how to copy data from watermeter to waterflow [Solved]
- Domoticz version: 2022.2
i have a virtual watermeter(counter incremental) which receives the liters used.
it does so on a 60 second base.
now i want to copy what is send to the watermeter also to the waterflow(virtual device) to get the amount of liters/minute.
should be straight forward but i can not get this to work.
i either need what was send to the watermeter also send to the waterflow
or
watermeter-current-value minus watermeter-previous-value send to waterflow.
using the watermeter as a trigger device
is there an easy way to do this?
It can be done by using json but it seems a bit as a workaround(use json to update the weaterflow)
also does this command domoticz.device(' waterflow' ).update(liters) exist.
i know there are a lot of update features but they are not available on a flow device, only on temp and barometer or energy devices
thanks
or
thanks
- waaren
Re: how to copy data from watermeter to waterflow
Could look like below
dzVents has a native method WaterflowUpdate for this since version 2.1 (domoticz V3.8088)i know there are a lot of update features but they are not available on a flow device, only on temp and barometer or energy devices
return
on =
devices =
'waterMeter', -- change to name of your watermeter
data =
water =
initial = {},
execute = function(dz, item)
local factor = 1 -- this might need to be changed depending on if your meter is in liters or m3 or different.
local waterFlow = dz.devices('waterFlow')
local waterTotal = tonumber(item.sValue) * factor -- watermeter can be of type counter or custom sensor sValue works for both
if dz.data.water.total ~= nil then -- first reading does not update the flowmeter
waterFlow.cancelQueuedCommands()
local pastTime = dz.data.water.lastTime - dz.time.dDate -- seconds since last time
local waterFlowValue = ( waterTotal - dz.data.water.total ) * 60 / math.max(pastTime,60) -- liter / min
waterFlow.updateWaterflow(waterFlowValue)
waterFlow.updateWaterflow(0).afterSec(60) -- if no new data within 60 seconds the reset flow to 0
dz.data.water.total = waterTotal
dz.data.water.lastTime = dz.time.dDate
hmm.
getting this error
lua:27: attempt to index a number value (local 'waterFlow')
line 27 is waterFlow.updateWaterflow(waterFlow)
i named my flow meter waterFlow like in the script.
could it be that the local name being the same as the device name is causing this?
getting this error
- waaren
Can you change line 26/27 to
ok tried again but the waterflow meter (named Flow) updates with a value of 446464
UPDATE
found the problem
my watermeter is an incremental counter so i needed to use .counterToday
Thanks Waaren for the help
UPDATE
found the problem
return
on =
devices =
'Watermeter', -- change to name of your watermeter
data =
water =
initial = {},
local waterFlow = dz.devices('Flow')
local waterTotal = item.counterToday * factor -- watermeter can be of type counter or custom sensor sValue works for both
waterFlow.updateWaterflow(0).afterSec(5) -- if no new data within 60 seconds the reset flow to 0
@waaren, can you look at this script.
i modified it so i can calculate a more accurate flow
the watermeter now gets updated instantly
i then calculate the time between 2 updates to calculate the flow.
It seems to work allright but the flow fluctuates a bit and i am not sure i did calculate things right.
i
i
return
on =
devices =
data =
water =
initial = {},
local Time = require('Time')
local currentTime = Time()
local factor = 1000 -- this might need to be changed depending on if your meter is in liters or m3 or different.
if dz.data.water.total ~= waterTotal then -- first reading does not update the flowmeter
local pasttime = (currentTime.compare(dz.data.water.lastTime).milliseconds)
local waterFlowValue = 60000 / pasttime
waterFlowValue = dz.round(waterFlowValue,2)
waterFlow.updateWaterflow(0).afterSec(60) -- if no new data within 60 seconds then reset flow to 0
dz.data.water.lastTime = currentTime
- waaren
In terms of script-logic I don't see a problem but you assume here an accuracy that is simply not there.
The watermeter total is not updated every second let alone milliseconds and even if that would be the case, the performance optimized way dzVents and Lua bundles information from all devices to be processed in the scripts causes the real time data to be off by sometimes more then a second.
So for the sake of understanding the process it's ok but please don't take it to serious.
Another thing to consider here is that you now write the complete dzVents time object as a table to persistent data.
This will write 189 lines 4150 bytes to disk every run. In the original script it was 7 lines / 150 bytes
Yes i know accuracy is off but in the old situation it was even worse.
old situation Watermeter update once every 60 seconds: resolution 1 liter
new situation Watermeter updates with usage of every liter :resolution better than 1 liter(but it still fluctuates with a delta of 2 liters)
is there anything i can do to avoid flooding memory and still get a little better accuray than 1 liter or 1 second?
if not i might go back to the old situation.
i like it that the Watermaeter changes instantly on usage but the flow functionality is not more accurate, just faster in updating the real flow
- waaren
Not with domoticz.
ok, clear.
i however noticed that the compare function can be used to compare on a millisecond level but the outcome is still on a second resolution base
eg it is comparing 2 times but the difference is not measured in milliseconds but in seconds/1000
This is the reason i still get 8,57L or 10 liter as outcome
i noticed that when you use data with history is true you can compare 2 timestamps and get the difference in milliseconds by using the msAgo option.
Tried something but i lack the knowlegde
if this works on the current data we can get low memory usage and still get better resolution
The only thing i want is something more accurate than 1 liter or 1 second
eg 8,57 or 10 liter means the real usage is probably more towards the 10 liter but missing 1 pulse drops the outcome to 8,57
local pastTime = tonumber (t.compare(dz.data.water.lastTime).ms)
Hello all,
I have try to use the script but I run into problems, I can't get it to work.
From what I found the value dz.data.water.total always stays nil
2021-01-28 17:55:46.718 Status: dzVents: Info: Handling events for: "Watermeter", value: "18446744073709453933"
2021-01-28 17:55:46.718 Status: dzVents: Info: ------ Start internal script: Waterflow-1-1: Device: "Watermeter (Dummy)", Index: 141
2021-01-28 17:55:46.718 Status: dzVents: Info: ------ Finished Waterflow-1-1
2021-01-28 17:55:46.718 Error: dzVents: Error: (3.0.2) An error occurred when calling event handler Waterflow-1-1
2021-01-28 17:55:46.718 Error: dzVents: Error: (3.0.2) ...ticz/scripts/dzVents/generated_scripts/Waterflow-1-1.lua:21: attempt to concatenate a nil value (field 'total')
return
on =
devices =
data =
water =
initial = { 0 },
dz.log (' waterTotal= ' .. dz.data.water.total, dz.LOG_FORCE)
local pastTime = dz.time.dDate - dz.data.water.lastTime -- seconds since last time
if pastTime > 55 then
local waterFlow = dz.devices('Waterflow')
dz.log (' waterTotal= ' .. waterTotal, dz.LOG_FORCE)
local waterFlowValue = dz.utils.round((( waterTotal - dz.data.water.total ) * 60) / pastTime, 2) -- liter / min
dz.log (' waterFlowValue= ' .. waterFlowValue, dz.LOG_FORCE)
if waterFlowValue > 0 then
waterFlow.updateWaterflow(0).afterSec(70) -- if no new data within 60 seconds the reset flow to 0
Best regards Bert
Synology DS1517+ - DSM 6.2
the Watermeter in my situation is a dummy counter(not incremental)
after that i have set it to water.
so it is not a waterflow device
i do not use this script anymore
i use the esp to give me both the counter and waterflow(in 0,1 liter)
so basically the esp holds the complete countertotal and sends that value to domoticz
this way i always get the correct value
the same goes for waterflow.
it turns out the esp pulsecounter sends out a time between pulss in ms. i use this number to calculate the exact flow and send this value over to domoticz.
so not more problems regarding timing and fast/slow calls
- waaren
The changes made to the script is causing it to fail and that 's why the persistent data is not set / updated ever.
Can you try with this one?
return
on =
devices =
data =
water =
initial = { },
dz.log (' waterTotal= ' .. ( dz.data.water.total or 'not set yet'), dz.LOG_FORCE)
dz.data.water.lastTime = dz.data.water.lastTime or os.time()
local pastTime = os.time() - dz.data.water.lastTime -- seconds since last time
dz.data.water.lastTime = os.time()
dz.data.water.total = 0
I tried the new code and this is what it is telling me.
I hope you can help me a bit with this.
- Spoiler: show
Best regards Bert
- waaren
Sure,
I updated my earlier posted version (the one at 20:00 hr.) It should now only give this message once.
Hi Waaren,
Indeed the new code prevented only gives the message once.
But now i'm running into new problems. The lastTime variable is nil.
- Spoiler: show
Best regards Bert
- waaren
Sure,
This type of errors occur usually because a variable is not initialized yet. That's also why you get this error here.
It should be solved by below line where the value of dz.data.water.lastTime is initialized with current time (in seconds from 1/1/1970) when stil nil
Thanks once more, now I'm getting values in.
Many thanks for your quick replies and your great help.!
Best regards Bert
I think you could better use
instead of
because value is calculated relative to previous value. No difference in displayed flow value, but counterToday is daily set to 0 at nighttime and results in a negative flow.
item.counter
item.counterToday
- Domoticz version: 2022.1
Hello, I hope you are still monitoring this thread. Could elaborate on your esp setup? What esp are you using, etc. Thank youGravityz wrote: ↑Thursday 28 January 2021 18:20 the Watermeter in my situation is a dummy counter(not incremental)
Debian buster on NUC and three RPi with buster.
Users browsing this forum: iw2fag and 1 guest
