One click wakeup alarm in music with LMS
hestia
Domoticz version: 2022.1
Post by hestia »
I made a DzVents script to wakeup with a Logitech Media Player. I wanted something simple to use and easy for changing the wake-up hour, and without any calendar.
Why Domoticz and not LMS GUI directly?!?
I've been using LMS GUI for years but I could not get what I wanted: a specific alarm routine: music in random at low level for 5 minutes, radio not random at normal level for 30 minutes, music in random at low level for 40 minutes. I should be up not too late after the radio slot ;-) and have music on when I come back after breakfast...
This sequence was not possible with LMS, probably due to bugs, I could not start with music and after have radio, the music never stop at the end, not possible to have different levels on each slot. And also sometimes no wake up :-(
So I did it why Domoticz.
I’d like to share it for the ones who want to use it, and to get feedback on the way I did it, it as I’m not a coder.
The GUI is a simple selector
This part could be improved, but I know nothing with GUI and html…
The prerequisite is to have a Logitech Media Server, a player and the integration in Domoticz with the plugin Logitech Media Server.
The script is
A one-click alarm to wake-up with the music off your Logitech Media Server (LMS).
Your can have several playlists played for the wakeup (music random, radio, other music random)
and with different level for each slot.
You can pause for one day ; there is also a vacation mode
When a playlist is send, there are some check that it is playing for real to be sure to wake up
If problem there is a fallback mode (for me blink my light)
If domoticz was down a the alarm time, the alarm is triggered when domoticz is back
About LMS API: http://tutoriels.domotique-store.fr/content/54/95/fr/api-logitech-squeezebox-server-_-player-http.html
Prerequisite: V2020.2 build 12924 (or from dzVents V 3.0.2 to domoticz 2020.2 build 12819)
hestia 29/05/2020> go live
hestia 28/10/2020> fix error when calling Blink (for fallback mode)
hestia 05/02/2021> move CheckResponse after PlayingKO to avoid error
hestia 07/02/2021> fix some issues with logging
hestia 08/02/2021> add some afterSec(x) on the OpenUrlLMS to avoid some risks of mix in calls
    due to openURL optimisation #4585 (http requests on seperate threads dzVents)
local alarmStartPerDay = {'Pause', '6h40', '6h40', '6h40', '6h40', '6h40', '7h15'} -- to be present in WAKEUPTIME_IDX  /!\ 1 is Sunday
local alarmDurations = {5, 30, 40, 0} -- alarm duration for each slot - 0 to stop the last alarm
local alarmPlayLists = {"zzReveilMusic","zzReveilInfo", "zzReveilDeezer"} -- playlists names for each slot  /!\ no blank nor é à ...
local alarmLevels = {60, 77, 60} -- alarm level for each playlist
local alarmShuffle = {true, false, true} -- to shuffe or not each alarm slot
local userDayNames = {'Dim.', 'Lun.', 'Mar.', 'Mer.', 'Jeu.', 'Ven.', 'Sam.'} -- to change from dz config, to comment if not necessary
--local FAKE_LMS = 1037 -- to uncomment for testing
--local DUMMY = true -- to set to true for testing only w/o playing for real
local PLAYER_IDX = 1303 -- LMS player idx for dzVent commands
local LMS_player= "b8:27:eb:7d:00:36"  -- LMS Player MAC Address for json commands
local LMS_serverPort='erato:9000'  -- LMS Server Hostname and HTTP Port Number
local LMS_playlistsFolder="/media/playlists/" -- LMS Playlists Folder
local ERR_IDX = 967 -- backup device to use in case of issue with LMS
local ICON_ON = 237
local ICON_PLAY = 236
local ICON_OFF = 238
local ICON_PAUSE = 239
local WAKEUPTIME_IDX = 1035 -- dummy device to create with the wakeup times
local WAKEUPTIME_NAME = 'Réveil' -- inital name of the dummy device to create with the wakeup times
    -- switch type selector, with level name like 6h30 6h35 6h40... and 'Pause' and 'Stop' (see param for value below
local alarmPauseValue = 'Pause' -- the value choosen to have the alarm off for 1 day
local alarmOffValue = 'Stop' -- the value choosen to have the alarm off
-- user variables to declare
local alarmStatus_idx=8
local alarmDate_idx =7
local alarmTime_idx =9
local alarmIndex_idx =10
local CALLBACKPREFIX=WAKEUPTIME_IDX -- if several instances of the script
local HHMM_SEPARATOR='h'
local TIME_DELAY=15
    logging =   {
                level =
                domoticz.LOG_ERROR, --select one to override system log level normal = LOG_ERROR
                --domoticz.LOG_DEBUG,
                --domoticz.LOG_INFO,
                --domoticz.LOG_ERROR,
                --domoticz.LOG_FORCE
    on =    {
            timer = {function(dz)
                    if dz.time.rawDate == dz.variables(alarmDate_idx ).date.rawDate then
                        if dz.time.matchesRule('at ' .. dz.variables(alarmTime_idx).value) then -- check exact minutes
                            --print('Exact time checked ' .. dz.variables(alarmTime_idx).value)
                            return true
                        else -- check if the time was missed
                            local maxTime= dz.variables(alarmTime_idx).time.addMinutes(TIME_DELAY)
                            local checkTime=dz.time.matchesRule('between ' .. dz.variables(alarmTime_idx).time.hour .. ":" .. dz.variables(alarmTime_idx).time.minutes
                            .. ' and ' .. maxTime.hour .. ":" .. maxTime.minutes)
                            --print('alarmTime ' .. dz.variables(alarmTime_idx).time.hour .. ":" .. dz.variables(alarmTime_idx).time.minutes)
                            --print('maxTime ' .. maxTime.hour .. ':' .. maxTime.minutes, dz.LOG_DEBUG)
                            if checkTime and dz.variables(alarmStatus_idx).value ~= 'PLAY' then -- the time was missed, no alarm triggered!
                                print('Alarm missed ' .. dz.variables(alarmTime_idx).value)
                                return true
                                --print('Alarm not missed')
            	        --print('NOT today')
        	        return false
            devices =   {
                        WAKEUPTIME_IDX
            httpResponses = {
                            CALLBACKPREFIX..'LMS_Play',
                            CALLBACKPREFIX..'LMS_Shuffle',
                            CALLBACKPREFIX..'LMS_Unshuf',
                            CALLBACKPREFIX..'LMS_Status'
 execute = function(dz, item, triggerInfo)
    _G.logMarker =  dz.moduleLabel -- set logmarker to scriptname
    local LOG_LEVEL = dz.LOG_INFO -- normal
    --local LOG_LEVEL = dz.LOG_DEBUG
    --local LOG_LEVEL = dz.LOG_ERROR
    --local LOG_LEVEL = dz.LOG_FORCE
    dz.log('==>> triggered by ' ..  triggerInfo.type, LOG_LEVEL)
    local scriptRC=0 -- global retrun code to stop the scrip
    local wakeupTimeBool=false
    local wakeUpTime
    local devPLAYER_IDX = dz.devices(PLAYER_IDX)
    local devWAKEUPTIME = dz.devices(WAKEUPTIME_IDX)
    local alarmStatus
    local alarmDate
    local alarmTime
    local alarmIndex
    local alarmValue
-----< BEG FUNCTIONS > ----------------------------------------------------------------------------------------
    local function OpenUrlLMS (urlParams, urlCallback, p_afterSec)
        -- open the player url with a callback to check the return code and player status
        local httpLMS='http://'..LMS_serverPort..'/status.html?'
 	    dz.openURL({url = httpLMS .. urlParams, callback = CALLBACKPREFIX..urlCallback}).afterSec(p_afterSec)
        dz.log(urlCallback .. ' - ' .. urlParams, LOG_LEVEL)
        return
    local function PlayLMS(cmd, volume, playlist, shuffle)
        -- cmd='On' => play the playlist with the volune and shuffle or not / "Off" => switch off the player
        if cmd == 'On' then
            dz.log('PlayLMS ' .. cmd .. ' '  .. volume .. ' ' .. playlist, LOG_LEVEL)
            -- set the player w or w/o shuffle
            local paramShuffle=0
            if shuffle then  paramShuffle=1 end
            local shufflePlaylist='p0=playlist&p1=shuffle&p2='.. paramShuffle ..'&player='..LMS_player
            -- adjust the volume
            if DUMMY then
                dz.log('DUMMY', LOG_LEVEL)
                OpenUrlLMS(shufflePlaylist, 'LMS_Shuffle', 0)
                devPLAYER_IDX.setVolume(volume).afterSec(1)
                -- play the playlist
                local playPlaylist='p0=playlist&p1=play&p2='..LMS_playlistsFolder..playlist..'.m3u&p3=1&player='..LMS_player
                OpenUrlLMS(playPlaylist, 'LMS_Play', 2)
                -- check the status, is the player playing? result in the callback...
                local playStatus='&player='..LMS_player
                OpenUrlLMS(playStatus, 'LMS_Status', 3)
            if FAKE_LMS ~= nil then -- dummy to test the script w/o activate LMS
                dz.log('==>> FAKE_LMS ' .. FAKE_LMS .. ' ' .. cmd, LOG_LEVEL)
                dz.devices(FAKE_LMS).updateAlertSensor(dz.ALERTLEVEL_GREEN, playlist)
            dz.log('PlayLMS ' .. cmd, LOG_LEVEL)
            -- Stop, Unshuffle Playlist and SwitchOff
            if DUMMY then
                devPLAYER_IDX.stop()
                OpenUrlLMS(shufflePlaylist, 'LMS_Unshuf', 1)
                devPLAYER_IDX.switchOff().afterSec(2)
                dz.devices(FAKE_LMS).updateAlertSensor(dz.ALERTLEVEL_GREY, 'Off')
        return
    local function CheckWakeUpTime (P_wakeUpTimeHM)
        -- function to check if the new wakeupTime is a time
        dz.log('CheckWakeUpTime ' .. P_wakeUpTimeHM, LOG_LEVEL)
        local F_wakeupTimeBool = false
        local F_hhmmTime = string.gsub(P_wakeUpTimeHM, HHMM_SEPARATOR, "")
        if tonumber(F_hhmmTime) ~= nil then -- it is a time
            F_wakeupTimeBool = true
        dz.log("CheckWupTime> hhmmTime " .. P_wakeUpTimeHM .. ' '..  tostring(F_wakeupTimeBool), LOG_LEVEL)
        return(F_wakeupTimeBool)
    local function ConvertWakeUpTime (P_wakeUpTimeHM)
        -- function to convert wakeupTime in hh:mm:ss, if with separator like 'h'
        dz.log('ConvertWakeUpTime ' .. P_wakeUpTimeHM, LOG_LEVEL)
        local F_wakeUpTimeHMS
        if HHMM_SEPARATOR ~= ":" then
            F_wakeUpTimeHMS = (string.gsub(P_wakeUpTimeHM, HHMM_SEPARATOR, ":") .. ':00')
            F_wakeUpTimeHMS = (P_wakeUpTimeHM .. ':00')
        dz.log("ConvertWakeUpTime hhmmTime " .. F_wakeUpTimeHMS, LOG_LEVEL)
        return(F_wakeUpTimeHMS)
    local function SetNextAlarmTime()
        local F_NextDayNum
        local F_nextWakeTime
        dz.log("SetNextAlarmTime nil", LOG_LEVEL)
        -- set the time for the tomorrow alarm based on a list of the day of the week
        F_NextDayNum = dz.time.wday + 1 -- Sunday = 1
        if F_NextDayNum == 8 then F_NextDayNum = 1 end
        F_nextWakeTime = alarmStartPerDay[F_NextDayNum]
        dz.log("Day#: " .. F_NextDayNum .. ' ' .. F_nextWakeTime, LOG_LEVEL)
        dz.log("Set next wakeup time: " .. F_nextWakeTime, LOG_LEVEL)
        return (F_nextWakeTime)
    local function CalculateNextAlarmInfos(P_wakeUpTimeState, P_Origin) --  P_Origin: 'U' User: after a change by GUI / 'S' Script for the next alarm day
        local F_wakeUpTimeHM = P_wakeUpTimeState -- the time selected in the dummy selector
        dz.log('CalculateNextAlarmInfos F_wakeUpTimeHM ' .. F_wakeUpTimeHM, LOG_LEVEL)
        local F_wakeupTimeBool=CheckWakeUpTime(F_wakeUpTimeHM)
        if F_wakeupTimeBool then -- it is a time
            dz.log('Wakeup time :' .. F_wakeUpTimeHM, LOG_LEVEL)
            F_wakeUpTimeHMS=ConvertWakeUpTime(F_wakeUpTimeHM)
            local F_checkAlarmTomorrow
            if P_Origin == 'S' then -- if by the script, it is for tomorrow
                F_checkAlarmTomorrow = true
                F_checkAlarmTomorrow = dz.time.matchesRule('between ' .. F_wakeUpTimeHMS .. ' and 23:59:59')
                -- if by the GUI, if the selected next alarm is before now, it is for tomorow
            if F_checkAlarmTomorrow then
                alarmDate=dz.time.addHours(24)
                --print(tostring(checkExec))
                dz.log('Set alarm for tomorrow ' .. F_wakeUpTimeHMS, LOG_LEVEL)
                alarmDate=dz.time
                dz.log('Reset alarm for today ' .. F_wakeUpTimeHMS, LOG_LEVEL)
            alarmTime= dz.time.makeTime(alarmDate.rawDate .. " " ..  F_wakeUpTimeHMS) -- the wakeup time as a time object
            alarmStatus='ON'
            alarmIndex=1
            if F_wakeUpTimeHM == alarmPauseValue then
                dz.log('Alarm pause', LOG_LEVEL)
                if alarmStatus == 'ON' then
                    -- alarm is ON and to be set on PAUSE, not a change of the trigger date/time
                    -- there should be already a next date/time set to be trigger the script again at the next alarm slot
                    dz.log('Alarm cancelled when ON', LOG_LEVEL)
                else -- PLAY, OFF
                    alarmDate=dz.time.addHours(24) -- tomorrow to update the alarm for the day after
                    alarmTime=dz.time.makeTime(alarmDate.rawDate .. ' 12:00:00')
                    dz.log('Alarm cancelled when not ON', LOG_LEVEL)
                alarmStatus='PAUSE'
            elseif  F_wakeUpTimeHM == alarmOffValue then
                dz.log('Alarm stopped', LOG_LEVEL)
                alarmDate=dz.time.addHours(-24) -- before today, not to be triggered
                --print('alarmDate.rawTime ' .. alarmDate.rawTime)
                --print('alarmDate.rawDate ' .. alarmDate.rawDate)
                alarmStatus='OFF'
                dz.log('CalculateNextAlarmInfos: Alarm ?????? <' .. F_wakeUpTimeHM .. '>', LOG_LEVEL)
            --print('=> 3 alarmIndex ' .. alarmIndex)
            alarmIndex=0
    return
    local function CancelAlarm() -- cancel the alarm after the icon is clicked
        if alarmStatus=='PLAY' then
            dz.log('CancelAlarm PLAY', LOG_LEVEL)
            PlayLMS('Off')
        elseif alarmStatus=='PAUSE' then
            dz.log('CancelAlarm: alarm already on ' .. alarmStatus, LOG_LEVEL)
            return(-1)
        alarmStatus='CANCELLED' -- the next alarm will be set when the next timer happens
        devWAKEUPTIME.setIcon(ICON_PAUSE)
        dz.log('CancelAlarm => ' .. alarmStatus, LOG_LEVEL)
        return(0)
    local function GetAlarmInfo() -- get status, date and time of the alarm
        alarmStatus=dz.variables(alarmStatus_idx).value
        alarmDate=dz.variables(alarmDate_idx).date
        alarmTime=dz.variables(alarmTime_idx).time
        alarmIndex=dz.variables(alarmIndex_idx).value
        --print('=> 4 alarmIndex ' .. alarmIndex)
        if alarmStatus=='PAUSE' or alarmStatus=='ON' or alarmStatus=='PLAY' or alarmStatus== 'CANCELLED' or alarmStatus== 'OFF' then
            dz.log('AlarmStatus OK: ' .. alarmStatus, LOG_LEVEL)
            dz.log('AlarmStatus KO: ' .. dz.variables(alarmStatus_idx).value, LOG_LEVEL)
            -------------SetNextAlarmTime(alarmOffValue)
            alarmDate=dz.time.addHours(-24) -- tomorrow to update the alarm for the day after
            alarmStatus='OFF'
            alarmIndex=0
            --print('=> 5 alarmIndex ' .. alarmIndex)
            return(-1)
        dz.log('Alarm status ' ..  alarmStatus, LOG_LEVEL)
        dz.log('Alarm date ' .. alarmDate.rawDate .. ' time ' .. alarmTime.rawTime, LOG_LEVEL)
        return(0)
    local function LangDayName(P_alarmDate) -- give the name of the day in user language (if dz GUI is not)
        if userDayNames == nil then -- the day list exist
            return(P_alarmDate.dayName)
            return(userDayNames[P_alarmDate.wday])
    local function SetIconNameDevice(P_alarmStatus, P_alarmDate)
        if P_alarmStatus == 'PAUSE' then
            devWAKEUPTIME.rename(WAKEUPTIME_NAME .. ' - ' .. LangDayName(P_alarmDate))
        elseif P_alarmStatus == 'OFF' then
            devWAKEUPTIME.setIcon(ICON_OFF)
            devWAKEUPTIME.rename(WAKEUPTIME_NAME)
        elseif P_alarmStatus == 'PLAY' then
            devWAKEUPTIME.setIcon(ICON_PLAY)
        elseif P_alarmStatus == 'ON' then
            devWAKEUPTIME.setIcon(ICON_ON)
        elseif P_alarmStatus == 'CANCELLED' then
            -- the icon is already ok
            dz.log('SetIconNameDevice ' .. P_alarmStatus .. ' unknown', dz.LOG_ERROR)
        return
    local function SetAlarmInfo(P_alarmStatus, P_alarmDate, P_alarmTime, P_alarmIndex) -- set status, date and time of the alarm
        dz.variables(alarmStatus_idx).set(P_alarmStatus) --.checkFirst()
        dz.variables(alarmDate_idx ).set(P_alarmDate.day..'/'..P_alarmDate.month..'/'..P_alarmDate.year) -- .checkFirst()
        dz.variables(alarmTime_idx).set(P_alarmTime.hour..':'..P_alarmTime.min) -- .checkFirst()
        dz.variables(alarmIndex_idx).set(P_alarmIndex)
        --print('=> 6 alarmIndex ' .. P_alarmIndex)(
        return
    local function Blink(deviceId) -- 28/10/2020 -- move before PlayingKO to avoid error
        -- blink a device based on time on and time off
        dz.devices(deviceId).cancelQueuedCommands()
        local blinkDurations= {2, 1, 2, 1, 2, 1}
        local duration=0
        local boolOn=true
        for key, id in ipairs(blinkDurations) do
            --print(duration)
            if boolOn then
                dz.devices(deviceId).switchOn().afterSec(duration)
                boolOn=false
                dz.devices(deviceId).switchOff().afterSec(duration)
                boolOn=true
            duration=duration+blinkDurations[key]
        return
    local function PlayingKO(playError)
        -- in case of error when playing, do something to wakeup anayway...
        dz.log('Error playing ' .. playError, dz.LOG_ERROR)
        Blink(ERR_IDX) -- blink a specific device
        return
    local function CheckResponse() -- check http response -- 05/02/2021 -- move after PlayingKO to avoid error
        if item.callback == CALLBACKPREFIX..'LMS_Status' then
            -- check if the player is present (selected)
            --dz.log('item.data ' .. item.data, LOG_LEVEL)
            local CheckPlayer=string.find(item.data,'<option selected value="'..LMS_player)
            if CheckPlayer ~= nil then -- the player is present
                dz.log('HTTPResponse CheckPlayer OK ' .. CheckPlayer, LOG_LEVEL)
                -- check if the player is playing
                local CheckPlaying=string.find(item.data,'Now Playing')
                if CheckPlaying ~= nil then -- the player is playing
                    dz.log('HTTPResponse CheckPlaying OK ' .. CheckPlaying, LOG_LEVEL)
                else  -- the player is not playing
                    dz.log('item.data ' .. item.data, dz.LOG_FORCE)
            else -- the player is not present
                PlayingKO('Player')
        return
-----< END FUNCTIONS > ----------------------------------------------------------------------------------------
-- < Device trigger
    if item.isDevice then -- the wakeup time has been changed
        dz.log(dz.moduleLabel .. ' triggered by ' .. item.id .. ' ' .. item.name, LOG_LEVEL)
        scriptRC=GetAlarmInfo()
        if scriptRC ~= 0 then
            SetAlarmInfo(alarmStatus, alarmDate, alarmTime, alarmIndex)
            return
        dz.log(devWAKEUPTIME.name .. ' ' .. devWAKEUPTIME.state .. " nValue: " .. devWAKEUPTIME.nValue, dz.LOG_DEBUG)
        if devWAKEUPTIME.nValue == 0 and devWAKEUPTIME.state ~= alarmOffValue then -- the icon is clicked to cancel the alarm
            scriptRC=CancelAlarm()
                return
            dz.log('==>> Alarm cancelled', LOG_LEVEL)
            -------SetNextAlarmTime(devWAKEUPTIME.state)
            CalculateNextAlarmInfos(devWAKEUPTIME.state, 'U') -- user: after a change by GUI
            devWAKEUPTIME.switchSelector(devWAKEUPTIME.state).silent() -- to refresh icon and name selector on the GUI
-- < Timer to fire the alarm
    elseif item.isTimer then
        dz.log(dz.moduleLabel .. ' triggered by timer', LOG_LEVEL)
            return
            -- Wakeup management
            local W_nextWakeTime
            if alarmStatus == 'ON' or alarmStatus == 'PLAY' then
                local wakeUpTimeHM = devWAKEUPTIME.state -- the time selected in the dummy selector
                dz.log(alarmStatus .. ' Wakeup at ' .. wakeUpTimeHM .. ' slot ' .. alarmTime.rawTime .. ' ' .. alarmIndex, LOG_LEVEL)
                if alarmDurations[alarmIndex]==0 then -- it was the last slot of the alarm
                    PlayLMS('Off')
                    W_nextWakeTime = SetNextAlarmTime() -- set alarm for next day
                    CalculateNextAlarmInfos(W_nextWakeTime, 'S') -- script
                    dz.log('Off alarmIndex ' .. alarmIndex, LOG_LEVEL)
                else -- it is a slot to play
                    alarmStatus='PLAY'
                    PlayLMS('On', alarmLevels[alarmIndex], alarmPlayLists[alarmIndex],alarmShuffle[alarmIndex])
                    alarmTime=alarmTime.addMinutes(alarmDurations[alarmIndex])
                    --print('=> 1 alarmIndex ' .. alarmIndex)
                    alarmIndex=alarmIndex+1
                    dz.log('=> On alarmIndex ' .. alarmIndex, LOG_LEVEL)
                    W_nextWakeTime = devWAKEUPTIME.state
            elseif alarmStatus =='CANCELLED' or alarmStatus =='PAUSE' then -- set alarm for next day
                dz.log('Alarm status: ' .. alarmStatus .. ' ?!?', dz.LOG_ERROR)
                return
            devWAKEUPTIME.switchSelector(W_nextWakeTime).silent() -- and to refresh icon and name selector on the GUI
-- < The callbacks to check if the player is playing
    elseif item.isHTTPResponse then -- the callback to check error code and player status
        dz.log(dz.moduleLabel .. ' callbacked by ' ..  item.callback, LOG_LEVEL)
        if item.ok then -- statusCode == 2xx
            dz.log('HTTPResponse OK !!! callback: ' .. item.callback .. ' statusCode: ' .. item.statusCode, LOG_LEVEL)
            CheckResponse()
        else -- error http
            dz.log('HTTPResponse KO !!! callback: ' .. item.callback .. ' statusCode: ' .. item.statusCode, dz.LOG_ERROR)
            --if item.callback == CALLBACKPREFIX..'LMS_Play' then --Error playing alarm
                dz.log('Backup alarm to fire!!!', LOG_LEVEL)
                PlayingKO('HTTPResponse')
            --else
            --    dz.log('HTTPResponse KO for something else?!?', dz.LOG_ERROR)
            --end
-- < Impossible error!
        dz.log(dz.moduleLabel .. ' triggered by ?????', dz.LOG_ERROR)
updated on 06/02/2021 13:35 to fix an error (05/02/2021 in the script)
updated on 08/02/2021 fix the logging and an error due to new dz version
The configuration is done with variables explained in the script
I comment the following ones:
  • The normal wake-up time for each day of the week, Pause for the days you don’t want an alarm
    alarmStartPerDay = {'Pause', '6h40', '6h40', '6h40', '6h40', '6h40', '7h15'} the first one is Sunday, but perhaps depends on settings.
    They have to be present in the selector WAKEUPTIME_IDX so one could change it.
  • alarmDurations = {5, 30, 40, 0} -- alarm duration for each slot - 0 to stop the last alarm
  • alarmPlayLists = {"zzReveilMusic","zzReveilInfo", "zzReveilDeezer"} -- playlists names for each slot /!\ no blank nor é à ...
  • alarmLevels = {60, 77, 60} -- alarm level for each playlist
  • alarmShuffle = {true, false, true} -- to shuffe or not each alarm slot
Some user variables are needed, info in the script
There is also a fallback possibility is case the LMS doesn’t play ; I blink a light (ERR_IDX)
If Domoticz missed the wakeup time (for some cause), when Domoticz could do something after, it will play the LMS.
As all the wanted methods for the LMS doesn’t exist in DzVents, I used direct api and so I need 2 sort of id for the LMS
It is a morning wakeup alarm ; I’m not sure it works to wake up after noon 😉
Next steps
Better widget?
More configuration via GUI rather than in the script…
Build a device like Oregon Projection Clocks to display if there an alarm on and other info from Domoticz like temperature… But I didn’t find anything regarding the projector…
Disclaimer: I'm not responsible if you don't wake up on time to "go" to work ;-)
