm investigating how to merge the two.
FuReT
Post by FuReT »
Ok I was not knowing for getStatus, not indicated on the doc page..
Thanks a lot to take care of my request ;)
