zigate tuya siren
Re: zigate tuya siren
For the temperature/humidity, please provide logs, I need more less 15 minutes of logs , without I cannot really help.
my log:pipiche wrote: Sunday 31 January 2021 11:39 For the temperature/humidity, please provide logs, I need more less 15 minutes of logs , without I cannot really help.
https://www.dropbox.com/s/knj40mxxiqxac ... e.txt?dl=0
This is very strange, wometimes the speaker has a soft "tik" when it is not in use.
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
looks not very usefull. Can you do the followingmarktn wrote: Sunday 31 January 2021 17:02 my log:
1/ update to latest version
git pull3/ leave it for while
then drop me the :
* log
* export.json
I have the similar behaviourThis is very strange, wometimes the speaker has a soft "tik" when it is not in use.
Sorry for my late response. I am in the middle of a home improvement. Of course some extra wire for domoticapipiche wrote: Sunday 31 January 2021 18:09looks not very usefull. Can you do the followingmarktn wrote: Sunday 31 January 2021 17:02 my log:
1/ update to latest version2/ enable debugTuya ( from the Web Admin Tool -> Debug menu (advanced)Code: Select all
git pull
then drop me the :
* log
* export.json
I have put some logs in my dropbox, i hope that are the one you want.
https://www.dropbox.com/sh/dim7nyvhhq1e ... NG28a?dl=0
This is what i see, maybe i read it wrong.
- firefox_2021-02-12_21-31-06.jpg (25.79 KiB) Viewed 1935 times
From what I saw in th export(1).json , it looks like the pairing was not done correctly.
Can you try to remove all devices in Domoticz, and then redo the pairing ? And then sending the expor.json of Plugin devices RAW (json)
redo paring done!pipiche wrote: Saturday 13 February 2021 19:00 From what I saw in th export(1).json , it looks like the pairing was not done correctly.
https://www.dropbox.com/s/lwaag4g3ek2xi ... .json?dl=0
ANy issue in the log ? There is something no happening during the pairing process .
Can you get the latest beta ( 4.12.126 ) and then do once more removing the devices and redo the pairing ?
pipiche wrote: Saturday 13 February 2021 21:25 ANy issue in the log ? There is something no happening during the pairing process .
I did update and paring, but it is not working.
2021-02-16 18:54:59.842 Status: (Zigate) [ MainThread] 26 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-16.txt
2021-02-16 18:54:59.881 Status: (Zigate) [ MainThread] Transport mode: USB
2021-02-16 18:54:59.881 Status: (Zigate) ZiGate plugin start with limited capabilities due to Domoticz version below 2020.2 (Build 12741)
2021-02-16 18:54:59.882 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0
2021-02-16 18:54:59.887 Status: (Zigate) [ZiGateWriter_16] ZigateTransport: writer_thread Thread start.
2021-02-16 18:54:59.887 Status: (Zigate) [ZiGateForwarder_16] ZigateTransport: thread_processing_and_sending Thread start.
2021-02-16 18:54:59.888 Status: (Zigate) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2021-02-16 18:55:09.577 Status: (Zigate) [ZiGateForwarder_16] ZiGate Classic
2021-02-16 18:55:09.577 Status: (Zigate) [ZiGateForwarder_16] Installer Version Number: 031c
2021-02-16 18:55:18.623 Status: (Zigate) [ZiGateForwarder_16] Zigate addresses ieee: 00158d0001ee040a , short addr: 0000
2021-02-16 18:55:18.623 Status: (Zigate) [ZiGateForwarder_16] Network state UP, PANID: 4f3e extPANID: 0x2fe14f25179533d9 Channel: 11
2021-02-16 18:55:23.414 Status: (Zigate) [ MainThread] Request Disabling Accepting new Hardware
2021-02-16 18:55:25.026 Status: (Zigate) [ZiGateForwarder_16] Accepting new Hardware: Disable
2021-02-16 18:55:25.530 Status: (Zigate) [ZiGateForwarder_16] Number of devices recently active in Zigate = 16
2021-02-16 18:55:25.530 Status: (Zigate) [ZiGateForwarder_16] [00] DevID = 00 Network addr = c2bb IEEE = 00158d0003cc6bae LQI = 149 Power = 00 Model = lumi.sensor_ht ( Sensor badkamer )
2021-02-16 18:55:25.530 Status: (Zigate) [ZiGateForwarder_16] [01] DevID = 01 Network addr = 746c IEEE = 00158d00036b5243 LQI = 096 Power = 00 Model = lumi.weather ( 3D printer )
2021-02-16 18:55:25.530 Status: (Zigate) [ZiGateForwarder_16] [02] DevID = 02 Network addr = 2172 IEEE = 00158d00045c2862 LQI = 073 Power = 00 Model = lumi.sensor_magnet.aq2 ( Deursensor schuifdeur )
2021-02-16 18:55:25.530 Status: (Zigate) [ZiGateForwarder_16] [03] DevID = 03 Network addr = 3478 IEEE = 00158d0005225f00 LQI = 095 Power = 00 Model = lumi.sensor_magnet.aq2 ( Deursensor voordeur )
2021-02-16 18:55:25.531 Status: (Zigate) [ZiGateForwarder_16] [04] DevID = 04 Network addr = 907a IEEE = 00158d00056e67a4 LQI = 072 Power = 00 Model = lumi.sensor_smoke ( Rookmelder zolder )
2021-02-16 18:55:25.531 Status: (Zigate) [ZiGateForwarder_16] [05] DevID = 06 Network addr = 5554 IEEE = 00158d000490afab LQI = 072 Power = 00 Model = lumi.sensor_smoke ( rookmelder kantoor )
2021-02-16 18:55:25.531 Status: (Zigate) [ZiGateForwarder_16] [06] DevID = 07 Network addr = c52b IEEE = 00158d000572a925 LQI = 078 Power = 00 Model = lumi.sensor_smoke ( Rookmelder wasmachine )
2021-02-16 18:55:25.531 Status: (Zigate) [ZiGateForwarder_16] [07] DevID = 08 Network addr = 5f8f IEEE = 00158d0005884092 LQI = 149 Power = 00 Model = lumi.sensor_smoke ( Rookmelder hal )
2021-02-16 18:55:25.531 Status: (Zigate) [ZiGateForwarder_16] [08] DevID = 28 Network addr = 8b16 IEEE = 000d6ffffe485188 LQI = 069 Power = 01 Model = TRADFRI bulb E27 WS opal 980lm ( Woonkamer bankstel )
2021-02-16 18:55:25.531 Status: (Zigate) [ZiGateForwarder_16] [09] DevID = 29 Network addr = f1f1 IEEE = 680ae2fffe413429 LQI = 157 Power = 01 Model = TRADFRI control outlet ( TV boven schakelaar )
2021-02-16 18:55:25.531 Status: (Zigate) [ZiGateForwarder_16] [10] DevID = 2a Network addr = d4ad IEEE = 00158d000444ee2f LQI = 117 Power = 01 Model = lumi.relay.c2acn01 ( Voortuin relay )
2021-02-16 18:55:25.532 Status: (Zigate) [ZiGateForwarder_16] [11] DevID = 2b Network addr = f295 IEEE = ec1bbdfffeb8ab2a LQI = 081 Power = 01 Model = TRADFRI bulb E27 WW clear 250lm ( )
2021-02-16 18:55:25.532 Status: (Zigate) [ZiGateForwarder_16] [12] DevID = 2c Network addr = 9ab3 IEEE = ec1bbdfffe468a93 LQI = 150 Power = 01 Model = TRADFRI bulb GU10 WS 400lm ( Woonkamer salontafel_2 )
2021-02-16 18:55:25.532 Status: (Zigate) [ZiGateForwarder_16] [13] DevID = 2d Network addr = 7f15 IEEE = ec1bbdfffe986a27 LQI = 151 Power = 01 Model = TRADFRI bulb GU10 WS 400lm ( Woonkamer salontafel_1 )
2021-02-16 18:55:25.532 Status: (Zigate) [ZiGateForwarder_16] [14] DevID = 2e Network addr = 3764 IEEE = 00158d0003f05121 LQI = 104 Power = 01 Model = lumi.relay.c2acn01 ( Badkamer relay )
2021-02-16 18:55:25.532 Status: (Zigate) [ZiGateForwarder_16] [15] DevID = 2f Network addr = 5a7a IEEE = 680ae2fffe373006 LQI = 128 Power = 01 Model = TRADFRI bulb GU10 WS 400lm ( Woonkamer salontafel_3 )
2021-02-16 18:55:28.435 Status: (Zigate) [ MainThread] Zigate set to Certification : CE
2021-02-16 18:55:28.435 Status: (Zigate) [ MainThread] Start Group Management
2021-02-16 18:55:28.459 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c2 FileVersion: 23028631 Size: 179390 Bytes Filename: 159701-2.1-TRADFRI-wireless-dimmer-2.3.028.ota.ota.signed
2021-02-16 18:55:28.477 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2203 FileVersion: 23007631 Size: 207870 Bytes Filename: 100355342-2.1-TRADFRI-bulb-ws-gu10-2.3.007.ota.ota.signed
2021-02-16 18:55:28.492 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2801 FileVersion: 13009572 Size: 178366 Bytes Filename: 10035515-TRADFRI-bulb-cws-1.3.009.ota.ota.signed
2021-02-16 18:55:28.507 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4201 FileVersion: 12217572 Size: 173246 Bytes Filename: 159698-TRADFRI-driver-lp-1.2.217.ota.ota.signed
2021-02-16 18:55:28.522 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4202 FileVersion: 12217572 Size: 173246 Bytes Filename: 159697-TRADFRI-driver-hp-1.2.217.ota.ota.signed
2021-02-16 18:55:28.540 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4203 FileVersion: 20022623 Size: 208830 Bytes Filename: 191100-4.1-TRADFRI-sy5882-driver-ws-2.0.022.ota.ota.signed
2021-02-16 18:55:28.555 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11ca FileVersion: 21024631 Size: 180926 Bytes Filename: 10043101-3.1-TRADFRI-dimmer-2.1.024.ota.ota.signed
2021-02-16 18:55:28.571 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c8 FileVersion: 20022623 Size: 186814 Bytes Filename: 10039874-1.0-TRADFRI-motion-sensor-2-2.0.022.ota.ota.signed
2021-02-16 18:55:28.589 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4206 FileVersion: 21022631 Size: 208254 Bytes Filename: 10047227-1.2-TRADFRI-cv-cct-unified-2.1.022.ota.ota.signed
2021-02-16 18:55:28.606 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2201 FileVersion: 23007631 Size: 208126 Bytes Filename: 10035514-2.1-TRADFRI-bulb-ws-2.3.007.ota.ota.signed
2021-02-16 18:55:28.622 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4101 FileVersion: 12245572 Size: 181118 Bytes Filename: 159495-TRADFRI-transformer-1.2.245.ota.ota.signed
2021-02-16 18:55:28.638 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x1187 FileVersion: 22009631 Size: 186942 Bytes Filename: 10037585-5.1-TRADFRI-connected-blind-2.2.009.ota.ota.signed
2021-02-16 18:55:28.654 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c1 FileVersion: 23014631 Size: 182590 Bytes Filename: 159699-5.1-TRADFRI-remote-control-2.3.014.ota.ota.signed
2021-02-16 18:55:28.670 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x1102 FileVersion: 22005631 Size: 189822 Bytes Filename: 10037603-3.1-TRADFRI-signal-repeater-2.2.005.ota.ota.signed
2021-02-16 18:55:28.685 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2101 FileVersion: 12214572 Size: 168318 Bytes Filename: 159696-TRADFRI-bulb-w-1000lm-1.2.214.ota.ota.signed
2021-02-16 18:55:28.698 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c4 FileVersion: 12214572 Size: 157822 Bytes Filename: 159700-TRADFRI-motion-sensor-1.2.214.ota.ota.signed
2021-02-16 18:55:28.714 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c5 FileVersion: 22010631 Size: 179838 Bytes Filename: 10005778-10.1-TRADFRI-onoff-shortcut-control-2.2.010.ota.ota.signed
2021-02-16 18:55:28.729 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x0002 FileVersion: 165801bc Size: 166270 Bytes Filename: 190579-ncp572b444.ebl.ota.ota.signed
2021-02-16 18:55:28.747 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4204 FileVersion: 20023623 Size: 209086 Bytes Filename: 10038562-2.1-TRADFRI-sy5882-bulb-ws-2.0.023.ota.ota.signed
2021-02-16 18:55:28.765 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x1101 FileVersion: 20024623 Size: 202110 Bytes Filename: 10005777-6.1-TRADFRI-control-outlet-2.0.024.ota.ota.signed
2021-02-16 18:55:28.783 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4103 FileVersion: 21022631 Size: 202878 Bytes Filename: 10046695-1.1-TRADFRI-light-unified-w-2.1.022.ota.ota.signed
2021-02-16 18:55:28.801 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2202 FileVersion: 23007631 Size: 208702 Bytes Filename: 159695-2.1-TRADFRI-bulb-ws-1000lm-2.3.007.ota.ota.signed
2021-02-16 18:55:33.943 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4205 FileVersion: 21022631 Size: 208254 Bytes Filename: 10040611-3.2-TRADFRI-sy5882-unified-2.1.022.ota.ota.signed
2021-02-16 18:55:33.948 Status: (Zigate) [ MainThread] Start Web Server connection
2021-02-16 18:55:33.968 Status: (Zigate) [ MainThread] Web backend for Web User Interface started on port: 9440
2021-02-16 18:55:33.968 Status: (Zigate) [ MainThread] Plugin with Zigate firmware 031c correctly initialized
2021-02-16 18:55:34.253 Status: (Zigate) [ZiGateForwarder_16] TxPower Attenuation : 0 dBm
2021-02-16 18:55:34.094 Error: (Zigate) decode8000 - command miss-match 0806 vs. 0018
2021-02-16 18:55:34.171 Error: (Zigate) decode8000 - command miss-match 0019 vs. 0806
2021-02-16 18:55:34.304 Error: (Zigate) decode8000 - cannot get isqn for MsgType 0019
2021-02-16 18:55:38.747 Status: (Zigate) [ MainThread] There is a newer plugin version available on gitHub
2021-02-16 18:55:38.747 Status: (Zigate) [ MainThread] There is a newer Zigate Firmware version available
2021-02-16 18:55:49.180 Status: Notification: Bewatering achter Haag Uitgeschakeld
2021-02-16 18:55:49.193 Status: Notification: Bewatering achter planten Uitgeschakeld
2021-02-16 18:56:02.423 Status: Notification sent (Email)
2021-02-16 18:56:03.532 Status: New sensors allowed for 5 minutes...
2021-02-16 18:56:15.682 Status: Afzuiging badkamer gaat aan
2021-02-16 18:56:20.250 Error: (Zigate) No transport, write directive to '192.168.1.41:59371' ignored.
2021-02-16 18:56:20.310 Error: (Zigate) No transport, write directive to '192.168.1.41:59372' ignored.
2021-02-16 18:57:02.394 Status: Notification sent (Email)
2021-02-16 18:57:08.320 Status: Notification sent (Email)
2021-02-16 19:00:01.831 Status: Schedule item started! Name: Minke Aquarium, Type: On Time, DevID: 4342, Time: 2021-02-16 19:00:01
2021-02-16 19:05:42.558 Status: Notification: De bel
2021-02-16 19:22:48.375 Status: New sensors allowed for 5 minutes...
2021-02-16 19:23:06.061 Status: (Zigate) [ MainThread] Request Accepting new Hardware for ever
2021-02-16 19:23:06.671 Status: (Zigate) [ZiGateForwarder_16] Accepting new Hardware: On
2021-02-16 19:23:11.155 Error: (Zigate) DeviceExist - Found some inconsistency Inputs: b03b 5c0272fffecea9d6 instead of None
2021-02-16 19:23:12.036 Status: (Zigate) [ZiGateForwarder_16] (b03b/5c0272fffecea9d6) send a Leave indication and will be outside of the network. LQI: 0
2021-02-16 19:23:31.704 Error: (Zigate) DeviceExist - Found some inconsistency Inputs: b986 5c0272fffecea9d6 instead of None
2021-02-16 19:23:32.358 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Active Endpoint Response Ep: 01 LQI: 99
2021-02-16 19:23:32.360 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Request Simple Descriptor for Ep: 01
2021-02-16 19:23:33.621 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Simple Descriptor Response EP: 0x01 LQI: 90
2021-02-16 19:23:33.621 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 ProfileID 0104
2021-02-16 19:23:33.621 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 ZDeviceID 0051
2021-02-16 19:23:33.621 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Application Version 0001
2021-02-16 19:23:33.622 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Cluster IN Count: 04
2021-02-16 19:23:33.622 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Cluster In 1: 0000 (Basic)
2021-02-16 19:23:33.622 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Cluster In 2: 0004 (Groups)
2021-02-16 19:23:33.622 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Cluster In 3: 0005 (Scenes)
2021-02-16 19:23:33.622 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Cluster In 4: ef00
2021-02-16 19:23:33.622 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Cluster OUT Count: 02
2021-02-16 19:23:33.622 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-02-16 19:23:33.623 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Cluster Out 2: 000a (Time)
2021-02-16 19:23:33.826 Status: (Zigate) [0] NEW OBJECT: b986 Model Name: TS0601-sirene
2021-02-16 19:23:38.163 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01) 0:7.85;8115.0
2021-02-16 19:23:38.505 (Zigate) [ZiGateForwarder_16] ReadCluster - 0000 b986/01 attribute Tuya/Zemismat - fffe: 0x00
2021-02-16 19:23:56.823 Status: EventSystem: reset all device statuses...
2021-02-16 19:23:59.287 Status: EventSystem: reset all device statuses...
2021-02-16 19:24:01.858 Status: EventSystem: reset all device statuses...
2021-02-16 19:24:02.394 Status: Notification sent (Email)
2021-02-16 19:24:04.820 Status: EventSystem: reset all device statuses...
2021-02-16 19:24:08.750 Status: EventSystem: reset all device statuses...
2021-02-16 19:24:13.440 Status: EventSystem: reset all device statuses...
2021-02-16 19:24:16.748 (Zigate) UpdateDevice - ($PIR-ligt sterkte) 0:0
2021-02-16 19:24:29.958 Error: (Zigate) No transport, write directive to '192.168.1.41:61151' ignored.
2021-02-16 19:25:02.593 Status: Notification sent (Email)
2021-02-16 19:25:04.325 (Weer) Temp + Humidity + Baro (Tempratuur buiten (online))
2021-02-16 19:25:04.343 (Weer) Wind (Wind (online))
2021-02-16 19:25:04.353 (Weer) General/Visibility (Zichtbaarheid (online))
2021-02-16 19:25:04.361 (Weer) General/Percentage (Wolken (online))
2021-02-16 19:25:50.322 (Zigate) UpdateDevice - ( PIR-voordeur) 1:On
2021-02-16 19:27:02.879 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.9;73.7;3
2021-02-16 19:27:02.889 (Zigate) UpdateDevice - ( Badkamer vocht) 73.7:3
2021-02-16 19:27:02.902 EventSystem: Event triggered: Badkamer afzuiging_2
2021-02-16 19:27:02.903 Status: Afzuiging badkamer gaat uit
2021-02-16 19:29:01.369 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Power-00158d000444ee2f-01) 7.93:7.934482097625732
2021-02-16 19:29:01.379 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01) 0:7.93;8115.94
2021-02-16 19:30:01.082 (Zigate) Zigate receive message processing time Max: 122 ms with an of average: 6 ms
2021-02-16 19:33:28.963 (Zigate) UpdateDevice - ( Zigate temp) 0:19.7;47.0;1;1003.1;3
2021-02-16 19:33:28.974 (Zigate) UpdateDevice - (3D printer vocht) 47.0:1
2021-02-16 19:33:29.000 (Zigate) UpdateDevice - ( Zigate temp) 0:19.7;47.0;1;1003.0;3
2021-02-16 19:33:29.020 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d00036b5243-01) 0:1003.0;3
2021-02-16 19:34:39.438 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Power-00158d000444ee2f-01) 7.84:7.83547306060791
2021-02-16 19:34:39.448 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01) 0:7.84;8116.56
2021-02-16 19:35:00.426 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.8;73.7;3
2021-02-16 19:35:00.431 (Zigate) UpdateDevice - (Badkamer temperatuur) 19.8:19.8
2021-02-16 19:35:00.442 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.8;67.6;1
2021-02-16 19:35:00.447 (Zigate) UpdateDevice - ( Badkamer vocht) 67.6:1
2021-02-16 19:35:00.453 EventSystem: Event triggered: Badkamer afzuiging_2
2021-02-16 19:35:04.431 (Weer) Temp + Humidity + Baro (Tempratuur buiten (online))
2021-02-16 19:35:04.445 (Weer) Wind (Wind (online))
2021-02-16 19:35:04.453 (Weer) General/Visibility (Zichtbaarheid (online))
2021-02-16 19:35:04.461 (Weer) General/Percentage (Wolken (online))
2021-02-16 19:36:11.475 (Zigate) UpdateDevice - ($PIR-ligt sterkte) 0:0
2021-02-16 19:36:11.491 (Zigate) UpdateDevice - ( PIR-voordeur) 0:Off
2021-02-16 19:37:02.941 (Zigate) UpdateDevice - (Badkamerventilatie) 0:Off
2021-02-16 19:40:52.404 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.7;67.6;1
2021-02-16 19:40:52.414 (Zigate) UpdateDevice - (Badkamer temperatuur) 19.7:19.7
2021-02-16 19:40:52.433 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.7;74.2;3
2021-02-16 19:40:52.443 (Zigate) UpdateDevice - ( Badkamer vocht) 74.2:3
2021-02-16 19:41:06.472 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Power-00158d000444ee2f-01) 7.89:7.894878387451172
2021-02-16 19:41:06.482 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01) 0:7.89;8117.5
2021-02-16 19:45:04.561 (Weer) Temp + Humidity + Baro (Tempratuur buiten (online))
2021-02-16 19:45:04.575 (Weer) Wind (Wind (online))
2021-02-16 19:45:04.584 (Weer) General/Visibility (Zichtbaarheid (online))
2021-02-16 19:45:04.591 (Weer) General/Percentage (Wolken (online))
2021-02-16 19:46:06.504 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Power-00158d000444ee2f-01) 7.81:7.810821533203125
2021-02-16 19:46:06.514 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01) 0:7.81;8118.12
2021-02-16 19:46:39.296 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.6;74.2;3
2021-02-16 19:46:39.307 (Zigate) UpdateDevice - (Badkamer temperatuur) 19.6:19.6
2021-02-16 19:46:39.327 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.6;80.2;3
2021-02-16 19:46:39.336 (Zigate) UpdateDevice - ( Badkamer vocht) 80.2:3
2021-02-16 19:46:39.349 EventSystem: Event triggered: Badkamer afzuiging_1
2021-02-16 19:46:39.397 (Zigate) UpdateDevice - (Badkamerventilatie) 1:On
2021-02-16 19:46:39.350 Status: Afzuiging badkamer gaat aan
2021-02-16 19:48:25.545 (Zigate) UpdateDevice - ( Deur_woonkamer) 0:Closed
2021-02-16 19:49:20.284 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.6;74.1;3
2021-02-16 19:49:20.294 (Zigate) UpdateDevice - ( Badkamer vocht) 74.1:3
2021-02-16 19:49:20.307 EventSystem: Event triggered: Badkamer afzuiging_2
2021-02-16 19:49:20.308 Status: Afzuiging badkamer gaat uit
2021-02-16 19:51:47.565 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Power-00158d000444ee2f-01) 7.91:7.913871765136719
2021-02-16 19:51:47.575 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01) 0:7.91;8118.75
2021-02-16 19:52:06.300 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.6;68.0;1
2021-02-16 19:52:06.311 (Zigate) UpdateDevice - ( Badkamer vocht) 68.0:1
2021-02-16 19:52:06.324 EventSystem: Event triggered: Badkamer afzuiging_2
2021-02-16 19:53:03.065 (Zigate) UpdateDevice - ( Deur_woonkamer) 1:Open
2021-02-16 19:53:15.662 (Zigate) UpdateDevice - ( Deur_woonkamer) 0:Closed
2021-02-16 19:55:04.640 (Weer) Temp + Humidity + Baro (Tempratuur buiten (online))
2021-02-16 19:55:04.655 (Weer) Wind (Wind (online))
2021-02-16 19:55:04.663 (Weer) General/Visibility (Zichtbaarheid (online))
2021-02-16 19:55:04.671 (Weer) General/Percentage (Wolken (online))
2021-02-16 19:56:10.777 (Zigate) UpdateDevice - (Deur_schuifdeur) 0:Closed
2021-02-16 19:58:10.719 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Power-00158d000444ee2f-01) 7.88:7.8803300857543945
2021-02-16 19:58:10.730 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01) 0:7.88;8119.69
2021-02-16 19:59:20.364 (Zigate) UpdateDevice - (Badkamerventilatie) 0:Off
2021-02-16 19:59:58.851 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.5;68.0;1
2021-02-16 19:59:58.862 (Zigate) UpdateDevice - (Badkamer temperatuur) 19.5:19.5
2021-02-16 19:59:58.884 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.5;62.0;1
2021-02-16 19:59:58.894 (Zigate) UpdateDevice - ( Badkamer vocht) 62.0:1
2021-02-16 20:04:19.826 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Power-00158d000444ee2f-01) 7.94:7.944180965423584
2021-02-16 20:04:19.836 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01) 0:7.94;8120.31
2021-02-16 20:04:55.508 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.5;66.8;1
2021-02-16 20:04:55.518 (Zigate) UpdateDevice - ( Badkamer vocht) 66.8:1
2021-02-16 20:05:04.719 (Weer) Temp + Humidity + Baro (Tempratuur buiten (online))
2021-02-16 20:05:04.733 (Weer) Wind (Wind (online))
2021-02-16 20:05:04.742 (Weer) General/Visibility (Zichtbaarheid (online))
2021-02-16 20:05:04.749 (Weer) General/Percentage (Wolken (online))
2021-02-16 20:05:14.789 (Zigate) UpdateDevice - ( Deur_woonkamer) 1:Open
2021-02-16 20:05:20.324 (Zigate) UpdateDevice - ( Deur_woonkamer) 0:Closed
2021-02-16 20:05:22.029 (Zigate) UpdateDevice - ( Deur_voordeur) 1:Open
2021-02-16 20:05:22.433 (Zigate) UpdateDevice - ($PIR-ligt sterkte) 0:0
2021-02-16 20:05:22.452 (Zigate) UpdateDevice - ( PIR-voordeur) 1:On
2021-02-16 20:05:26.316 (Zigate) UpdateDevice - ( Deur_voordeur) 0:Closed
2021-02-16 20:06:24.633 (Zigate) UpdateDevice - ( Deur_woonkamer) 1:Open
2021-02-16 20:07:26.986 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.5;68.2;1
2021-02-16 20:07:26.996 (Zigate) UpdateDevice - ( Badkamer vocht) 68.2:1
2021-02-16 20:07:43.938 (Zigate) UpdateDevice - ( Deur_woonkamer) 0:Closed
2021-02-16 20:10:16.862 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Power-00158d000444ee2f-01) 7.94:7.936502456665039
2021-02-16 20:10:16.872 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01) 0:7.94;8121.25
2021-02-16 20:10:46.164 (Zigate) UpdateDevice - ($PIR-ligt sterkte) 0:0
2021-02-16 20:10:46.183 (Zigate) UpdateDevice - ( PIR-voordeur) 1:On
2021-02-16 20:15:01.132 (Zigate) Zigate receive message processing time Max: 128 ms with an of average: 6 ms
2021-02-16 20:15:04.837 (Weer) Temp + Humidity + Baro (Tempratuur buiten (online))
2021-02-16 20:15:04.852 (Weer) Wind (Wind (online))
2021-02-16 20:15:04.861 (Weer) General/Visibility (Zichtbaarheid (online))
2021-02-16 20:15:04.868 (Weer) General/Percentage (Wolken (online)) Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
can you give me the export.json ( Plugin Device RAW (json) ?
Yes it works! The Firmware 031d is the solution.
Thanks Pipiche, keep up the good work!
Champagne !!!!
Hi Pipiche,
I have order a new siren, the last one did not work on usb power...
Is it possible that the last beta is not working with the siren?
Adding the siren was no problem. Strange is, the Light is flashing.
what do you mean not working with the last beta ?
I made a update to a newer version (beta branch), in this thread.The problem with the Hue gu10
viewtopic.php?f=68&t=36448
attached the raw export.
- export.txt
- (300.77 KiB) Downloaded 50 times
@marktn I would be please to help you but, please explain what is your new problem, what is not working what you are expecting ?
I know that the Hue GU10 doesn't work on your end, but from what I see this should work, and for now I only see a way to purchase one to make the test on my end
Is that one you are refereing : https://www.amazon.co.uk/Philips-Ambian ... rzigbee-21 ?
Now the post here is about Tuya Siren, so what is not working with the Tuya Siren on beta and what do you expect ?
Hi Pipiche,
I have added the new siren, pairing no problem, and it is visible in domoticz.
Only it does not work, the siren is not working, and no temperature/humidity.
The led ring is flashing, is that normal?
In domoticz log there is a error, see under here.
About the Hue light, i will answer that in the other topic.
2021-06-24 20:25:10.680 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:49255' ignored.
2021-06-24 20:25:10.680 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:49257' ignored.
2021-06-24 20:30:11.589 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:49550' ignored.
2021-06-24 20:30:11.589 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:49549' ignored.
2021-06-24 21:12:04.792 Error: Zigate: (Zigate) DeviceExist - Found some inconsistency Inputs: 2dac 00158d0004631f4e instead of None
2021-06-24 21:12:53.398 Error: dzVents: Error: (3.1.7) Discarding device. No last update info found: {["changed"]=true, ["data"]={["hardwareType"]="Zigate plugin", ["protected"]=false, ["customImage"]=0, ["usedByCamera"]=false, ["hardwareID"]=7908956, ["unit"]=40, ["hardwareName"]="Zigate", ["Image"]="Light", ["icon"]="motion", ["hardwareTypeValue"]=94, ["maxDimLevel"]=100, ["levelVal"]=0, ["_state"]="On", ["_nValue"]=1}, ["description"]="", ["image"]="", ["switchType"]="Motion Sensor", ["subType"]="Switch", ["switchTypeValue"]=8, ["batteryLevel"]=1700434296, ["protected"]=false, ["baseType"]="device", ["deviceID"]="", ["lastLevel"]=255, ["lastUpdate"]="", ["id"]=4962, ["rawData"]={"On"}, ["timedOut"]=true, ["signalLevel"]=2686588, ["iconNumber"]=200, ["name"]="Zigate - lumi.sensor_motion_Motion-00158d0004631f4e-01", ["deviceType"]="Light/Switch"}
2021-06-24 21:18:46.979 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:57597' ignored.
2021-06-24 21:18:47.033 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:57599' ignored.
2021-06-24 21:20:50.889 Error: Slave Synolgy: Can not connect to: 192.168.1.59:6144 (Connection refused)
2021-06-24 21:29:48.332 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:62174' ignored.
2021-06-24 21:33:03.292 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:62176' ignored.
2021-06-25 19:13:27.111 Error: dzVents: Error: (3.1.7) Discarding device. No last update info found: {["baseType"]="device", ["timedOut"]=true, ["lastLevel"]=255, ["iconNumber"]=104, ["description"]="", ["lastUpdate"]="", ["switchTypeValue"]=7, ["protected"]=false, ["switchType"]="Dimmer", ["changed"]=true, ["data"]={["customImage"]=0, ["usedByCamera"]=false, ["icon"]="dimmer", ["hardwareType"]="Zigate plugin", ["hardwareID"]=7908956, ["Image"]="Light", ["hardwareName"]="Zigate", ["levelVal"]=1, ["unit"]=41, ["_state"]="On", ["_nValue"]=1, ["color"]="{"b":0,"cw":42,"g":0,"m":2,"r":0,"t":213,"ww":213}", ["maxDimLevel"]=100, ["hardwareTypeValue"]=94, ["protected"]=false}, ["subType"]="RGBWW", ["rawData"]={"1"}, ["batteryLevel"]=1814015136, ["signalLevel"]=2686588, ["name"]="Zigate - hal", ["image"]="", ["deviceID"]="", ["deviceType"]="Color Switch", ["id"]=4963} - Attachments
- firefox_2021-06-25_19-05-38.jpg (135.72 KiB) Viewed 1790 times
I have found a difference between the sirens, the second one has the name Neo, the first one Neo coolcam. Maybe the problem...
I have charged the batteries of my first siren, with my second siren. (The first siren does not charge the batteries)
The first Siren is working, second one not.
So the first Siren is working, maybe the second one is another type/version.
Or the second one is also broken...
e4d3
804b50fffe048336
TS0601-sirene
Zigate - TS0601-sirene_Temp+Hum-804b50fffe048336-01
Zigate - TS0601-sirene_Temp-804b50fffe048336-01
Zigate - TS0601-sirene_Humi-804b50fffe048336-01
Zigate - TS0601-sirene_TuyaSiren-804b50fffe048336-01
Zigate - TS0601-sirene_TuyaSirenHumi-804b50fffe048336-01
Zigate - TS0601-sirene_TuyaSirenTemp-804b50fffe048336-01
RFD
Battery
207
inDB
Live
ebd2
5c0272fffecea9d6
TS0601-sirene
Zigate - TS0601-sirene_Temp+Hum-5c0272fffecea9d6-01
Zigate - TS0601-sirene_Temp-5c0272fffecea9d6-01
Zigate - TS0601-sirene_Humi-5c0272fffecea9d6-01
Zigate - TS0601-sirene_TuyaSiren-5c0272fffecea9d6-01
Zigate - TS0601-sirene_TuyaSirenHumi-5c0272fffecea9d6-01
Zigate - TS0601-sirene_TuyaSirenTemp-5c0272fffecea9d6-01
Could you kindly post a maximum information so I can analyse
- document what is working, what is not
- logs from the pairing
- eventually logs when doing actions
- attach export.json from the Plugin Devices RAW (json). The RAW version is a must.
The new (second) siren is not working, attached the logs. No siren, no temp and hum.
Also the new siren is flashing, see a video of it. https://www.dropbox.com/s/aqct67bvnus85 ... n.mp4?dl=0
The frist siren is still working fine, only has a problem with charging. Not a problem of zigate or domoticz. It looks like a charging problem.
- Json Raw.txt
- (314.87 KiB) Downloaded 55 times
- firefox_2021-07-02_19-17-40.jpg (146.55 KiB) Viewed 1756 times
- domoticz log.txt
- (3.8 KiB) Downloaded 66 times
