Problem Aeotec ZWave Gen5/slea's Zigbee CC2652R same PI3B+
brommetje
Post by brommetje »
Hi ALL,
Configuration : PI3B+ + external hub and an Aeotec Z-Stick Gen 5, Slea's stick CC2652R and an RFXtrx433 connnected to it.
After upgrade from Domoticz 2020.2 build 12393 to the latest or earlier (restore backup) ZWave is not running anymore and stay's under hardware on Setup no devices seen or what so ever, in my OZW_Log.txt I the following
2021-01-30 15:07:06.079 Always, OpenZwave Version 1.6-1240-g01c8d001 Starting Up
2021-01-30 15:07:06.114 Always, Using Language Localization
2021-01-30 15:11:43.125 Error, ERROR: Not enough space in stream buffer
2021-01-30 15:11:43.126 Always,
2021-01-30 15:11:43.126 Always, Dumping queued log messages
2021-01-30 15:11:43.127 Always,
2021-01-30 15:11:43.127 Always, End of queued log message dump
2021-01-30 15:11:43.127 Error, ERROR: Not enough space in stream buffer
2021-01-30 15:11:43.127 Always, Dumping queued log messages
My Zigbee stick is still working fine. I have created USB persistent devices and with lsusb and ls -ld /dev/ttyUSB* I see all my devices.
pi@snoepie:~/domoticz/scripts/lua $ ls -ld /dev/ttyUSB*
crw-rw---- 1 root dialout 188, 0 Jan 30 15:06 /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 1 Jan 30 15:51 /dev/ttyUSB1
crw-rw---- 1 root dialout 188, 2 Jan 30 16:23 /dev/ttyUSB2
lrwxrwxrwx 1 root root 7 Jan 30 15:06 /dev/ttyUSB-KAIFA -> ttyUSB0
lrwxrwxrwx 1 root root 7 Jan 30 15:17 /dev/ttyUSB-RFX433 -> ttyUSB1
lrwxrwxrwx 1 root root 7 Jan 30 15:17 /dev/ttyUSB-ZIGBEE -> ttyUSB2
lrwxrwxrwx 1 root root 7 Jan 30 15:17 /dev/ttyUSB-ZWAVE -> ttyACM1
pi@snoepie:~/domoticz/scripts/lua $ lsusb
Bus 001 Device 006: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
Bus 001 Device 014: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Bus 001 Device 016: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]
Bus 001 Device 015: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
Bus 001 Device 013: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 012: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 005: ID 154b:f009 PNY
Bus 001 Device 008: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Any one an idea was this can be so it worked before, I think it was do with opening device of the Aeotec Z-Stick Gen 5 but I am not sure?
logging dmesg
[ 20.466532] Bluetooth: BNEP socket layer initialized
[ 499.190656] usb 1-1.2.1.2: USB disconnect, device number 10
[ 517.330298] ftdi_sio ttyUSB2: usb_serial_generic_read_bulk_callback - urb stopped: -32
[ 517.330319] cp210x ttyUSB1: usb_serial_generic_read_bulk_callback - urb stopped: -32
[ 517.330413] ftdi_sio ttyUSB2: usb_serial_generic_read_bulk_callback - urb stopped: -32
[ 517.330421] cp210x ttyUSB1: usb_serial_generic_read_bulk_callback - urb stopped: -32
[ 517.385197] usb 1-1.2.1.4: USB disconnect, device number 11
[ 517.385415] cp210x ttyUSB1: failed set request 0x7 status: -19
[ 517.385428] cp210x ttyUSB1: failed set request 0x12 status: -19
[ 517.385435] cp210x ttyUSB1: failed set request 0x0 status: -19
[ 517.395241] cp210x ttyUSB1: cp210x converter now disconnected from ttyUSB1
[ 517.395320] cp210x 1-1.2.1.4:1.0: device disconnected
[ 517.397950] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.398046] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.398178] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.398295] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.398430] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.398435] usb 1-1.2-port1: Cannot enable. Maybe the USB cable is bad?
[ 517.398543] usb 1-1.2-port1: cannot disable (err = -32)
[ 517.398665] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.398790] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.398925] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.399040] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.399185] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.399190] usb 1-1.2-port1: Cannot enable. Maybe the USB cable is bad?
[ 517.399292] usb 1-1.2-port1: cannot disable (err = -32)
[ 517.399420] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.399558] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.399675] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.399792] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.399916] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.399921] usb 1-1.2-port1: Cannot enable. Maybe the USB cable is bad?
[ 517.400041] usb 1-1.2-port1: cannot disable (err = -32)
[ 517.400172] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.400294] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.400417] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.400543] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.400669] usb 1-1.2-port1: cannot reset (err = -32)
[ 517.400674] usb 1-1.2-port1: Cannot enable. Maybe the USB cable is bad?
[ 517.400793] usb 1-1.2-port1: cannot disable (err = -32)
[ 517.400920] usb 1-1.2-port1: cannot disable (err = -32)
[ 517.401550] hub 1-1.2:1.0: hub_ext_port_status failed (err = -32)
[ 517.411231] usb 1-1.2.1: USB disconnect, device number 7
[ 517.429555] usb 1-1.2: USB disconnect, device number 4
[ 517.517127] usb 1-1.2.4: USB disconnect, device number 9
[ 517.517332] ftdi_sio ttyUSB2: error from flowcontrol urb
[ 517.518460] ftdi_sio ttyUSB2: FTDI USB Serial Device converter now disconnected from ttyUSB2
[ 517.518548] ftdi_sio 1-1.2.4:1.0: device disconnected
[ 517.936143] usb 1-1.2: new high-speed USB device number 12 using dwc_otg
[ 518.066763] usb 1-1.2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 518.066774] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 518.066780] usb 1-1.2: Product: USB 2.0 Hub
[ 518.067314] hub 1-1.2:1.0: USB hub found
[ 518.067431] hub 1-1.2:1.0: 4 ports detected
[ 518.486205] usb 1-1.2.1: new high-speed USB device number 13 using dwc_otg
[ 518.716840] usb 1-1.2.1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 518.716853] usb 1-1.2.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 518.716859] usb 1-1.2.1: Product: USB 2.0 Hub
[ 518.717457] hub 1-1.2.1:1.0: USB hub found
[ 518.717583] hub 1-1.2.1:1.0: 4 ports detected
[ 518.916195] usb 1-1.2.4: new full-speed USB device number 14 using dwc_otg
[ 519.169862] usb 1-1.2.4: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
[ 519.169874] usb 1-1.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 519.169887] usb 1-1.2.4: Product: RFXtrx433
[ 519.169893] usb 1-1.2.4: Manufacturer: RFXCOM
[ 519.169899] usb 1-1.2.4: SerialNumber: A1XFDOXJ
[ 519.175316] ftdi_sio 1-1.2.4:1.0: FTDI USB Serial Device converter detected
[ 519.175435] usb 1-1.2.4: Detected FT232RL
[ 519.177124] usb 1-1.2.4: FTDI USB Serial Device converter now attached to ttyUSB1
[ 519.347474] usb 1-1.2.1.2: new full-speed USB device number 15 using dwc_otg
[ 519.579490] usb 1-1.2.1.2: New USB device found, idVendor=0658, idProduct=0200, bcdDevice= 0.00
[ 519.579503] usb 1-1.2.1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 519.580403] cdc_acm 1-1.2.1.2:1.0: ttyACM1: USB ACM device
[ 519.776203] usb 1-1.2.1.4: new full-speed USB device number 16 using dwc_otg
[ 520.015186] usb 1-1.2.1.4: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
[ 520.015198] usb 1-1.2.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 520.015204] usb 1-1.2.1.4: Product: slae.sh cc2652rb stick - slaesh's iot stuff
[ 520.015210] usb 1-1.2.1.4: Manufacturer: Silicon Labs
[ 520.015216] usb 1-1.2.1.4: SerialNumber: 00_12_4B_00_21_CB_F2_49
[ 520.017802] cp210x 1-1.2.1.4:1.0: cp210x converter detected
[ 520.021119] usb 1-1.2.1.4: cp210x converter now attached to ttyUSB2
Any one an idea?
