setKelvin(Kelvin): Function  [Solved]
deennoo
Post by deennoo »
First step using Dzevents.
My goal is to use the set kelvin fonction on a Yeelight Desktop lamp (as a test, finaly to all bulb and light from various brand all around the house)
I want to use ; setKelvin(Kelvin): Function for an adaptative Kelvin value depending on sun position
my basic LUA time script is :
local mini = 100 --kelvin max range
local maxi = 0 --kelvin min range
local delta = maxi - mini
local wakeup = 60*timeofday['SunriseInMinutes']
local goodnight = 60*timeofday['SunsetInMinutes']
local periode = goodnight - wakeup
local offset = wakeup-periode/2
local color = mini
local time = os.date("*t")
local now = 60*(time.hour*60 + time.min)
if now >= wakeup and now < goodnight then
	color = math.floor((maxi-delta/2)+(delta/2)*math.cos((now-offset)*2*math.pi/periode)+0.5)
print('color:'..color)
if otherdevices['test']~='Off' then
commandArray['OpenURL']='http://127.0.0.1:8080/json.htm?type=command&param=setkelvinlevel&idx=24&kelvin='..color..'' '
Basic but working as a charme, next step is to retrive kelvin value, and update only if necesseary every 5 minutes
As DzEvent is the futur and i try to translate this with this :
local mini = 100
local maxi = 0
local color = mini
		timer = {
			'every minute',
	execute = function(domoticz, timer)
		domoticz.log('colordz events:'..color)
		domoticz.devices('test').setKelvin(color)
Log answer is :
2021-01-23 09:41:00.274 Error: dzVents: Error: (3.1.2) Method setKelvin is not available for device "test" (deviceType=Color Switch, deviceSubType=White). If you believe this is not correct, please report.
My device correctly answer to domoticz api
http://127.0.0.1:8080/json.htm?type=command&param=setkelvinlevel&idx=24&kelvin=25
http://domo-attitude.fr
Re: setKelvin(Kelvin): Function
deennoo wrote: Saturday 23 January 2021 9:44 Log answer is :
Thx for reporting.
I assume the subType 'White'was not in use yet when this dzVents function was created.
Can you please try again after changing line 36 of the file
<domoticz dir>/dzVents/runtime/device-adapters/rgbw_device.lua
from
		if (device.deviceSubType == 'RGBWW') or (device.deviceSubType == 'WW')  then
to
		if (device.deviceSubType == 'RGBWW') or (device.deviceSubType == 'WW') or (device.deviceSubType == 'White')  then
If that is successful I will patch it into dzVents and make it available in the next domoticz build.
deennoo
Post by deennoo »
waaren wrote: Saturday 23 January 2021 10:52
The Job is done !
Maybe can be usefull to create setAutoKelvin function using "color" function of my script who come from : https://github.com/vil1driver/lua
deennoo wrote: Saturday 23 January 2021 11:11 The Job is done !
Thx for testing !
I am not sure I understand. Is this function different then what is already available in the dzVents rgbw device-adapter? as setColor or any of the other functions?
deennoo
Post by deennoo »
On this fonction the name is color but must be named : whitetemp.
Idea is to automatise white temp on Sun position (surely this must be done on domoticz widget side).
deennoo wrote: Saturday 23 January 2021 12:57 On this fonction the name is color but must be named : whitetemp.
Probably a language thing but I do not understand.
deennoo
Post by deennoo »
waaren wrote: Saturday 23 January 2021 15:12
My fault, i don't speak about setkelvin function
Spoking about :
local mini = 100
local maxi = 0
local color = mini
Who is a way to make kelvin value follow sun position and make de white temp to be automaticaly adapted to sun position like Philips Hue made, they call it adaptative light
https://www.imore.com/philips-hue-homek ... ing-update
Maikel76
Domoticz version: 2022.1
Post by Maikel76 »
Spoking about :
local mini = 100
local maxi = 0
local color = mini
Goodafternoon,
I was looking for something that’s calculates this Kelvin value and stumbled upon your post. Thanks a lot for posting
Scripting is my passion, dzVents, LUA, Bash
Dashticz v3.10.7 Beta --Raspbian Buster
