Add LSC smart movement sensor and door sensor to domoticz
Colin
Post by Colin »
I installed domoticz with mosquito (MQTT Client Gateway with LAN interface). Now I would like to activate in domoticz my flashed (tuya-convert ) LSC smart movement sensor and door sensor. Only I have no idea how I could do this. Be new in domoticz. Don't know all the ins and outs of the program yet.
The smart power pug worked immediately. But the sensors are a bit more difficult than I thought. Can somebody tell me please how to do this?
Below is what the sensors transmit. And after that they shutdown. So I need something that see that they turned on.
Smart Door Sensor
00:00:00 CFG: Loaded from flash at F7, Count 64
00:00:00 Project tasmota Tasmota Version 8.2.0(tasmota)-STAGE
00:00:00 WIF: Connecting to AP1 Domotica in mode 11N as tasmota-4832...
00:00:05 WIF: Connected
00:00:05 HTP: Web server active on tasmota-4832 with IP address 192.168.0.4
00:00:06 MQT: Attempting connection...
00:00:06 MQT: Connected
00:00:06 MQT: tele/tasmota/LWT = Online (retained)
00:00:06 MQT: cmnd/tasmota/POWER =
00:00:06 MQT: tele/tasmota/INFO1 = {"Module":"Generic","Version":"8.2.0(tasmota)","FallbackTopic":"cmnd/DVES_ACD2E0_fb/","GroupTopic":"cmnd/tasmotas/"}
00:00:06 MQT: tele/tasmota/INFO2 = {"WebServerMode":"Admin","Hostname":"tasmota-4832","IPAddress":"192.168.0.4"}
00:00:06 MQT: tele/tasmota/INFO3 = {"RestartReason":"Power On"}
00:00:10 MQT: tele/tasmota/STATE = {"Time":"1970-01-01T00:00:10","Uptime":"0T00:00:12","UptimeSec":12,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"Wifi":{"AP":1,"SSId":"Domotica","BSSId":"06:1D:AA:B5:5D:00","Channel":6,"RSSI":74,"Signal":-63,"LinkCount":1,"Downtime":"0T00:00:06"}}
Smart Movement Sensor
00:00:00 CFG: Loaded from flash at F9, Count 11
00:00:00 Project tasmota Tasmota Version 8.1.0.2(tasmota)-2_6_1
00:00:00 WIF: Connecting to AP1 Domotica in mode 11N as tasmota-2720...
00:00:05 HTP: Web server active on tasmota-2720 with IP address 192.168.0.2
00:00:06 MQT: tele/tasmota/INFO1 = {"Module":"Generic","Version":"8.1.0.2(tasmota)","FallbackTopic":"cmnd/DVES_40AAA0_fb/","GroupTopic":"cmnd/tasmotas/"}
00:00:06 MQT: tele/tasmota/INFO2 = {"WebServerMode":"Admin","Hostname":"tasmota-2720","IPAddress":"192.168.0.2"}
00:00:06 MQT: tele/tasmota/INFO3 = {"RestartReason":"Power on"}
00:00:11 MQT: tele/tasmota/STATE = {"Time":"1970-01-01T00:00:11","Uptime":"0T00:00:13","UptimeSec":13,"Heap":31,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":26,"MqttCount":1,"Wifi":{"AP":1,"SSId":"Domotica","BSSId":"06:1D:AA:B5:5D:00","Channel":6,"RSSI":88,"Signal":-56,"LinkCount":1,"Downtime":"0T00:00:06"}}
[code]
Regards,
Colin
AchilleTalon
Domoticz version: 2023.2
Re: Add LSC smart movement sensor and door sensor to domoticz
Post by AchilleTalon »
i just joined the forum and found your message. I just bought two LSC movement sensors (one of each type) and I'm interested in knowing how complex the flash process was, but also what template you used for your device after you flashed it (tasmota -custom firmware- comes with pre-defined templates but lets you input yours for new devices).
I'm using Shelly switches, flashed with tasmota, MQTT (with lLAN interface), and their integration ni domoticz works like a charm. May be I can share my experience once I have flashed mine and started to play with them.
