Combining would be a bit more difficult, but in latest beta the garbage collection will be sorted based on the order of the keys in 'garbage' parameter.damdub wrote: ↑Sunday 31 January 2021 15:58
Is there any way to prioritize the garbage type or, even better, a way to display a combination of images depending on the types collected on the next day ?
I tried to adjust the event times in home made garbage google calendar :
Plastic at 09.00 and Bio at 10.00
Even like this, the first item displayed in the list (and icon displayed) is always Bio bag.
Any idea ?
Dashticz - Show your dashboard and how-to's!
Great news !
Thank you @Lokonli !
Hello
another question about new calendar block
Is it possible to limit the list to the next 7 days events ?
It seems like this is only possible with layout 2 via parameter weeks
Why is it limited t this layout only ?
Thank you for your help
- HansieNL
Check out latest beta. You can now use layout:3 or layout: 4 for that.
See: https://github.com/Dashticz/dashticz/bl ... y-calendar
Blah blah blah
Hello all,
New to dashticz but already came far with my skills. See attached screenshot after a few hours of testing and editing. I looked through this topic but couldn't find it so that is why I am asking.
I am looking for a few options to add:
- Sonos possibility to add my 3 speakers
- How can I group and arrange things better? Now it's a bit of a mess. I want to have the switches for my lamps and groups in a row on the left. Then my News + Buienradar radar image and forecast from owm. and last but not least my energy consumption in a third row on the right. How can I fix this?
- How can I add buienradar radar image to dashticz?
- In the topbar there is now maandag 8 february 2021. Is it possible to make it "Maandag 8 February 2021"? So with upperclass? Also I added 'sunrise' here but this doesn't show up.
Attached there is my config.JS
var config = {}
config['language'] = 'nl_NL'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SV
config['domoticz_ip'] = 'http://192.168.1.2:8080';
config['app_title'] = 'xxxx';
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
config['spot_clientid'] = 0;
config['hide_seconds'] = 1;
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['spot_clientid'] = 'xxxxxxx';
config['hide_mediaplayer'] = 1;
config['use_favorites'] = 0; //Request all Domoticz Devices, not only favorites
config['auto_positioning'] = 0; // Use 0 this if you have defined your own columns
config['owm_api'] = 'xxxxx';
config['owm_city'] = '2757345';
config['owm_name'] = 'Delft';
config['owm_country'] = 'nl';
config['owm_lang'] = 0;
config['owm_cnt'] = '3';
config['owm_days'] = true;
config['owm_min'] = true;
config['background_image'] = 'img/bg12.jpg';
blocks = {} //only once
blocks[40] = {
title: 'Huisbediening',
width: 4
//headerbar
var columns = {}
columns['bar'] = {}
columns['bar']['blocks'] = ['logo','miniclock','sunrise','settings'],
//Definition of columns
// Woonkamer, Slaapkamer, Keuken en Thermostaat
columns = {}
columns[1] = {
blocks : [40,'s1','s2', 34, 43],
//In this example: No blocks are defined in this column
//This column will be empty
width: 6
//energiemeter, gasmeter//
columns[2] = {
blocks : [2, '4_1'],
width: 6
//spotify
columns[3] = {
blocks : ['spotify'],
width: 4
//energieverbruik grafiek
columns[4] = {
blocks : ['graph_2'],
devices: [2],
legend: true,
width: 4
//gasverbruik grafiek
columns[5] = {
blocks : ['graph_4'],
devices: [4],
legend: true,
width: 4
//weerbericht
columns[6] = {}
columns[6]['blocks'] = ['currentweather_big_owm','weather_owm']
columns[6]['width'] = 3;
- madpatrick
- Domoticz version: 2024.7
To arrange your thing, play with the collums and blocksRuudP1987 wrote: ↑Monday 08 February 2021 15:50 Hello all,
for ex.
Place your block to the blocks section
devices: [2],
legend: true,
width: 4
devices: [4],
legend: true,
width: 4
columns[4] = {'graph_2', 'graph_4', width: 8}
-= HP server GEN8 Xeon(R) E3-1220L_V2 -=- OZW -=- Toon2 (rooted) -=- Domoticz v2024.7 -=- Dashticz v3.12b on Tab8" =-
First decide how many screens you want to have. Then for the first screen: how many columns do you want to have?RuudP1987 wrote: ↑Monday 08 February 2021 15:50
Make the sum of the column width 12: (=100% screen width)
So, if your column width is 4, then that column will occupy 4/12 = 33% of the screen width.
Then you can a start adding blocks to each column. Per column-row, Dashticz again can fill up to a width of 12.
So, in one column row you can place three blocks each having width 4, one with width 12, or 6 with width 2. If a block doesn't fit anymore in the current row, it will shift to the next row (of the same column).
Define a block:
blocks['buienradar'] = {width:12, isimage:true, refresh:60, btnimage: 'https://image.buienradar.nl/2.0/image/animation/RadarMapRainNL?height=300&width=360&extension=gif&renderBackground=True&renderBranding=False&renderText=True&history=3&forecast=6&skip=1', url: 'https://www.buienalarm.nl/amsterdam-noord-holland-nederland/52.3727,4.8936'}
And then add this button to a column:
columns[3] = {
blocks: ['buienradar']
Thanks for the quick answer. But with the blocks I got this syntax error now:
SyntaxError: Unexpected token ':'. Parse error. at line 34, which is this line:
Also I added the blocks title to my switches but this Block title won't show up
blocks[40] = {
width: 4
devices: [2],
legend: true,
width: 4
devices: [4],
legend: true,
width: 4,
//headerbar
var columns = {}
columns['bar'] = {}
columns = {}
columns[1] = {
width: 6
//spotify
columns[3] = {
width: 4
//energiegrafieken
//weerbericht
columns[6] = {}
- madpatrick
Try:
blocks['graph_2'] = {
devices: [2],
legend: true,
width: 4
blocks['graph_4'] = {
devices: [4],
legend: true,
width: 4,
I am getting there but the layout is getting messier and messier haha. Buienradar works now!
Is there somewhere a guide on setting up blocks and more?
- Sjonnie2017
- Domoticz version: Latest ß
YouLess Energy meter
Hello all,
I have been busy working with columns and blocks.. My first block I got set up properly but when I add my second row it all goes wrong again.. What am I doing wrong? I calculated the width of the blocks and as Lokonli said a block is 12 and a column can be divided in 12 again. But I want the OWM and buienradar on their own line so I made these both 6 width. Attached a screenshot and my new code. My light switches and thermostat are at the correct place. The buienradar and OWN needs to go right of that block.
Also if I start using
Then I can name these easily and implement them in a block instead of 's1' I use 'Slaapkamer' right?
blocks['s1','s2',34,43] = {
Width:4
columns[1] = {
blocks: ['s1','s2',34],
width: 4,
columns[2] = {
blocks: [43],
width: 12,
blocks['buienradar','currentweather_big_owm','weather_owm'] = {
Width:4
columns[3] = {
blocks: ['buienradar'],
width: 3,
columns[4] = {
blocks: ['currentweather_big_owm','weather_owm'],
width: 3,
blocks['s1'] = { //Select group/scene with Domoticz index 12
title: 'Slaapkamer'
- madpatrick
How does your screens setup look ?
for example:
for example:
//Definition of screens
screens = {}
screens[1] = {
columns: [1, 2]
The keys are case sensitive. So use 'width' instead of 'Width'RuudP1987 wrote: ↑Tuesday 09 February 2021 9:44 Hello all,
Also if I start usingCode: Select all
blocks['s1','s2',34,43] = { Width:4 } columns[1] = { blocks: ['s1','s2',34], width: 4, } columns[2] = { blocks: [43], width: 12, } blocks['buienradar','currentweather_big_owm','weather_owm'] = { Width:4 } columns[3] = { blocks: ['buienradar'], width: 3, } columns[4] = { blocks: ['currentweather_big_owm','weather_owm'], width: 3, }
Then I can name these easily and implement them in a block instead of 's1' I use 'Slaapkamer' right?Code: Select all
blocks['s1'] = { //Select group/scene with Domoticz index 12 title: 'Slaapkamer' }
And probably the next statement is incorrect:
Width:4
Width:4
blocks['s1'] = {
width: 4
blocks['s2'] = {
width: 4
width: 4,
//add the other parameters like btnimage and url here as well
I don't use screens as I just only want 1 screen at the moment. Does it make any difference?madpatrick wrote: ↑Tuesday 09 February 2021 9:57 How does your screens setup look ?
for example:
//Definition of screens screens = {} screens[1] = { columns: [1, 2] }
If you don't define screens[1] in CONFIG.js, then by default a screens[1] will be created that contains all columns you defined.RuudP1987 wrote: ↑Tuesday 09 February 2021 10:35I don't use screens as I just only want 1 screen at the moment. Does it make any difference?madpatrick wrote: ↑Tuesday 09 February 2021 9:57 How does your screens setup look ?
for example:
So, it should work ...
Your column 1 contains three blocks, and has width 4.
Your column 2 contains one block '43'. I assume this is the Thermostaat device. The column has width 12, so this second column doesn't fit right of the first column.
That means column 2 will start on a new row, below column 1.
Column 3 has width 3. However, column 2 (width 12) already covers the whole screen width. That means column 3 will start a new row, below column 2.
Column 4 has width 3. This column will fit right of column 3. The two columns together will fit within the left 50% of the screen.
So it seems the screenshot exactly shows how you defined your columns.
I think I now get it. Back to the drawing bord!Lokonli wrote: ↑Tuesday 09 February 2021 11:00If you don't define screens[1] in CONFIG.js, then by default a screens[1] will be created that contains all columns you defined.RuudP1987 wrote: ↑Tuesday 09 February 2021 10:35I don't use screens as I just only want 1 screen at the moment. Does it make any difference?madpatrick wrote: ↑Tuesday 09 February 2021 9:57 How does your screens setup look ?
for example:
Looking forward to see the results!
Making a lot of progress these days! Almost happy with the result!
Although I want a graph with bars. But when I have set up this code nothing shows up anymore. What am I missing that it only displays the title and the usage and the custom buttons but not the graph?
title: 'Mijn verbruik',
devices: [2],
graph: 'bar',
width: 12, //12 is 100% column breedte
custom : {
"Last 2 weeks": {
range: 'month',
filter: '14 days',
"Last 6 months": {
range: 'year',
filter: '6 months',
legend: true,
Almost done!
Only question left is my graph and how to center the Buienradar screen in my 2nd column?
