Use tado geofencing in domoticz Topic is solved
Phil C
Post by Phil C »
Hi, not sure where to put this.
I have tado linked to domo for temp.
Is it possible to use the geofencing function through domoticz to turn a light on for example when I approach home ?
Phil
technohippy29
Re: Use tado geofencing in domoticz
Post by technohippy29 »
There is a switch called "<home name> Away". I believe this will show as "on" when you are away, and "off" when you are home.
Phil C
Post by Phil C »
Superb, found it, thank you.
technohippy29
Cool - does it work btw? Sorry haven't tried it but would use it if it does!
