ikea tradfri: domoticz plus controller, is it possible?
rrozema
Post by rrozema »
Most of my setup is z-wave, but since some time I've now also got 3 zigbee devices:
- 2 x ICPSHC24-30EU-IL-1, TRADFRI driver for wireless control (30 watt)
- 1 x L1527, FLOALT LED light panel, dimmable, white spectrum (30x30 cm)
For controlling them I use zigbee2mqtt with the zigbee2mqtt plugin.
The 30w led drivers are controlled only by domoticz and they work fine. The FLOALT led panel however came with a pre-paired dimmer device. That dimmer worked for some time, but after some time it stopped working. Thinking back, I think it stopped working when I paired the panel with domoticz but at the time I didn't see the connection. Recently I replaced the battery in the dimmer device then re-paired the dimmer with the led panel (Keep the dimmer close to the led panel and press the button in the battery compartment for 10 seconds until the led goes on and the panel flashes off for a second.) Now the dimmer can be used again to control the panel. I've however lost the ability to control the panel from Domoticz.
So here's my question: is it possible to have both a dimmer and domoticz control a zigbee device in general? Or at least my FLOALT led panel? And if so, how do I do it?
Thorgal789
Re: ikea tradfri: domoticz plus controller, is it possible?
Post by Thorgal789 »
Yes it s possible, you make bad procedure.
So first I m not using zigbee2mqtt so it will be the theorie.
You are making the bad procedure (10s press is for touchlink fonction) to make a direct link with a bulb and a remote, when you do that they live their network, to bind them themself.
You need to use the inclusion /pairing procedure, 4 short press in less than 5 s.
Include the remote in the network
Include the bulb in the network
Bind them using directly zigbee2mqtt
But the thirst step is optionnal, you can use domoticz to make the connection, the direct bind is just an option.
rrozema
Post by rrozema »
Thorgal789 wrote: Tuesday 29 December 2020 16:12 You need to use the inclusion /pairing procedure, 4 short press in less than 5 s.
Thanks, I will try this.
