Hello
I have a question about the logitech squeezebox block.
If the title is too long the comand buttons get off of my block.
Is there any solution to at least truncate the title to a maximum lenght or, even better, to force the title to display on maximum 2 or 3 lines for example and make it scroll if it is too long ?
Thank you madPatrick but this is not exactly what I'm trying to achieve.
I already changed the font size and img size and buttons size to my needs.
Problem here is that depending on the title size the buttons line is pushed down.
The title could be very long and changing the font size will never be enough.
Do you think the block height could change depending on the title length so the buttons stay inside the block ?
Hello
I'm using the "openpopupOn" option to show a snapshot of my main door camera when someone rings the doorbell.
The snapshot pops up when someone rings the bell but this snapshot is too large for the popup frame.
The camera provides a 1920*1080 snapshot where I'd like it to fit the 720*480 popup frame.
Is it possible to make the snapshot fit the popup frame no matter what size it is ?
Thank you
You said that you changed the font size, center icons etc of buttons.
Do you have the css script for that? Im looking to center the icons in the buttons...
Is it possible that more then one domoticz system is giving input to a Dashticz interface? Problem is that I am using Zigbee2MQTT and I am encountering a 255 device limit of Domoticz. Setting up a second Domoticz as slave does not work due to another problem that information from a python device is not shared.
sanderjohan wrote: Friday 12 March 2021 15:56
Not really.
However, I think you could show a second Dashticz instance inside of a frame ...
can you clarify that 255 limit ? i have now 286 entries - devices - scenes - dummy switches - etc .. works fine. i use 1 master domoticz (with the 286 entries / mix from master-slave) and a secondary which is more central in the house with the zwave stick.
I think the limitation is 255 devices per hardware 'device'.
After a long period to read the very complete tutorial and read you all, thank's a lot to the devs for their work!
I present you my board on my iPad 2, mounted on the wall with a support 3d printed
MyDashticz on the wall (for forum).jpg (378.18 KiB) Viewed 8512 times
I put my config.js and custom.js in a thread viewtopic.php?f=67&t=35831 with some questions if you have any ideas to help me improve my dash
Hello.
does anyone know if it is possible to exclude a screen from the auto_slide_pages config ?
I would like my dashboard to auto slide from screen 1 to screen 3 and avoid screen 4.
Thank you for your help.
D.
damdub wrote: Tuesday 13 April 2021 12:05
Hello.
D.
Hi, I have a dashboard with several dials, but find it very annoying that when you hover over them with the cursor, the dial changes. Is it possible to disable that hover animation?
And for good measure, is it also possible to disable interaction with blocks? this would make scrolling on an iPad a lot easier
damdub wrote: Monday 15 February 2021 14:55
Hello
Sorry for the latency... I'd suggest you try the material skin (a plug-in in Squeezeserver). Then create an iFrame for it. It is so much prettier than the standard squeezebox players.
- Running LMS, Domoticz and Dashticz on a windows 11 laptop.
- LMS (11 players) / Hue (26 lights, 2 switches) / Z-wave (14 devices) / Toon (unrooted) / Chromecast
stephanvdplas wrote: Tuesday 10 August 2021 15:18
This is a great suggestion, thanks! I had been under the mistaken impression that the Logitech Media Server only worked with proprietary gadgets, so hadn't checked it out. I installed it standalone on a Raspberry Pi3 together with Dashticz, and it runs very well. On the Pi, the hardest part was getting the external USB sound card to be recognized, but that's not unusual.
