Calendar not showing
Michael87
Post by Michael87 »
Hi guys,
So I spend all weekend trying to get Dashticz configured the way I like. All works just fine except for the calendar function. I really tried everything, used the search button on this forum and could not find anything that works. Really hope someone can help, I'm stuck! Code snips of my Config.js:
var config = {}
config['language'] = 'nl_NL';
config['domoticz_ip'] = 'http://10.0.0.187:8585';
config['enable_websocket'] = 'true';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['hide_topbar'] = 0;
config['hide_seconds'] = 1;
config['app_title'] = 'ControlCenter';
config['gm_api'] = 'XXXXXXXXXXXXXXXXX';
config['gm_zoomlevel'] = '8';
config['gm_latitude'] = 'XX.XXXXXX';
config['gm_longitude'] = 'X.XXXXXX';
config['use_beaufort'] = 1;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 1;
config['selector_instead_of_buttons'] = 1;
config['calendarlanguage'] = 'nl';
var calendars = {}
calendars.school = { maxitems: 5, url: 'https://calendar.google.com/calendar/embed?src=XXXXXXXXXXXXXXXXXXXXXXXgroup.calendar.google.com&ctz=Europe%2FAmsterdam', icalurl: 'https://calendar.google.com/calendar/ical/XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXgroup.calendar.google.com/private-XXXXXXXXXXXXXXXXXXXXXXXXXX/basic.ics' }
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = [calendars.school]
columns[1]['width'] = 2;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg2.jpg';
screens[1]['columns'] = [1,2,3,4]
screens[2] = {}
screens[2]['background'] = 'bg2.jpg';
screens[2]['columns'] = [5,6,7,8]
In the dashboard I see a calendar block, it says 'laden' / 'loading' but nothing shows! Clicking the block will open the calendar straight away. What am I doing wrong?
Running
Dashticz V3.7.2 beta
Domoticz version 2020.2
dzVents version 3.0.2
PHP version 8.0.0
Michael87
Re: Calendar not showing
Post by Michael87 »
Dug a little further last night, found an error in console:
VM2655:116 Error in response from calendar with icalurl ./vendor/dashticz/ical/index.php?time=1610444906588&maxitems=5&url=https://calendar.google.com/calendar/ical/5gipqhlg6spdvabprtkk%40group.calendar.google.com/private-0dbd20…/basic.ics
Figured it had something to do with the timezones / language settings of the calendar so I took a look at the ics file:
BEGIN:VCALENDAR
PRODID:-//Google Inc//Google Calendar 70.9054//EN
VERSION:2.0
CALSCALE:GREGORIAN
METHOD:PUBLISH
X-WR-CALNAME:Basisschool de Veste
X-WR-TIMEZONE:Europe/Amsterdam
BEGIN:VTIMEZONE
TZID:Europe/Amsterdam
X-LIC-LOCATION:Europe/Amsterdam
BEGIN:DAYLIGHT
TZOFFSETFROM:+0100
TZOFFSETTO:+0200
TZNAME:CEST
DTSTART:19700329T020000
RRULE:FREQ=YEARLY;BYMONTH=3;BYDAY=-1SU
END:DAYLIGHT
BEGIN:STANDARD
TZOFFSETFROM:+0200
TZOFFSETTO:+0100
TZNAME:CET
Added 'Europe/Amsterdam' => 'Europe/Berlin', to my WindowsTimezones.php. Unfortunately without result. Help would be much appreciated!
(btw, weird thing. My garbage block is working just fine?)
Lokonli
Post by Lokonli »
What is the result if you open the url in a browser:
http://dashticz ip:port/vendor/dashticz/ical/index.php?time=1610444906588&maxitems=5&url=https://calendar.google.com/calendar/ical/…/basic.ics
(fill in your dashticz ip and calendar url)
Can you add '&method=0' and try again, so like:
http://dashticz ip:port/vendor/dashticz/ical/index.php?time=1610444906588&maxitems=5&url=https://calendar.google.com/calendar/ical/…/basic.ics&method=0
Michael87
Post by Michael87 »
Thanks for replying! I tried both; the first one results in:
<br />
<b>Warning</b>:  Undefined array key "history" in <b>/var/www/html/vendor/dashticz/ical/index.php</b> on line <b>37</b><br />
<br />
<b>Warning</b>:  Undefined array key "method" in <b>/var/www/html/vendor/dashticz/ical/index.php</b> on line <b>39</b><br />
<br />
<b>Fatal error</b>:  Array and string offset access syntax with curly braces is no longer supported in <b>/var/www/html/vendor/dashticz/ical/ical5/helpers/SG_iCal_Duration.php</b> on line <b>44</b><br />
The second url results in:
<br />
<br />
Lokonli
Post by Lokonli »
Can you try the new calendar block by adding 'type: 'calendar' to block definition?
Then a more modern PHP calendar library is used.
The old calendar block uses the old library, which seems to be not supported in PHP8 as used by you.
Michael87
Post by Michael87 »
I tried the following; unfortunately with only the title and icon as a result. Suggestions to improve?
blocks['calendar.school'] = {
    url: 'https://calendar.google.com/calendar/embed?src=5gipqk%40group.calendar.google.com&ctz=Europe%2FAmsterdam',
    icalurl: 'https://calendar.google.com/calendar/ical/5gipqk%40group.calendar.google.com/private-0db7d20e50e6ca9/basic.ics',
    maxitems: 5,
    type: 'calendar',
    title: 'Basisschool',
Lokonli
Post by Lokonli »
ok, then we do more or less the same experiment.
Can you open DevTools (F12), refresh Dashticz.
On the network tab filter for 'ical'. Right click on the network request -> Copy -> Copy link address.
Paste the link address in a new browser window.
Can you post the output?
Maybe your PHP version is too new, or some agenda items are not handled correctly, or something else ...
Michael87
Post by Michael87 »
It looks like the data is beeing imported nicely, however in the dashboard I see nothing.
<br />
<b>Deprecated</b>:  usort(): Returning bool from comparison function is deprecated, return an integer less than, equal to, or greater than zero in <b>/var/www/html/vendor/dashticz/ical/vendor/om/icalparser/src/IcalParser.php</b> on line <b>383</b><br />
{"1610406000":{"id":1,"title":"Vergadering OR","desc":"","location":"","start":1610406000,"end":1610492400,"allDay":true},"1610546400":{"id":2,"title":"est","desc":"","location":"","start":1610546400,"end":1610550900,"allDay":false},"1610617500":{"id":3,"title":"dadfas","desc":"","location":"","start":1610617500,"end":1610621100,"allDay":false},"1611097200":{"id":4,"title":"Begin nationale voorleesdagen (t\/m 30 januari)","desc":"","location":"","start":1611097200,"end":1611183600,"allDay":true}}
Lokonli
Post by Lokonli »
You see the PHP script generates a warning. Dashticz expects json format, and can't handle the html tags.
It's caused by PHP8. I'll check whether there is an updated PHP ical library. I'll supress the warnings as well.
Michael87
Post by Michael87 »
Thanks a lot Lokonli!
Lokonli
Post by Lokonli »
Can you test latest beta? I've integrated the updated ical library.
I don't have a PHP8 system, so I did not test myself on PHP8.
PHP7 seems to work fine.
Michael87
Post by Michael87 »
Checked and works like a charm! Thanks you very much Lokonli.
