Open Weather Map language Topic is solved
JanvdW
Post by JanvdW »
In the Open Weather Map configuration in Dashticz (CONFIG.js) I have set both [owm_country] and owm_lang] to 'NL'. This results in a Dutch description of the weather, but the days are still in English (which is different in the manual. I think that this is caused by the English client OS, but it would be nice if the days are presented in the language that is set in OCNFIG.js as well.
HansieNL
Re: Open Weather Map language
Post by HansieNL »
Do you have the following language setting?
config['language'] = 'nl_NL';
Edit:
Check also the following language setting:
config['calendarlanguage'] = 'nl_NL';
Blah blah blah
JanvdW
Post by JanvdW »
The 'language' parameter was fine, but I had no ''calendarlanguage' set. That did the trick and solved the issue. Thanks!
