I have started trying Dashticz on my IPAD.
I noticed that when I start dashticz, for a while all is ok but after some minutes it seems to freeze (the clock widget is no more advancing and the timestamp is stopped).
Is there some settings I have to tune or this is a normal behaviour with Ipads?
Thank you
Dashticz and IPAD - freezing
Lokonli
Re: Dashticz and IPAD - freezing
I did not see that before ...
Maybe your config parameters domoticz_refresh or dashticz_refresh are too low.
Or you have a very high number of Domoticz devices: add the devices you want to show in Dashticz to a room plan in Domoticz, and use this room plan in Dashticz.
If that's not the case, could you test with an empty dashboard, and then start adding blocks until the error occurs?
Yes I will try with no devices and will add a couple of blocks.
Currently I only have the time block, 5 buttons and 3 dials.
I will let you know.
My dashticz is on synology web server and domoticz is on a VMM inside Synology itself (domoticz is running since lot of time).
Thank you
Thank you
