In first : happy New Year !
I hope to be in the good section.
Domoticz : Version: 2020.2 (build 12732)
On Raspberry Pi.
Onkyo amplifier : TX-NR575E
I try control my Onkyo amplifier in Domoticz, but I can't.
I don't know if I'm using the correct method.
So, in first, I add directly in Domoticz a hardware "Onkyo AV Receiver (LAN)" with IP and Port.
It's working, because in the Domoticz Log, I see :
" .... Status: OnkyoAVTCP: connected to: 192........"
But then I don't know.
If I understand
- I must go in the Domoticz Setting, and in System, I "Accept new Hardware".
- I'm going on my Onkyo amplifier and put in On.
- And I press on the Onkyo remote control buttons (TV, Radio, NET, ...)
- After this, I go back to Domoiticz Log, but nothing about Onkyo, excepted " .... Status: OnkyoAVTCP: connected to: 192........".
Same thing in the Devices : Nothing.
So I can't add new devices for Onkyo in Domoticz.
Maybe my amplifier isn't compatible ?
I hope you can help me.
Thanks.
Problem to integrate Onkyo amplifier in Domoticz.
Re: Problem to integrate Onkyo amplifier in Domoticz.
What port u used? My Onkyo is NR555 and working and a port is 60128.
jake
I use the python plugin for my NR535 receiver and can control on/off, input, listening mode and volume.
With this plugin I don't need to specify ip nor port number
Ok, I am using integrated plugin for Onkyo.
Frano
- Domoticz version: Bêta
Thanks for your reply.rodaman wrote: Friday 01 January 2021 20:51 What port u used? My Onkyo is NR555 and working and a port is 60128.
The port is 8080.
It seems it's good because in the log I can see " .... Status: OnkyoAVTCP: connected to: 192........"
But nothing after this when I try to integrate Onkyo devices.
- jursat
- Domoticz version: 2023.2
Port must bee 60128, 8080 is http port
eddieb
my TX-NR609 works great with the build-in .... port must be 60128
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
