How to check that some devices have been created some not in a plugin
darrepac
Post by darrepac »
I am just starting to put my hands on plugin in order to update a plugin. I read the wiki and some others plugin but did not understand how the devices creation work precisely particularly when you want to update the plugin:
I understood this from wiki:
import Domoticz
 def onStart():
   if (len(Devices) == 0):
       Domoticz.Device(Name="Status",  Unit=1, Type=17,  Switchtype=17).Create()
But if I want to create 1 device more with the same plugin without removing the already created devices, how can I do?
thx
Domoticz version: 2026.3
Re: How to check that some devices have been created some not in a plugin
In the following plugin there is an example how to handle this. https://github.com/mvzut/maxcube-Domoti ... /plugin.py
darrepac
Post by darrepac »
not obvious to me but will take a 2nd look
This part will check what type devices are supposed to be there and if new ones should be created (or even deleted, depends on plugin settings)
 def CheckDevice(self, name, deviceid, typename):
        # Initialization of variables for device creation
        switchtype = 0
        image = 0
        options = {"LevelActions": "|||",
                   "LevelNames": "Auto|Manual|Vacation|Boost",
                   "LevelOffHidden": "false",
                   "SelectorStyle": "0"}
        if typename == "Valve":
            devicetype = 243
            subtype = 6
        elif typename == "Thermostat":
            devicetype = 242
            subtype = 1
        elif typename == "Temperature":
            devicetype = 80
            subtype = 5
        elif typename == "Mode":
            devicetype = 244
            subtype = 62
            switchtype = 18
            image = 15
        elif typename == "Contact":
            devicetype = 244
            subtype = 73
            switchtype = 2
        # Check if device is wanted
        DeviceWanted = True
        if Parameters["Mode1"] == "False" and typename == "Valve" or Parameters["Mode2"] == "False" and typename == "Mode":
            DeviceWanted = False
        # Check if device with given deviceid and devicetype is already present
        DeviceFound = False
        for Device in Devices:
            if Devices[Device].DeviceID == deviceid and Devices[Device].Type == devicetype:
                DeviceFound = True
                # Delete found device if not wanted anymore
                if not DeviceWanted:
                    Domoticz.Log("Deleted device " + Devices[Device].Name)
                    Devices[Device].Delete()
                    break
        # If device not found but wanted, create it
        if not DeviceFound and DeviceWanted:
            # Check first available unit ID
            availableID = 1
            if Devices:
                for device in Devices:
                    if device > availableID: break
                    else: availableID += 1
            # Create device
            Domoticz.Device(Name=name + " - " + typename, Unit=availableID, DeviceID=deviceid, Type=devicetype, Subtype=subtype, Switchtype=switchtype, Options=options, Image = image, Used=1).Create()
            if availableID in Devices:
                # Device created
                Domoticz.Log("Created device '" + Parameters["Name"] + " - " + name + " - " + typename + "'")
            else:
                # Device not created!
                Domoticz.Error("Device '" + Parameters["Name"] + " - " + name + " - " + typename + "' could not be created. Is 'Accept new Hardware Devices' enabled under Settings?")
darrepac
Post by darrepac »
Thanks I eventually succeeded
