SPIRITZ Wall Radiator Thermostat read opening value %
- jursat
- Domoticz version: 2023.2
I need to read the % opening value from the thermostatic head, I use the SPIRITZ Wall Radiator Thermostat, it still throws me an error, all I need is to be able to read and work with the value. I see the value in the Dashboard settings. I need it if the relay turns off below a certain value and vice versa.
thank you
thank you
harrykausl
- Domoticz version: 2021.1
Re: SPIRITZ Wall Radiator Thermostat read opening value %
I do it like this, heating_name is the name of the level device. You'll get back Off (0%) or the percentage with text.
level = otherdevices[heating_name]
if ( level == "Off" ) then
heating_level = "Ventil zu"
heating_level = string.gsub ( level,"Set Level:", "Ventil")
- jursat
Thank you for the answer, how you have solved the switching on of the boiler, I have 5 rooms and I also need to turn it on, if it is necessary for each room separately
harrykausl
I switch off the spirit thermostat by setting the mode to off (mode 0) (for example, when a window is opended) and set it back to heat (mode 3), when it is closed.
Setting the mode I do like this:
idx = otherdevices_idx[heating_name]
commandArray['UpdateDevice'] = idx.."|" .. heating_mode .. "|" .. heating_mode
- jursat
I meant that if the Spirit needs heat, it will also give the command to turn on the boiler
harrykausl
You can look at the opening of the velve.
- jursat
I'm sorry, can you explain to me where to put the code?harrykausl wrote: Monday 11 January 2021 16:40 I do it like this, heating_name is the name of the level device. You'll get back Off (0%) or the percentage with text.
level = otherdevices[heating_name] if ( level == "Off" ) then heating_level = "Ventil zu" else heating_level = string.gsub ( level,"Set Level:", "Ventil") end
harrykausl
In a lua script.
- jursat
2021-01-13 17:39:15.365 Error: EventSystem: in Hlavica je otvorena: [string "..."]:6: bad argument #1 to 'gsub' (string expected, got nil)
harrykausl
It seems, that level is empty. You should test it with a "print ( level)", you can see the result in the protocol. Perhaps you don't have the correct name of the device. heating_name is a variable, which contents the name of the level device. I use this normally in a function, where it is passed as a argument.
function libs.heating_get_level ( heating_name )
-- ermittelt den Ventilstand des Heizkoerpers heizung_name
return heating_level
- jursat
Es funktioniert nicht, also noch einmal für den Amateur
1. Der Name des Kopfes, von dem ich Daten lesen möchte, ist "Radiator"
2. In welche Variable wird es geschrieben? Was soll ich erstellen?
Ich benutze Domoticz für Synology
Vielen Dank für Ihre Geduld
harrykausl
Do you have the Eurotronic Spirit Zwave+ Thermostat?. My scripts belong to this. If yes, you can see in your devices a device which contains leve in the name. This name you have to use.
- jursat
Yes, I have EUR_SPIRITZ Wall Radiator Thermostat+ titled "Radiator" , and script name is Valve opened, but it is still an error:
2021-01-14 18:47:49.978 Error: EventSystem: in Valve opened: [string "function libs.heating_get_level ( Radiator )..."]:1: attempt to index a nil value (global 'libs')
my script
level = otherdevices[Radiator]
my script
harrykausl
The function in my example is in a library called libs, so if you want to do it like this, you have to use a lib.
You can use the statement in a normal script without a lib, level = otherdevices (´radiator´)
- jursat
script
Error
2021-01-14 20:05:15.518 Error: EventSystem: in Valve opened: [string "level = otherdevices[Radiator] ..."]:9: <eof> expected near 'end'
Error
harrykausl
In which event will this script be called? Perhaps you should have a look at lua descripion in the wiki, or you use blockly.
- jursat
I need to turn the boiler on and off.
If the value drops e.g. below 15%, let the boiler switch off and above 15% let the boiler switch on.
blockly does not work, blockly doesn't work, nothing happens
- Blockly kotol.jpg (25.34 KiB) Viewed 1744 times
harrykausl
When you use lua, you have normally event based scripts. If a device changes, and you have a corresponding script, this script is started. For your Spirit Zwave you have normally 12 devices. One of the devices is the valve. This name you have to use in the naming of the script and in the if ... them code.
Have a look at the lua wiki to see the working. Perhaps you can also use dzvents, but I dont know, how this works.
- jursat
So finally solved through blockly
- Blockly kotol.jpg (29.61 KiB) Viewed 1720 times
