How to update a variable via json on a remote domoticz Topic is solved
aleph0
Domoticz version: 11838
Post by aleph0 »
Hi All !
I'm in need to update a variable on a remote domoticz via json & curl :
- remote domoticz is IP accessible on port 8080
- a dedicated user exists, with "user" rights on a remote domoticz and a few devices authorised
- this user can be successfuly used to update remotely that devices via json & curl
- but If I try to update a variable with curl "http://user:pass@ip:port/json.htm?type=command&param=updateuservariable&vname=SunRayDirect&vtype=1&vvalue=106.0" I always get a 403 Forbidden answer and can't figure out how to autorize my user to update a var :?:
Of course a workaround can be to use a device instead, but it's overkill for my need :-/
I'm I missing something ?
aleph0
Re: How to update a variable via json on a remote domoticz
Post by aleph0 »
Nobody ?
Envoyé de mon moto g(6) en utilisant Tapatalk
felix63
Domoticz version: 2020.1
Post by felix63 »
Try using the username, Password from Settings / Website Protection instead of those of one of the Domoticz users.
Bon chance
Tukker
Domoticz version: 2023.2
Post by Tukker »
In case you have a Raspberrypi I suggest you'd start by installing PiVPN using wireguard.
Your startpoint then will be a secure encrypted connecting.
Once connected it will be as if your inside your device running Domoticz.
All the freedom with a secure connection.
Bugs bug me.
aleph0 wrote: Thursday 14 January 2021 13:46 I'm I missing something ?
You need admin rights to update a uservariable
See this github issue
aleph0
Post by aleph0 »
waaren wrote: Sunday 17 January 2021 0:35 You need admin rights to update a uservariable
It works :-) Thanks for pointing this out :-)
