Problem installing Domoticz Topic is solved
robinvd
Domoticz version: 2021.1
Post by robinvd »
I used Domoticz for a few years on a raspberry pi, also installed in on windows e.t.c. never had any problems. Now I want to test a new simple setup using Domoticz. I downloaded en installed Raspbian, and then used The "easy" way to install Domoticz. It all seems to go well. Until I try to reach the webpage of Domoticz, its not responding on remote pc/Mac and also not on localhost in the raspbian browser.
I'm using a Model 3B
This is what I tried:
Checked if the port 8080 is in the list of used ports - it's not.
pi@raspberrypi:~ $ wget localhost:8080
converted 'http://localhost:8080' (ANSI_X3.4-1968) -> 'http://localhost:8080' (UTF-8)
--2021-01-13 00:18:01--  http://localhost:8080/
Resolving localhost (localhost)... ::1, 127.0.0.1
Connecting to localhost (localhost)|::1|:8080... failed: Connection refused.
Connecting to localhost (localhost)|127.0.0.1|:8080... failed: Connection refused.
Checked if Domoticz is running - it is running, but there is an error message.
raspberrypi domoticz.sh[560]: /home/pi/domoticz/domoticz: error while loading shared libraries: libssl.so.1.1: cannot open sh...irectory
So I searched the web for a few hours, trying a couple of things to install or add libssl.so.1.1, with no result.
I later tried it on an different raspberry pi (Model 2), with an different SD card.
I now don't now what to do anymore... is there somebody who nows?
Thank you,
Robin
Re: Problem installing Domoticz
robinvd wrote: Wednesday 13 January 2021 0:16 I now don't now what to do anymore... is there somebody who knows?
Robin
What is your OS version ?
You can check with
sudo cat /etc/os-release
sudo lsb_release -a
sudo uname -r
robinvd
Post by robinvd »
I checked on witch version it is:
pi@raspberrypi:~ $ sudo cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
pi@raspberrypi:~ $ sudo lsb_release -a
No LSB modules are available.
Distributor ID:	Raspbian
Description:	Raspbian GNU/Linux 8.0 (jessie)
Release:	8.0
Codename:	jessie
pi@raspberrypi:~ $ sudo uname -r
4.9.35-v7+
robinvd wrote: Wednesday 13 January 2021 12:28 I checked on witch version it is:
current domoticz releases require buster. You are two OS levels behind.
robinvd
Post by robinvd »
Thanks, I was using a already installed Raspberry and tried to install it on top of it. I downloaded a new version and now it's working.
