Dashticz v3.7.3 beta Topic is solved
smaus
Re: Dashticz v3.7.3 beta
Post by smaus »
Lokonli wrote: Thursday 18 February 2021 22:48
smaus wrote: Thursday 18 February 2021 21:31 type=command&param=getuservariables error js/domoticz-api.js:107
has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource.
hmm, not a typical error.
Locate this network request on the network tab of Devtools.
If you open this network request directly in a browser window, what is then the Domoticz reply?
I get this
"result" :
"LastUpdate" : "2020-01-03 14:29:05",
"Name" : "UV_DomoticzIP",
"Type" : "2",
"Value" : "192.168.2.159:8084",
"idx" : "1"
"status" : "OK",
"title" : "GetUserVariables"
but my ip is 192.168.1.159:8084
Lokonli
Post by Lokonli »
smaus wrote: Friday 19 February 2021 17:08
I get this
"result" :
"Type" : "2",
"idx" : "1"
"status" : "OK",
That looks ok, no errors.
What is your Domoticz version?
In DevTools do you see any other error on the console tab?
And which user messages do you get on the console tab?
smaus
Post by smaus »
Lokonli wrote: Friday 19 February 2021 18:11
I get this
"result" :
"Type" : "2",
"idx" : "1"
"status" : "OK",
Value" : "192.168.2.159:8084 but my ip is 192.168.1.159:8084?
madpatrick
Domoticz version: 2025.1
Post by madpatrick »
What is in the field UV_DomoticzIP in your Uservariables ?
check in settings/uservariables and search for this field
-= HP server GEN11 =- OZW -=- Toon2 (rooted) -=- Domoticz v2025.1 -=- Dashticz v3.14b on Tab8" =-
Lokonli
Post by Lokonli »
I get this
"result" :
"Type" : "2",
"idx" : "1"
"status" : "OK",
Probably the variable was created by a Domoticz script or device. It's not used by Dashticz.
smaus
Post by smaus »
Lokonli wrote: Friday 19 February 2021 21:49
solved the problem, i intall v2 and that one was worken partially but i get a error that set me on the right path, i was forgoten mij passworth and my username
Vomera
Post by Vomera »
Hi ! I am figuring out an issue with the styling.
Today i added air quality.
Domoticz:
Dashticz
What i can style =
Text and class, but not the ICON.
I can do it with other things perfectly, but here the icon doesnt change. So i thought maybe i used an icon from the newest fontawesome, so i took one i use with other data, but still it doesnt change. Could it be that its not scripted? For what i can see its just a data block.
in the mean time i will update to 3.7.5 > 3.7.5 gives also the same result.
Lucht now 10 and shows green how it supposed to be.
custom.js
// Luchtkwaliteit
	function getStatus_13344(block){
	var Data = block.device.Data;
   if(parseFloat(Data)>300){
   block.addClass='luchtbovendriehonderd';
   block.icon = 'fas fa-skull-crossbones';
   else if(parseFloat(Data) >201){
	 block.addClass='luchtboventweehonderd';
      block.icon = 'far fa-sad-tear';
   else if(parseFloat(Data) >151){
	   block.addClass='luchtbovenhonderdvijftig';
       block.icon = 'far fa-frown';
   else if(parseFloat(Data) >101){
	   block.addClass='luchtbovenhonderd';
         block.icon = 'far fa-meh';
   else if(parseFloat(Data) >51){
	   block.addClass='luchtbovenvijtig';
	   block.icon = 'far fa-smile';
   else if(parseFloat(Data) >0){
	   block.addClass='luchtbovennul';
       block.icon = 'fas fa-battery-full';
   else {
	 block.addClass= 'none';
     block.icon = 'far fa-smile-beam';
Output JSON idx 13344
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"BatteryLevel" : 255,
			"CustomImage" : 0,
			"Data" : "10 ppm",
			"Description" : "",
			"Favorite" : 0,
			"HardwareID" : 7,
			"HardwareName" : "DUMMY",
			"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
			"HardwareTypeVal" : 15,
			"HaveTimeout" : false,
			"ID" : "17470",
			"LastUpdate" : "2021-03-05 15:20:01",
			"Name" : "Lucht",
			"Notifications" : "false",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"Protected" : false,
			"Quality" : "Excellent",
			"ShowNotifications" : true,
			"SignalLevel" : "-",
			"SubType" : "Voltcraft CO-20",
			"Timers" : "false",
			"Type" : "Air Quality",
			"TypeImg" : "air",
			"Unit" : 1,
			"Used" : 1,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "13344"
edit:
This is what i see when i inspect the code:
edit1: 3.7.5 gives also the same result.
madpatrick
Vomera wrote: Friday 05 March 2021 15:38 Hi ! I am figuring out an issue with the styling.
What i can style =
(in the mean time i will update to 3.7.5.
custom.js
// Luchtkwaliteit
   else {
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"CustomImage" : 0,
			"Data" : "10 ppm",
			"Description" : "",
			"Favorite" : 0,
			"HardwareID" : 7,
			"ID" : "17470",
			"Name" : "Lucht",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"Timers" : "false",
			"TypeImg" : "air",
			"Unit" : 1,
			"Used" : 1,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "13344"
edit:
How does your block looks like.
It is possible to changre this icon in there also
add this to your block for example
icon: 'fas fa-cloud-sun'
Vomera
Post by Vomera »
Custom.css
.luchtbovennul {
	background: rgba(0,153,102,1.0) !important;
    background-clip: padding-box;
	color: white;
	icon: 'fas fa-cloud-sun';
I add it but still the air.png shows up, maybe i think its coded like this.
madpatrick
How does your block looks in CONFIG.JS ?
Vomera
Post by Vomera »
madpatrick wrote: Friday 05 March 2021 15:52 How does your block looks in CONFIG.JS ?
config.js
blocks[13344] = {} // Luchtkwaliteit
blocks[13344]['width'] = 4;
blocks[13344]['title'] = '';
blocks[13344]['icon'] = 'fas fa-gamepad';
Change it to gamepad for example, use it also on another block
Lokonli
Post by Lokonli »
Domoticz:
Dashticz
What i can style =
custom.js
// Luchtkwaliteit
   else {
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"CustomImage" : 0,
			"Data" : "10 ppm",
			"Description" : "",
			"Favorite" : 0,
			"HardwareID" : 7,
			"ID" : "17470",
			"Name" : "Lucht",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"Timers" : "false",
			"TypeImg" : "air",
			"Unit" : 1,
			"Used" : 1,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "13344"
edit:
It is (was) a bug.
For air quality not an icon, but the image 'air.png' is used by default.
Setting an icon didn't work in that case: always the image was shown.
I've made a fix in latest beta. Can you test?
Vomera
Post by Vomera »
Thanks! :) Then i know i didnt do anything wrong :D haha i will test it tomorrow and will let you know!
Vomera
Post by Vomera »
Lokonli wrote: Saturday 06 March 2021 18:20
It is (was) a bug.
Yes! you fixed another bug! it works now!
