according to Config/fibaro/fgt001.xml
the fibaro heat controller is supported, but i'm just getting "Unknown: id=010f Unknown: type=1301, id=1001+"
in the hardware list, and the 3 exposed "Thermostat, Setpoint" devices dont do anything.
am i missing something? From the other forums posts i found it sounded like it just worked out of the box once the openzwave config is updated, which does seem to be the case in the current release (2020.2)
domoticz FGT-001 unknown
smaus
Re: domoticz FGT-001 unknown
Same problem here, i folow this
smaus
When i include the fibaro fgt-001 on my synology i get hardware Unknown: id=010f Unknown: type=1301, id=1001+
When i incude the fibaro fgt-001on my raspberry then i get the hardware fgt001 heat controller.
Can somebody help me with this problem.
smaus
Solved
I install te latest domoticz from jadahl
brandie21474
- Domoticz version: ß
What exactly was your solution?
I run the latest stable version on domoticz on my rpi and mine tells me its an unkown id en unkown typ e just like yours.
Maybe your solution can help me as well.
smaus
Installing the latest version of domoticz
