Run a bash script with remote SSH Topic is solved
All kinds of 'OS' scripts
Number8
Domoticz version: 2022.1
Post by Number8 »
I'd like to run a bash script with a remote SSH session.
Logged as a standard user on computer from which I want to initiate the ssh session the following command works
ssh [email protected] sh ~/backupInflux.sh
Now I'm trying to get this working within dzVents context (dzVents 3.0.14 not 3.1 yet). So I'm using the generic os.execute command.
local cmd = 'ssh [email protected] sh ~/backupInflux.sh&'
os.execute(cmd)
os.excute runs (no error in Domoticz log file) but it does not work.
I know the trick is related to the parameters that are passed to the ssh command. How should I proceed?
Thank you
Debian buster on NUC and three RPi with buster.
Re: Run a bash script with remote SSH
Number8 wrote: Thursday 14 January 2021 18:38 os.excute runs (no error in Domoticz log file) but it does not work.
Before dzVents 3.1.0
I used below function for shell access because it does return more information.
the ssh command should look something like
 ssh user@remote ' command  '
        local function osCommand(cmd)
            dz.log('Executing Command: ' .. cmd,dz.LOG_DEBUG)
            local fileHandle = assert(io.popen(cmd, 'r'))
            local commandOutput = assert(fileHandle:read('*a'))
            local returnTable = {fileHandle:close()}
            dz.log("ReturnCode: " .. returnTable[3] .. "\ncommandOutput:\n" .. commandOutput, dz.LOG_DEBUG)
            if returnTable[3] ~= 0 then
                dz.log("ReturnCode: " .. returnTable[3] .. "\ncommandOutput:\n" .. commandOutput, dz.LOG_ERROR)
            return commandOutput,returnTable[3] -- rc[3] contains returnCode
Number8
Post by Number8 »
Thanks waaren. Based on your code here is the current code and the log
local cmd = "ssh -oKexAlgorithms=+diffie-hellman-group1-sha1 [email protected] 'sh home/pi/backupInfluxA.sh'"
	os.execute(cmd)
Log reports
2021-01-14 19:59:08.090 Status: dzVents: Debug: test script: Executing Command: ssh -oKexAlgorithms=+diffie-hellman-group1-sha1 [email protected] 'sh home/pi/backupInfluxA.sh'
2021-01-14 19:59:08.234 Status: dzVents: Debug: test script: ReturnCode: 255
2021-01-14 19:59:08.234 commandOutput:
2021-01-14 19:59:08.235 Status: dzVents: Info: test script: ------ Finished 9forTest.lua
2021-01-14 19:59:08.234 Error: dzVents: Error: (3.0.14) test script: ReturnCode: 255
Number8 wrote: Thursday 14 January 2021 20:12 'sh home/pi/backupInfluxA.sh'
Should it not be 'sh /home/pi/backupInfluxA.sh' ?
Number8
Post by Number8 »
waaren wrote: Thursday 14 January 2021 20:34
Indeed, you're right thank you. I corrected it, same errors
Number8 wrote: Thursday 14 January 2021 21:00 same errors
Can you try it without the sh, so that it will use the default shell
Things to try
'/home/pi/backupInffluxA.sh'
'sh -c /home/pi/backupInffluxA.sh'
'sh -cl /home/pi/backupInffluxA.sh'
'sh -clv /home/pi/backupInffluxA.sh'
Number8
Post by Number8 »
Thanks for that. I tried the 4 options, same 255 error code returned. What this code is supposed to mean?
So the calling code is currently
local cmd = "ssh -oKexAlgorithms=+diffie-hellman-group1-sha1 [email protected] ~/backupInfluxA.sh"
or
local cmd = "ssh -oKexAlgorithms=+diffie-hellman-group1-sha1 [email protected] '~/backupInfluxA.sh'"
and then calling the function. I checked that ~/ points to the right directory
Number8 wrote: Thursday 14 January 2021 23:28 Thanks for that. I tried the 4 options, same 255 error code returned. What this code is supposed to mean?
code 255 is the same as code 1. Not very useful without errormessage. Did you already tried to do it with sudo and with the full qualified filename?
Number8
Post by Number8 »
waaren wrote: Friday 15 January 2021 0:40
Yes I did, and I doubled checked just now.
Just to see what is the result I replaced the command by "ls". Same error reported
Number8 wrote: Friday 15 January 2021 8:17 Just to see what is the result I replaced the command by "ls". Same error reported
Below script works for me since 2019
Not sure if it is of any help to you but it proves it is possible
local scriptVersion = '0.201909201700'
local scriptVar  =  'TMEP_' .. scriptVersion
This dzVents script is used to send temperature and humidity data to a TMEP database
see  https://github.com/MultiTricker/TMEP for details on how to use and setup.
The script use os.popen to trigger a mySQL insert statement
It also tested and works for a remote system if the system with the TMEP database
can be accessed by the user that is running the domoticz service, via password-less
SSH (with public / private key setup)
Be aware that even if domoticz runs as root it will not behave the same
as from the command line because it can use a different OS environment.
That can imply that if you can access the database from the command line without password
you still need to use that when access from the domoticz program.
Before activating the script:
    Read the GETTING STARTED section of the dzVents wiki.
    Change the values in the script to reflect your setup
    Change the names / ID s of your humidity and temperature devices
return
    on =
         timer = { 'every 15 minutes' },  -- Set to required frequency
    logging =
        level = domoticz.LOG_ERROR, -- set to LOG_ERROR when tested and OK
        marker = scriptVar,
   execute = function(dz)
        local db = {
                        name = 'TMEP',             -- database name
                        user = 'waaren',           -- change to your database username
                        userPassword = 'obscured',   -- set userPassword = false (without quotes) when you can access the database without
                        remoteHost = 'dz',        -- set remoteHost = 'remote hostname' when database is remote
                        sudoRequired = false,      -- set true or false
                        temperatureDevice = 2289, -- change to your temperature sensor "name" or idx
                        humidityDevice = 2289,      -- change to your humidity sensor "name" or idx
                        table = 'tme',           -- these table- and fieldnames probably do not need to change
                        dateTime = 'kdy',
                        temperature = 'teplota',
                        humidity = 'vlhkost',
        --               NO changes required below this line
        local temperature = dz.utils.round(dz.devices(db.temperatureDevice).temperature,1)
        local humidity = dz.utils.round(dz.devices(db.humidityDevice).humidity,1)
        local function buildCommand(temperature, humidity)
            local sshBOL =  ( db.remoteHost and "ssh "  .. db.remoteHost .. " \'" ) or ''
            local sshEOL =  ( db.remoteHost and ";\'" ) or ';'
            local password = ( db.userPassword and " -p" .. db.userPassword .. " "  ) or ''
            local sudo = (db.sudoRequired and "sudo " ) or ''
            local cmd = sshBOL ..
                        sudo .. " echo \" INSERT INTO " ..
                        db.table .. "(" ..
                        db.dateTime .. ", " ..
                        db.temperature .. ", " ..
                        db.humidity .. ")" .. "VALUES (NOW(), " ..
                        humidity .. ") \" | mysql -v -u " ..
                        db.user ..
                        password .. " " ..
                        db.name ..
                        sshEOL
            return cmd
        osCommand(buildCommand(temperature , humidity))
Number8
Post by Number8 »
Thanks a lot, I will try to mimic your code and report back
Number8
Post by Number8 »
I implemented your script, without sending the command to have a look at the build-up of the ssh command line. It gives (I set dz to some IP address to have something meaningfull:
ssh 192.168.21.110 ' echo " INSERT INTO tme(kdy, teplota, vlhkost)VALUES (NOW(), 25, 90) " | mysql -v -u waaren -pobscured TMEP;'
I noticed there is no user attached to the IP address. How could it be (I guess you have setup a public/private key set up as well)?
Number8 wrote: Friday 15 January 2021 15:08 I noticed there is no user attached to the IP address. How could it be (I guess you have setup a public/private key set up as well)?
Yes, as it's described in the comments at the beginning of the script
Number8
Post by Number8 »
waaren wrote: Friday 15 January 2021 17:06
oh yes sorry for that. The only difference I see so far, in your case the remote machine grants the connection since the account the cllent uses exists on the remote, hence there is no need to declare it in the connection string. In my case I have to make it explicit.
I have a Domoticz test gear, I will carry some tests from this one to the same remote (it will be same OS, that is Raspian Buster) to see how it goes. As far as Domoticz is concerned, it is beta updated, I'll test ir with the new method as well. I'll keep you posted.
Number8
Post by Number8 »
I have a freshly compiled Domoticz running in a VM. Test has been carried you with the newly cooked function domoticz.executeShellCommand(). Now we know why is does not work: Key verification failed
local cmd = 'ssh [email protected] "sh ~/backupInfluxA.sh"'
dz.executeShellCommand({
     command = cmd,
     callback = 'shell',
     timeout = 5,   })
{["dump"]=function, ["isHTTPResponse"]=false, ["timeoutOccurred"]=false, ["data"]="", ["callback"]="shell", ["isHardware"]=false, ["isGroup"]=false, ["isCustomEvent"]=false, ["baseType"]="shellcommandResponse", ["isSystem"]=false, ["isDevice"]=false, ["errorText"]="Host key verification failed. ", ["hasLines"]=false, ["isVariable"]=false, ["statusCode"]=0, ["isScene"]=false, ["isTimer"]=false, ["isXML"]=false, ["ok"]=true, ["isShellCommandResponse"]=true, ["shellCommandResponse"]="shell", ["isJSON"]=false, ["isSecurity"]=false, ["trigger"]="shell"}
As a matter of fact the private/public key is set-up for pi account. What could cause the error then? Bash script owner is pi. An it still works when using ssh in console mode
Number8 wrote: Saturday 16 January 2021 15:23 As a matter of fact the private/public key is set-up for pi account. What could cause the error then? Bash script owner is pi. An it still works when using ssh in console mode
If your domoticz is not executed as user pi the process cannot find the key. You will have to do something with the su command I guess.
erem
Domoticz version: 2021.1
Post by erem »
to set this up correctly
1- on the source machine
- sudo su
- whoami (should return root)
- ssh pi@target machine
answer the questions
The authenticity of host 'target)' can't be established.
ECDSA key fingerprint is SHA256:dKNyChgyMqAaenlhW/Cvq2M0+BOojZvi3koKbQlqUOw.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added 'target' (ECDSA) to the list of known hosts.
pi@target password:
once connection has been made once, subsequent connections should not ask for pw.
Regards,
Rob
Number8
Post by Number8 »
@erem: this is it! Thank you very much. The mistake I made was related to the fact that I did not generate the public/private key pair from su account. Thanks a lot to waaren as well that has been very helpfull to tackle the issue. I made the test with both methods os.execute() and domoticz.executeShellCommand() that are working as expected now.
