GMY G95 bulb not 'working'
Melissen
Post by Melissen »
Just boughed this bulb:
https://www.ledstripkoning.nl/speciale- ... -led-lamp/
Tried to pair this bulb with Domoticz, using RaspberryPI with C2253sniffer. The bulb is paired, but not supported (I think)
text from "sudo journalctl -u zigbee2mqtt.service -f"
feb 01 17:44:42 raspberrypi npm[444]: Zigbee2MQTT:info 2021-02-01 17:44:42: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"announce","meta":{"friendly_name":"lamp G95"},"type":"device_announced"}'
I can change the FRIENDLY NAME to 'lamp G95'... but there's no status or information about the status of this bulb.
Should it first be supported by zigbee2mqtt before it can be used in Domoticz (and plugin must be updated?) ?
Is there someone who can help me out to fix this problem? I'm not really good in programming or debugging, so step bij step is recommended.
Many thanks in advance
RFXcom433e ver1009,Raspberry Pi,Domoticz v3.5877
KaKu:16c remote,dimmer,wall-sockets,sunscreenswitch
Promax:wall sockets Elro:wall sockets Somfy:RFY screens
TFA:weather station Chinese temperature sensors, smoke detectors, power switches
